OME 2.5” Lift Measurements?
Discussion in 'Suspension' started by The Patriot 1776, Sep 28, 2020.
  1. Oct 8, 2020 at 1:13 PM
    #61
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Agri-Cover,RCI skid,ADARAC,Fox 2.0,TruDuals
    Man, that totally sucks. I'd probably look into alternatives for the front. Since the R&P didnt last long the rest of the truck isn't gonna just "live with it". Maybe look at something adjustable like the Elka 2.0 coil overs. Then hopefully you can dial in the height yourself.
    Mountun Goat likes this.
  2. Oct 8, 2020 at 3:05 PM
    #62
    betotundra
    betotundra Toyota for Life
    Yeah, I saw that thread also.
  3. Oct 8, 2020 at 3:09 PM
    #63
    betotundra
    I Wouldn't write them off just yet.
    It's the first one I've seen having this kind of issues. Very awkward nontheless.
  4. Oct 8, 2020 at 4:40 PM
    #64
    The Patriot 1776
    The Patriot 1776 [OP] Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    It definitely sucks. Have y'all looked into Dobinsons? They're a quality product but odds are pretty high you'll have to wait for shipping.
    I had Fox 2.5 C/O's on my Taco. I wasn't all that impressed for the amount of money I spent on them. The Toytec Aluma series looks promising if you want an adjustable C/O w/out breaking the bank. King is top notch but top dollars, too. Icon's have a different style internally & some don't like the way it handles as it's the opposite of everyone else's C/O's.
  5. Oct 15, 2020 at 4:13 PM
    #65
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Man, what an absolute horror show. This makes no sense. Sorry to read this, @The Patriot 1776!
  6. Nov 1, 2020 at 10:13 AM
    #66
    The Patriot 1776
    '16 TSS CM 4x4
    So I'm going to try something for my particular weird scenario. I'm going to cut the coil springs to the length needed, for my truck, to give me ~3" of lift but not sure how to measure them. Should I measure them @ free height, not attached to the shock, or should I measure them in loaded position @ static ride height? I'm going to cut about 1" off DS & 1.5" off PS. My DS sits ~.5" lower than PS & will 'bang' on potholes/holes/hard dips from over-extension but nowhere near as much as the PS.
    So, should I measure them @ free height, not attached to the shock, or should I measure them in loaded position installed on the shock @ static ride height?
    (Yes, I know this is a weird ass thing to do but I don't see any other choice for my weird ass scenario. I am absolutely positive the banging/popping sound is from the lift being too high & the shocks maxing out on extension (droop) when hitting imperfections in the road or driving on dirt roads. I can't do more than ~3mph on a trail w/out this vicious racket.)
    ***ETA***
    Disregard. These type springs can't be cut properly due to the style of the ends. They would ever seat properly. My only option is a refund.
    Mountun Goat and equin like this.
  7. Nov 1, 2020 at 10:24 AM
    #67
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Is there any way they sent you the wrong struts (spring perch is incorrect height)?
  8. Nov 1, 2020 at 11:05 AM
    #68
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Sorry to hear of the troubles you’re having. I’ve heard nothing but good things about OME suspensions with other vehicles, but it seems like it may be hit or miss with Tundras for some reason. Definitely keeps me from considering them as an option as I, too, am thinking of adding a heavier front winch bumper.
    Anyway, I’ve cut coil springs before using a chop saw. Spring rate stays the same. The trick is figuring out how much to cut. I’ve done this on smaller vehicles (older Civics), so it was very quick and easy to install and remove numerous times til I got it at the right height. You may have to cut bit by bit til you get it just right, which means going through the trouble of R&R’ing the coilovers each time. Only other thing to factor in is the settling over time. So if you cut it to the right length, it’s possible they may eventually settle a bit more, but it’s always difficult to predict by how much and over what period of time.
    Steering rack sounds like a pain, too. Good luck and please keep us posted.
  9. Nov 1, 2020 at 12:01 PM
    #69
    The Patriot 1776
    '16 TSS CM 4x4
    No. I've installed 2 sets w/the same results.
  10. Nov 1, 2020 at 12:02 PM
    #70
    JLS in WA
  11. Nov 1, 2020 at 5:46 PM
    #71
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    This thread makes me :(:(
    The Patriot 1776[OP] likes this.
  12. Nov 1, 2020 at 5:47 PM
    #72
    The Patriot 1776
    '16 TSS CM 4x4
    Me too. And :mad:
    Mountun Goat[QUOTED] likes this.
  13. Nov 1, 2020 at 6:19 PM
    #73
    betotundra
    Some day the mistery shall be solved.
  14. Nov 1, 2020 at 7:35 PM
    #74
    The Patriot 1776
    '16 TSS CM 4x4
    I just sent Wheeler's requesting a refund for the coilovers. I'm completely happy w/the rest of the lift I installed. We'll see how this goes. I see no reason why they wouldn't seeing as I can't even drive my truck down dirt roads w/out it banging. I use this truck for truck stuff & drive quite a bit on dirt roads & all over my deer lease.
  15. Nov 1, 2020 at 7:37 PM
    #75
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Hopefully they play nice with you and refund without issue. What’s your plan after refund? Try a different brand coilover up front?
  16. Nov 1, 2020 at 7:38 PM
    #76
    The Patriot 1776
    '16 TSS CM 4x4
    Yes. Probably Dobinsons 3" HD. Hope it doesn't bite me in the ass!!!
  17. Nov 1, 2020 at 7:41 PM
    #77
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I hope so too. Keep us updated. I’d sure like to see the ome vs. Dobison side by side once removed for comparison sake. Be nice to find the issue. Nothing worse than never finding an answer :annoyed:
  18. Nov 1, 2020 at 7:51 PM
    #78
    The Patriot 1776
    '16 TSS CM 4x4
    I'll take some pics. IDK WTF I'll do if their 3" lift gives me 4.75" lift besides lose my damn mind!
  19. Nov 1, 2020 at 7:52 PM
    #79
    betotundra
    Maybe add 2" extra in the back to level her up?
    JK
  20. Nov 1, 2020 at 8:02 PM
    #80
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    No joke, that would call for a straight axle leaf spring swap :D
  21. Nov 2, 2020 at 6:11 AM
    #81
    The Patriot 1776
    '16 TSS CM 4x4
    It sits dead nuts level now. I love the look but the functionality isn’t there.
    That’d kick ass but also be over $10K.
  22. Nov 2, 2020 at 6:44 AM
    #82
    Terndrerrr
    Music City
    6UR-FE
    Maybe all the springs you’ve received are from a bad batch? They measure at the correct height uninstalled, but are they just way too stiff? I’m frustrated just from reading this. I can imagine how upset you must be.
    I was going to order the BP51 kit before bookmarking this thread. But I’m now looking elsewhere as well.
  23. Nov 2, 2020 at 6:56 AM
    #83
    The Patriot 1776
    '16 TSS CM 4x4
    That’s what I’m thinking but ARB says no. That’s the only thing I can think of. It’ll be interesting to see if others start having this issue when installing this kit.
  24. Nov 2, 2020 at 7:46 AM
    #84
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    What a shitshow. I'm sorry to hear they didn't work out. I'm looking at adjustable coilovers like Toytec and Elka for mine. I think you should too so you can dial in your ride height to account for the bumper rather than go with another fixed length setup like the Dobinson and hope the spring weights and lengths work out.
    I'm curious if you measured from the spring perch to the bottom shock eyelet and compared with other members running the same setup. There's gotta be a snafu with the shock length or a batch of springs with the wrong weight.
  25. Nov 2, 2020 at 4:31 PM
    #85
    betotundra
    Aren't this the ones with the grey shocks, I think the OP has the yellow ones, not the same.
  26. Nov 2, 2020 at 5:27 PM
    #86
    The Patriot 1776
    '16 TSS CM 4x4
    Besides the cost, I wouldn’t hesitate to buy the BP51 kit. I bet it rides niiiiice.
  27. Nov 2, 2020 at 6:20 PM
    #87
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Agreed. Plus, as unfortunate as it is, seems to be an isolated case. A real sh!ty isolated case!
  28. Dec 17, 2020 at 12:02 PM
    #88
    Duramaxh1
    Duramaxh1 New Member
    Fingerlakes ny
    19 Additude Black Tundra SR dclb
    5100 /5160, air lift bags, daystar cradles, on board compressor. Diff drop. S&B intake, homemade dual magnaflow exhaust. Ceramic coated paint/glass. Powder coated black calipers, Rock warrior wheels.
    Any resolution or explaination? Was really looking to run 613's but now im concerned.
  29. Dec 17, 2020 at 12:49 PM
    #89
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    Man... not to beat a dead horse, and this is coming from experience making this mistake myself. I installed the spring perches upside down once and couldn't believe how much more lift I had. Experienced much of the same trouble you're describing. Not saying this is what's going on but it may be worth another look. When I compare the image from your install to a stock image of a OME strut with the perch installed it looks to me like yours are upside down. What really leads me to believe this is it looks like like I can see the perch ledge on the shock in your photo. In the stock photo it looks like the "cup" of the perch should be facing down and conceal that ledge. When you're looking at the parts it seems counterintuitive to install them the way they need to be installed which is why I believe this happens. See images and let me know your thoughts.
    Duramaxh1 likes this.
  30. Dec 17, 2020 at 1:11 PM
    #90
    DFW
    2021 Limited 4x4
    Now I'm finding conflicting images.... some with the cups facing up and some facing down....
