Older trd pro grill on 2018 up with tss can be done!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Allrsdup, Aug 16, 2020.
  1. Aug 16, 2020 at 7:39 PM
    Allrsdup
    Allrsdup [OP] New Member
    Joe
    24 Lunar Rock Limited crewmax trd ord
    What's up guys in case anyone was wondering I actually found you can install the older style Toyota tundra TRD pro grill on your 2018 and up with the TSS and still have it work perfectly! With the right parts it was actually super simple made a quick video Hope this helps some members.
    https://youtu.be/YjsXo5EoP6A
  2. Aug 16, 2020 at 9:58 PM
    2020 dc
    2020 dc New Member
    2020 tundra dc sr
    Thanks for sharing.
    Allrsdup[OP] likes this.
  3. Aug 17, 2020 at 3:55 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Good luck.....post back in a week or two and let us know if it is still working. I had the exact same setup and it didn’t work. Even paid $200 at the dealership to recalibrate the sensor. Nothing worked - kept saying that the pre collision system was off and unavailable. I got the Jomax bracket and it has worked ever since I replaced the bracket. It seems to me that the Ajt bracket has too thick of a face plate. The Jomax is much thinner. Please keep us posted
  4. Aug 17, 2020 at 9:00 AM
    Allrsdup
    Joe
    Drove it yesterday and this morning all good so far even used adaptive cruise. I know these radars are finicky even without modifying sometimes people have issues from what I understand AJT has redesigned their bracket so maybe you had the original design but so far so good if I start having an issue I will definitely report it.
  5. Aug 17, 2020 at 8:53 PM
    Allrsdup
    Joe
    So far so good! All working well! Was pacing the car i front of me for 10 miles no issues. IMG_20200817_105316_1.jpg
  6. Aug 18, 2020 at 5:00 AM
    InsaneAuto86
    InsaneAuto86 New Member
    SE PA
    2020 Tundra SR5 TRD
    I did the exact same thing, 18 pro grill on my 20 w ajt bracket. It doesn't work
  7. Aug 18, 2020 at 5:40 AM
    Blacktooth
    Blacktooth New Member
    Raleigh, NC
    2018 Platinum
    I put the old style grill w/ AJT bracket on my 18 back in April. I get the PCS off warning when it's raining out but otherwise it's fine.
  8. Aug 18, 2020 at 5:49 AM
    shawn474
    MoCo, Maryland
    I installed the older style grill on a 2019 with Ajt bracket a couple months ago. After about 100 miles (I guess the computer was recalibrating or something) the PCS would randomly turn off, the adaptive cruise control wouldn’t work and there were no “BRAKE” warnings that would come up on the dash. I replaced with the Jomax bracket and all works fine now. I know some have had success with the Ajt bracket and many have not. I believe it’s a matter of the thickness on the plastic faceplate.
    Tundrastruck91 and Allrsdup[OP] like this.
  9. Aug 18, 2020 at 8:44 AM
    Allrsdup
    Joe
    Definitely possible these are finiky systems. Thanks for the heads up. Ill be sure to update if stops working. And ill ill another alternative.
  10. Sep 29, 2021 at 5:07 PM
    normagene
    normagene New Member
    Normagene
    New England
    2021 Cement DC Limited Texas Edition
    Texas Edition
    Any issues. Been awhile now so it’s either a thumbs up or down.
    I’m considering/on the fence whether to swap out my stock grille into the color matched old style pro grille or installing the color matched old style pro grille with a ajt bracket.
  11. Sep 29, 2021 at 6:19 PM
    CamaroSsToTundra
    CamaroSsToTundra New Member
    Ohio
    2018 Tundra
    Same here it didn’t work
  12. Sep 29, 2021 at 7:15 PM
    normagene
    Normagene
    New England
    Texas Edition
    So what did you do? Still using the pro grille?
  13. Sep 29, 2021 at 7:46 PM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    I just ordered ajt bracket first to find out if it will work. It didn’t work so I kept the stock grill.
  14. Sep 29, 2021 at 8:36 PM
    normagene
    Normagene
    New England
    Texas Edition
    Did you insert your stock grille into a color matched old style pro grille?
    That’s the reason I ordered the old pro grille just for the color matched surround but when I opened the box today I was like….hmm this is pretty nice too.
    But if the ajt bracket is wonky and works sometimes under certain conditions then it’s not worth the hassle. From what I’ve read the Jomax bracket worked correctly but is no longer available for some reason.
    Anyway appreciate your input. Thanks
  15. Sep 29, 2021 at 9:50 PM
    CamaroSsToTundra
    Ohio
    2018 Tundra
    You can try it might work
  16. Oct 4, 2021 at 12:41 AM
    Allrsdup
    Joe
    Im not in the truck anymore. But i had it 2 months with that setup. No issues for me.
  17. Oct 4, 2021 at 6:59 AM
    normagene
    Normagene
    New England
    Texas Edition
    Thanks appreciate your input
    Allrsdup[QUOTED][OP] likes this.
  18. Oct 5, 2021 at 6:59 PM
    Vickbo
    Vickbo New Member
    Mark
    Indiana
    2021 Tundra Off Road
    Does anyone have a purchase link to Jomax Bracket?
  19. Dec 18, 2021 at 10:17 AM
    shawn474
    MoCo, Maryland
    they don’t make them anymore
