Olsin6's Tundra Build
Discussion in '2nd Gen Builds (2007-2013)' started by olsin6, Sep 21, 2016.
  1. Aug 6, 2017 at 11:15 PM
    #61
    olsin6
    olsin6 [OP] New Member Vendor
    Joey
    Mesa, AZ
    2010 White DCSB Tundra
    35" Toyo MT w/ 17" Method Standards Body Mount Chop SDHQ Sliders
    I'll see what I can get together. But it consisted of them doing a complete rebuild and doing their bulletproof package while doing it. This includes their clutch pack with all new seals and bearings throughout the trans, new output shaft, Billet torque converter, new valve body with the necessary porting needed, bigger and better oil pump. This is going to get rid of the long delayed shifts and makes everything quicker and firmer.
  2. Aug 7, 2017 at 10:15 AM
    #62
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Did you go with that deeper transmission pan with fins?
  3. Aug 7, 2017 at 10:51 AM
    #63
    olsin6
    Joey
    Mesa, AZ
    I thought about it but did not at this time. I will probably do that when I need to do the break in service at 12,000 miles.
  4. Jun 9, 2018 at 8:11 AM
    #64
    olsin6
    Joey
    Mesa, AZ
    Well, there has been a ton of upgrades, changes, adventures, etc that have happened since August of last year. I am working on updating this build thread, just been spending too much time on the SDHQ login.
  5. Jun 9, 2018 at 9:15 AM
    #65
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    We like up grades and mods
    4x4_Angel and TheBeast like this.
  6. Jun 9, 2018 at 9:57 AM
    #66
    TheBeast The Beach
    yes please :)
  7. Jun 9, 2018 at 9:59 AM
    #67
    Juddrussell
    Juddrussell New Member
    Jacob
    Bentonville, AR
    2016 MGM Tundra TRD Pro
    BAMF Bedrack, 295/70/r18 General Grabbers, Bedslide, Weathertech floor mats, and Tepui Autana Sky RTT.
    WE NEEEED PICTURES
  8. Jun 11, 2018 at 8:35 AM
    #68
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    I saw you got that chase rack mane! That might be my next upgrade!
    4x4_Angel and sdhq_offroad like this.
  9. Jun 14, 2018 at 11:44 AM
    #69
    olsin6
    Joey
    Mesa, AZ
    So last update I chimed in on was when I blew my transmission shortly after doing our 4th of July video last year. See link for video if you haven't watched it or want to watch it again. https://www.youtube.com/watch?v=IWH6oNQyMy0
    So I had nothing but problems with the aftermarket transmission and ended up just putting a stock one back in. Shortly after, a company gave me some gear oil to test in the rear diff and they ended up giving me the wrong stuff. So it smoked the rear end. They were thoughtful enough to replace the stuff for me and I figured since its cheaper to upgrade, may as well doing gears and an Auburn Limited Slip! Took advantage of the new REM polishing that we are doing to all of our gears pre-install so that there is no break in period and also it hardens the gears. Been smooth cruising since!
    Decided after doing too much night off-roading with stock headlights that I need a little extra light. Went with the @sdhq_offroad A-Pillar mounts and mounted up some @Baja Designs XL80's in the amber Driving/Combo pattern. All I have to say is WOW! You can't out run these things!
    I ended up working the AZ Off-Road Expo and we had a trailer that needed to be towed home otherwise someone was making another 45 mile each way trip. Don't be fooled by the size, this thing is lined with steel cabinetry as a display trailer. Put the truck on the hydro bumps but got her towed home no problem. My @dirtydeeds budget dump was screaming out of joy! People, hit him up if you like aggressive!
    Went to Tundras to Sedona 2018 shortly after. Boss man asked me to take the shop Tundra and I wasn't going to turn that down. Don't have many action shots but there are pictures in Tron's build thread. Was a blast and took a few guys from some bitchin rides through the Cinders whoops at 85mph.
    We decided to designed and produce a chase style rack for the rear of the Tundras. Once we got them worked up, I HAD to have one. It fit my needs too much and it looks bitchin!
    With the desire to get an even better ride with the Icon shocks, I started looking around for a spindle so that I could take all the preload out of my coilovers. After some test fitment, we found that the CST spindles will work with the 17" Method wheels. With the amount of lift given in the front, I had to bring the rear up as well. From stock leafs with Icon 2.5" rear shocks w/ CDC and hydro bumps to Icon RXT leaf pack, 2.5" RXT spec bypasses, and the Icon hydro bumps. This leaf pack is the smoothest pack I have ever had in a truck. It is also weight configurable to how much static weight you have in the back. I has the chase rack with one spare (225lbs) on the option #1 setting.
    I've also been thinking about going with new wheels. I have been eyeing the new Method 701's in black and with all the available room front and rear due to the spindle and leaf pack, did some test fitting. 37x12.50x17 will fit no problem without any rub while maintaining full suspension travel and usability after a tad bit of trimming. There are a couple future "updates" that will be happening around this same time.
  10. Jun 14, 2018 at 11:59 AM
    #70
    TheBeast The Beach
    very nice !
  11. Jun 14, 2018 at 12:05 PM
    #71
    TheBeast The Beach
    are you using the switch pro as well for wiring all the lights inside the cabin ?
  12. Jun 14, 2018 at 3:30 PM
    #72
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Looking good bud! Those rear bumps are amazing!!
    I still need to stop by and check out the fronts on the shop truck
    olsin6[OP] likes this.
  13. Jun 14, 2018 at 3:35 PM
    #73
    Awesome Sauce
  14. Jun 14, 2018 at 4:25 PM
    #74
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Damn you have done a lot sense the last time I seen your truck. Very sweet
  15. Jun 15, 2018 at 9:05 AM
    #75
    olsin6
    Joey
    Mesa, AZ
    Swing by!
  16. Jun 15, 2018 at 9:12 AM
    #76
    olsin6
    Joey
    Mesa, AZ
    Its been a little bit since you've been by. No way there isn't something that you need by now!
    blue16[QUOTED] likes this.
  17. Jun 15, 2018 at 9:18 AM
    #77
    TheBeast The Beach
    just noticed you still have the spare under the bed..lol
  18. Jun 15, 2018 at 9:23 AM
    #78
    olsin6
    Joey
    Mesa, AZ
    Yeah, I wanted more weight at the very rear end so that I don't have to put as much rebound in to prevent the bucking.
  19. Jun 15, 2018 at 9:36 AM
    #79
    Rextinkleton93
    Rextinkleton93 New Member
    Kyle
    Chandler, AZ
    2018 Superwhite 4x4
    Guess I’ll sub to this thread, even though it makes me a wee bit jealous.
    Erichudgins and olsin6[OP] like this.
  20. Jun 16, 2018 at 12:20 PM
    #80
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    I am due to show the Tundra some love
  21. Jan 26, 2019 at 5:02 PM
    #81
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    You need to update this thing
    TRON likes this.
  22. Jan 26, 2019 at 7:54 PM
    #82
    olsin6
    Joey
    Mesa, AZ
    No kidding! When time permits.
    TRON and Erichudgins like this.
  23. Jan 27, 2019 at 7:42 PM
    #83
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I too have a 2010 DC tundra 2wd. Thanks for showing exactly what I’ve been picturing in my head for a build!
    Truck looks amazing! Looks like with the cst spindles you were able to avoid cranking the c/o’s up? Nice flatter uca angle, therefor nice ride?
    olsin6[OP] and Rica25 like this.
  24. Aug 2, 2019 at 3:11 PM
    #84
    olsin6
    Joey
    Mesa, AZ
    Correct, it rides like a dream with zero preload in the coilover
  25. Aug 2, 2019 at 3:17 PM
    #85
    olsin6
    Joey
    Mesa, AZ
    Big things coming down the pipeline on this truck! I post mostly on the SDHQ account answering questions and what not, so I haven't been too active.
    We move into our new 30,000 square foot facility in a month which is a huge undertaking for us.
    TRON, PLC721 and zcarpenter92 like this.
  26. Aug 2, 2019 at 3:38 PM
    #86
    olsin6
    Joey
    Mesa, AZ
    Some random shots throughout the last few months
    37" Toyo M/Ts on 17" Method 701's. Riding on the gorgeous Camburg Kinetik Billet Upper arms and Icon 3.0 Coilovers.
    The Ragin Cagin himself came to visit. Still one of the best looking built second gen Tundras out there. SDHQ Built!
    Headed out the Tundras to Sedona with the shop truck!
    Christmas in the mountains
    Weekend adventure
    The other side project. :spending:
    motoxscott, TheBeast, TRON and 3 others like this.
