Old man emu lift?
Discussion in 'Suspension' started by Tundra1794E, Jan 24, 2018.
  1. May 28, 2020 at 8:57 AM
    #241
    Limber
    Limber New Member
    Chase
    to much to list
    How are the 5.29 with 35's thinking on going this exact same route in a couple months but with 613's I already have a bumper and winch
  2. May 28, 2020 at 9:40 AM
    #242
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Looks great! So are you saying you went from a 3” front lift and then gained an additional 1.5” front lift for a total of 4.5” up front?
    Mountun Goat likes this.
  3. May 28, 2020 at 10:11 AM
    #243
    DesertGorilla
    DesertGorilla New Member
    Eric
    Tucson
    12 CM SW 4x 35s
    17" Methods 35x12.5 BFG KO2 - OME 612 Kit Dakar Rears OME Shocks & Shackles. - Nitro 5.29s and Auburn LSD
    Front was at 40" its now 41.5" I think that with stock springs and readylift I was probably around 2.5 inches of lift (given the spring rate being much lower than the OME)...so now im about 3.5" inches
    equin[QUOTED] and Mountun Goat like this.
  4. Jun 1, 2020 at 3:52 PM
    #244
    DesertGorilla
    Eric
    Tucson
    12 CM SW 4x 35s
    5.29s on 35s...overall its a big improvement especially city driving 5th and 6th gear have regained their value as in they are usable, for awhile i was driving in select mode and kept the truck in 4th until speed allowed me to shift to 5th and then 6th if i jumped on the freeway....
    Now to freeway driving with 5.29 on 35s...at about 70-75 it feels like I need 1 more shift...but its not there I drove from Tucson to Deming and back (seems like it was uphill both ways, LOL) RPMs stayed at around 2100 - 2200 but she held 6th gear the whole time, no searching for gears.
    I'll have to spend some more time on the freeway to give a better evaluation, I've got a drain and fill scheduled so once that is done I will get back on the road.
  5. Jun 3, 2020 at 8:35 PM
    #245
    Tundra9831
    Tundra9831 New Member
    I've been studying Tundra suspension to determine what route to go. These numbers may help others make an informed decision....assuming my research is correct ;)
    Dobinsons 2.25” coils - 737lb, 410mm free height
    Dobinsons 3” comfort coils - 662lb, 460mm free height
    OME 612 coils - 2.5” lift with 0-150lbs - 740lb, 415mm free height
    OME 613 coils - 740lb, 435mm free height
    OME 614 coils - 740lb, 425mm free height
    MrClortho and DesertGorilla like this.
  6. Jun 7, 2020 at 7:10 PM
    #246
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Question for those running the 612 kit. Did you guys also install the brake line and ABS extension kit? Is it recommended to also upgrade the bump stops and add a carrier barrier spacer?
  7. Jun 10, 2020 at 2:40 PM
    #247
    DesertGorilla
    Eric
    Tucson
    12 CM SW 4x 35s
    I did install the extension kit...did not upgrade the bump stops, and I think I'm about to get the https://shop-coachbuilder.myshopify...drop-kit-rear-lift-0-2?variant=12559349710925, but not 100% sure yet.
    300BLK[QUOTED] and Mountun Goat like this.
  8. Jun 21, 2020 at 4:40 PM
    #248
    Rolling Biome
    Rolling Biome New Member
    Denver, CO
    2019 Tundra CM Limited TRD Off Road
    For those of you that are running OME setups, did you install a trim packer to compensate for any "lean?"
  9. Jun 21, 2020 at 5:01 PM
    #249
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I’m on coachbuilder shim +1 on drivers side.
  10. Jun 21, 2020 at 5:37 PM
    #250
    Rolling Biome
    Denver, CO
    Any reason you chose Coach Builder shim and not the OME trim packer?
    Mountun Goat[QUOTED] likes this.
  11. Jun 21, 2020 at 7:09 PM
    #251
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’ve never heard of a trim packer until now. A member was selling the shins I have on the forum, that’s what I ended up with is all. Mind you, I also have one 1/4” steel plate I traced off a coachbuilder shim and it works exactly the same. :hattip:
  12. Jun 22, 2020 at 6:42 AM
    #252
    Rolling Biome
    Denver, CO
    Gotcha. Thanks!
    I'm debating on the OME setup vs. Bilstein 6112/5160 or possibly something more elaborate. I like the set-it-and-forget-it approach and don't want to have to pull the suspension every couple of years for a rebuild.
  13. Jun 22, 2020 at 6:56 AM
    #253
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’ve really enjoyed my ome 613’s. Having a bunch of extra weight added to my truck, it rides like it should. I’ve never heard many things bad about either ome/bilstein setups. I’m sure you’ll be stoked with either :hattip:
    Rolling Biome[QUOTED] and 300BLK like this.
  14. Jun 22, 2020 at 6:56 AM
    #254
    300BLK
    300BLK New Member
    I was in the same position as you a month ago. I went OME and I’m happy I did. I love my setup. I don’t do any high speed off road driving here on the east coast so I didn’t see much of a need for a reservoir setup. These OME setups are bulletproof and pretty much zero maintenance.
  15. Jun 22, 2020 at 7:08 AM
    #255
    Rolling Biome
    Denver, CO
    Thanks for the feedback! There's a lot of info on this site on Bilsteins and all the other options but not a lot on OME so it's good to hear you've had a positive experience. I do like that the OME setup has more lift and more spring options than the Bilsteins. I'm assuming slightly more travel as well but haven't found any info online.
  16. Jun 22, 2020 at 7:19 AM
    #256
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’m not experienced with bilsteins, but I have also airborne the front of my 6000lbs truck without issue on my ome. I also have a few buds who run ome on their Tacoma work trucks. The roads these trucks drive down everyday is basically a one hour baja run one way twice a day. Anywhere from plus 30c to -40c and they haven’t had issue after years of abuse. Sold me.
    300BLK and Rolling Biome[QUOTED] like this.
  17. Aug 22, 2020 at 12:17 PM
    #257
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    Damn I was looking at pulling the trigger on the OME front Coilovers/strut assembly and the rear shocks, but now I’m concerned I’m going to have a bro lean. I currently have 3” spacer front, 1” block rear. You’re saying with a 2” lift in the rear you are dead level? I was hoping to achieve a tiny bit of rake putting the OME on the front (which claims 2.5” lift) and leaving the rear 1” block.
  18. Aug 26, 2020 at 11:04 AM
    #258
    300BLK
    300BLK New Member
    Update on my OME setup after about 1500 miles. Very happy with it. Once the springs settled the ride has become more comfortable. In addition i took it out to some trails while camping this past week. It handled everything i threw at it well. Great travel and also handled trails at higher speed well. I'm definitely going to fluid film the shocks and consider shock covers though. Not too happy about the finish wearing off fairly easily. I have a number of chips in the paint of both body of the shock and the springs.
    Mine is level with a 1.5" block in the rear. Eyeballing though, i haven't measured.
    Skey44 and Mountun Goat like this.
  19. Aug 26, 2020 at 9:33 PM
    #259
    McCrapper
    McCrapper New Member
    For those on the 613s are yall replacing the UCAs? results?
  20. Sep 8, 2020 at 10:31 AM
    #260
    DesertGorilla
    Eric
    Tucson
    12 CM SW 4x 35s
    I didn't or haven't seen any lean at all.
  21. Sep 8, 2020 at 10:51 AM
    #261
    DesertGorilla
    Eric
    Tucson
    12 CM SW 4x 35s
    I did end up installing the coachbuilder carrier bearing drop...the shudder from a dead stop is gone, also installed coachbuilder bumper shims got rid of the last of the rubbing at full turn while going uphill while banking on I-10 off-ramp, going 35s has been a pain in the ass...but love the way she looks...hahaha
  22. Sep 17, 2020 at 11:31 AM
    #262
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    I ordered the OME 2613 coils, w/the complete kit including Dakar’s and greaseable shackle bushings, & it's to be delivered today. I was hoping for 3" lift w/those springs but I also have an ARB Summit front bumper & 10K winch, which weigh about 250lbs together. Should I use 1/2" trim packers/spacers to lift the front a bit more so I can get 3" of front lift?
  23. Sep 17, 2020 at 1:02 PM
    #263
    DesertGorilla
    Eric
    Tucson
    12 CM SW 4x 35s
    My understanding is that the 613 will give you the 3" lift you're looking for with the bumper installed, but it seems like each truck is different...I feel like the 612s gave me a little more lift than I expected.
    Mountun Goat and RLHULK like this.
  24. Sep 17, 2020 at 6:07 PM
    #264
    The Patriot 1776
    '16 TSS CM 4x4
    I was under the impression:
    612 = 2.5”
    613 = 3.5”
    614 = 3”
    This is with no heavy bumper or winch. They’re all 740lb springs, just different lengths.
    betotundra, equin and Mountun Goat like this.
  25. Sep 17, 2020 at 9:33 PM
    #265
    DesertGorilla
    Eric
    Tucson
    12 CM SW 4x 35s
    I don't think any of the springs are supposed to give you more than 3...but for me and a lot of other we are getting slightly more then the 2.5-3" lift range from factory...now i went from 7 year old factory shocks, springs and 3/1 leveling kit to the OMETUN47LKS which included the 612 springs and got about 1.75 extra inches of lift on the front and about 2.5 inches in the rear...OME spring numbers seem to cause confusion but here is what i found on lowrangeoffroad.com which seems to confirm what you posted
  26. Sep 17, 2020 at 9:41 PM
    #266
    DesertGorilla
    Eric
    Tucson
    12 CM SW 4x 35s
    I'd say i was less the 3" upfront due to age and sagging...because 4.5" seems like a lot...I never measured from stock...first measurement was after 35s with factory shocks, springs and a 3/1 level installed more than 7 years ago, so with age maybe the 40 measurement put me at 2.25" and now 3.5...seems like a lot...hope it settle soon, hahaha.
  27. Sep 18, 2020 at 6:10 AM
    #267
    The Patriot 1776
    '16 TSS CM 4x4
    If used for their intended purpose, no they shouldn’t give you more than 3. But people are using the longer springs in situations that don’t call for them (614 to get 3” lift with a stock truck instead of having 4.6L w/winch and bumper, 613 for 3.5” for stock truck instead of having winch and bumper).
    I’ll be running 35x11.5x18 so I’d like to have a full 3” lift. I’ll just install what I have now and if I need to add packers I will in the future. I’ll post back what numbers I get.
    betotundra and Mountun Goat like this.
  28. Sep 18, 2020 at 8:16 AM
    #268
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I have always found that OME suspensions generally run a little taller than advertised. They certainly do not run small. I think that you will find that they are about 1/2 inch higher, and that may be so that once it settles and has some wear it still meets the specs. They build a great product.
  29. Sep 18, 2020 at 8:27 AM
    #269
    300BLK
    300BLK New Member
    Yeah i'm pretty sure mine is closer to 3" despite being a 2.5" kit.
    DesertGorilla and Mountun Goat like this.
  30. Sep 18, 2020 at 8:39 AM
    #270
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’m on 613’s with an arb Sahara bumper (no winch yet) and lots of extra weight bolted onto the truck and got 3.5” from my old worn suspension. I also added coachbuilder shim’s for 4” total lift. Fyi
