Old man emu lift?
Discussion in 'Suspension' started by Tundra1794E, Jan 24, 2018.
  1. Mar 24, 2018 at 8:40 PM
    #61
    Treemite
    Treemite New Member
    AZ
    I ordered mine from Toytec with the front coils already assembled and did it all in my garage with 1 set of Jack stands so it's not bad at all. You will still need an alignment even if you mark the cam bolts position.
    zcarpenter92 and Mountun Goat like this.
  2. Mar 25, 2018 at 10:10 AM
    #62
    Ret_Soldier
    Ret_Soldier New Member
    Andy
    '17 Tundra Platinum
    You're from Aurora? Do you have OME 612s? How was the power loss from the 295s? Also, do you have pics of it parked on level ground? I'm having my 612 kit installed on 4/20. Also live in Aurora.
  3. Mar 25, 2018 at 5:33 PM
    #63
    Wow..a fellow Auroraian... Yep..got the 612. Was considering the 613. Went wheeling to above Central City. Ride was fine so I'm staying with the 612s. My truck was level until I installed Toytec shackles to regain rake. Putting in Dakar leafs soon. What power loss? None.
  4. Mar 25, 2018 at 5:50 PM
    #64
    Ret_Soldier
    Andy
    '17 Tundra Platinum
    Do you have pics of your truck on level ground? What was your approximate lift in the front? I have heard different heights with the 612s. Also having the Dakar leafs installed.
    Mountun Goat likes this.
  5. Mar 25, 2018 at 7:38 PM
    #65
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I’m wondering if the 613’s I ordered are gunna be super stiff? I have the arb Safari bumper on it now. No winch yet but plan on at some point... I also ordered spc uca’s so I figure that will help harshness slightly. Am I in for a literal and figurative shock?
  6. Mar 25, 2018 at 7:48 PM
    #66
    Over 2.5". Closer to three. There are several pics on my build thread.
  7. Mar 25, 2018 at 7:49 PM
    #67
    613s are overkill with the Ranch Hand. I had the Ranch Hand with 612s and was a little stiff.
    Mountun Goat[QUOTED] likes this.
  8. Mar 25, 2018 at 9:00 PM
    #68
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Ah shit haha. What amount of lift did you get with the bumper and 612’s?
  9. Mar 26, 2018 at 5:52 AM
    #69
    No change at all. Still around 2 3/4". I subtracted the weight of the OEM steel bumper cover, bumper, and steel brackets from total weight of new bumper plus winch. About 170lbs. 612s should be good to go. If I was over 200lbs then I would switch to the 613s.
  10. Apr 23, 2018 at 10:24 PM
    #70
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Looky what showed up on my doorstep today. Now I need to find the time o_O
    J&ATundra, Y0TA PR0, TheBeast and 2 others like this.
  11. Apr 24, 2018 at 12:59 PM
    #71
    Waterman
    Waterman Some Days Life Almost Makes Sense
    18' Crewmax 4x4
    Stuff
    @2ndgenny that looks SWEET! This is the exact setup I am going to do this next month. Who did you end up going through? Toytec, Sleeoffroad, someone else?
  12. Apr 24, 2018 at 2:34 PM
    #72
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I went through a local shop called Baja North... I’m pretty stoked to see how this setup works. I’m sure it will kick the shit out of the stock one with 450000 Km’s on them haha
  13. May 6, 2018 at 1:42 AM
    #73
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Well that was a long ass night! Got the front of my OME lift and SPC uca’s on. Passenger side was easy going (did it first too). Drivers side I fought every bolt. They were seized to shit. I guess 450000km will do that. Anyway I took my sway bar off too (I had to cut the links cause the bolts were seized on). My plan for the truck is max flex anyway. I also cut relief notches in the lower control arm shock bracket, so at max droop it’s not pushing the side of the shock (common failure point from what I gather). I’ll weld the back of the bracket solid to the control arm before I’m done as well. I screwed up and didn’t measure the lift I got but just by looking it’s for sure +3”. I’ll post a better before and after I’m the daylight. :amen: Rear Dakar’s and Daystar bag cradle’s to follow...
    jewsNbrews and Waterman like this.
  14. May 6, 2018 at 8:53 AM
    #74
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Here’s some better afters
    Waterman likes this.
  15. May 6, 2018 at 3:42 PM
    #75
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Here’s a before and after. Lifted front is on top. I need to get the rear done ASAP!
    mtTundra and Waterman like this.
  16. May 6, 2018 at 8:57 PM
    #76
    Waterman
    18' Crewmax 4x4
    Stuff
    Looking sweet @2ndgenny can't wait to see the rest!
  17. May 6, 2018 at 9:10 PM
    #77
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks me too haha:thumbsup:
  18. Jun 5, 2018 at 7:21 AM
    #78
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    You have the 612 coils and got roughly 2 3/4" lift and used factory UCA? Curious as I'm eyeing this setup maybe in the future and was wondering how it performed with the factory UCA's. After running the factories what made you decide to go with aftermarket? Where there issues or are you trying to avoid future issues or failures?
  19. Jun 5, 2018 at 7:43 AM
    #79
    I have the 614 coils. The OME setup is very popular and reasonably priced. Way better than OEM shocks.I still want to upgrade to the SPC's but quite frankly the OEM UCA's are working out quite well for now. I don't expect any failures at all, I just want to take advantage of the adjustability of the SPCs for best alignment.
  20. Jun 5, 2018 at 7:47 AM
    #80
    Rngr188
    Chad
    Harrison AR
    2017 CM, 5.7 with no extra front weight I should go with the 612 correct? Should that be 2.5" as stated on ToyTec's website or would I get a little more? Would the 614 and no bumper put me close to 3" where UCA's would be needed?
  21. Jun 5, 2018 at 8:54 AM
    #81
    chphilo
    chphilo Tundra addict
    Western PA
    It seems that most people get closer to 3 inches with 612.
    Some vendors list 614 as the coils for 5.7 Tundras without any heavy bumper. I think you could go either way. 614 will give you roughly 1/2 inches more height. The ride is firm, but still very good, imo, with 614.
    With 614, you probably will need a set of aftermarket UCAs though. Some people get away with the stock UCAs, but I just went ahead and got a set of SPC UCAs. With 612, you could probably just use the stock UCAs.
  22. Jun 5, 2018 at 8:58 AM
    #82
    Rngr188
    Chad
    Harrison AR
    Thanks! Whish I could afford the new BP-51 kit :drool::drool:
  23. Jun 5, 2018 at 9:12 AM
    #83
    The 614s are the HD rated for the 4.6L. After trying them out off road a few times with my new winch bumper setup there is no need to go to the 613s. I'm less than 200lbs added weight. The ride is perfect. My stock UCAs aren't bottoming out on my coils but I do want to take advantage of the additional clearance with the SPCs.
  24. Jul 26, 2018 at 10:09 PM
    #84
    Kmaiboy
    Kmaiboy New Member
    2018 White TRD Sport CM
    Just curious how much are OME 612?
  25. Jul 26, 2018 at 10:27 PM
    #85
    lackeycc
    lackeycc New Member
    Cody
    Louisiana
    2015 TUNDRA CM SR5
    S&B CAI Raptor lights OME 612 Cooper STT PRO 295/60R20 5% Tint Husky Liners Rigid D2 Fogs on OEM Switch
    I bought mine less than a month ago had them assembled with a diff drop for $700.05 to my door.
  26. Jul 26, 2018 at 10:29 PM
    #86
    lackeycc
    lackeycc New Member
    Cody
    Louisiana
    2015 TUNDRA CM SR5
  27. Jul 26, 2018 at 10:46 PM
    #87
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Been on mine for a month or so. I don’t know what the springs alone cost. But my front and rear kit with UCa’s was $2200usd. I like it so far. I am wondering though, if anyone has heard spring creaking from the front coilovers? It seems to do it when I’m turning at full lock.
    lackeycc likes this.
  28. Jul 26, 2018 at 10:47 PM
    #88
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Looks awesome
    lackeycc[QUOTED] likes this.
  29. Jul 27, 2018 at 2:56 AM
    #89
    lackeycc
    lackeycc New Member
    Cody
    Louisiana
    2015 TUNDRA CM SR5
    Appreciate that! I haven’t heard any creaking in mine at all. What’s odd is I had a cream from the rear pre lift. Now it’s gone magically.
  30. Jul 27, 2018 at 8:06 AM
    #90
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Maybe it’s just settling in noise at first?
