Old man emu lift?
Discussion in 'Suspension' started by Tundra1794E, Jan 24, 2018.
  1. Apr 26, 2021 at 8:46 AM
    #421
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    looks great, even with stock tires.
    JungleFev3r[QUOTED] likes this.
  2. Apr 26, 2021 at 10:15 AM
    #422
    Treemite
    Treemite New Member
    AZ
    @Skeezo Thanks, yeah I'm still running the stock control arms, probably 30k miles now and no issues, I do plan to replace them soon with spc or similar.
    300BLK and Skeezo like this.
  3. Apr 26, 2021 at 11:39 AM
    #423
    Skeezo
    Skeezo New Member
    WHITE 2019 TRD OFF ROAD
    I just installed the 612's a couple day's ago right after I was done I took it to get an alignment but it's not perfect and pulling to the right as well. Decided to order UCA's because I feel it is very necessary
  4. May 6, 2021 at 7:43 PM
    #424
    Bikewrench
    Bikewrench New Member
    2012 Super White Double Cab 4x4
    OME 614s/Dakar packs SPC arms Fab Fours Red Steel Bumper Rough Country 12k winch 35x12.50 17 Toyo r/t Method Race Standards HMF bed rack w/ Smittybilt Overlander XL RTT TRD exhaust
    I’m running 614s w/ SPC arms in the front and Dakar packs w/ Bilstein 5160s & 2” shackles in the rear. There is a huge RTT in the back on a steel bed rack. Just added a Fab Fours bumper & 12k winch last weekend. My front measures 25” driver & 25.5” passenger. It dropped 1/2” on both sides w/ the addition of the ~220lbs of bumper/winch.
  5. May 7, 2021 at 1:44 PM
    #425
    Skeezo
    Skeezo New Member
    Installed UCA's and got an alignment. Everything feels Good until I drive at 70mph. Getting some serious vibration.
    Mountun Goat likes this.
  6. May 7, 2021 at 2:00 PM
    #426
    frichco228
    did you do rear carrier and front diff drop? OME runs high so you probably need them.
    Mountun Goat and HulkSmurf14 like this.
  7. May 7, 2021 at 2:02 PM
    #427
    Skeezo
    Skeezo New Member
    Did diff drop. Waiting on the carrier I'm the mail
  8. May 8, 2021 at 1:26 PM
    #428
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Soon to be 4WC Raven host. Mods to come.
    @Bikewrench Looks great. What is your tire size?
  9. May 8, 2021 at 2:04 PM
    #429
    Bikewrench
    35x12.50 17
  10. May 9, 2021 at 10:01 AM
    #430
    JungleFev3r
    JungleFev3r New Member
    2020 MGM Tundra TRD
    What were the final numbers for the new alignment with new UCAs?
  11. May 11, 2021 at 10:12 AM
    #431
    406Michael
    406Michael New Member
    2014 Limited CM
    Beautiful rig!:eek2::eek: I am looking at going with that same tire and size, what did you think? Why are you changing? I am also going with the C4 bumper
    CorsoTundra[QUOTED] likes this.
  12. May 11, 2021 at 11:35 AM
    #432
    CorsoTundra
    CorsoTundra This is the way
    North GA
    2021 Cement Trail Edition
    Toytec Aluma 3/1.5, Pro headlights, OEM LED fog lights, AJT chrome delete, interior/exterior LEDs, front TRD sway, 18x9 Method Roosts, 285/75/18 Toyo A/T 3, RCI engine skid,
    Probably gonna keep the setup I've got and just do the Toytec progressive leaf pack for the back, drop the Toytec shackle down to the 1" and crank up the front maybe 1/4". My GFC has a build date of August so, I've got some time to decide.
    I like the Duratracs, but may switch out to the new Mickey Thompson Baja Boss A/T's in 305/70/18, when my local Discount has them available.
    406Michael[QUOTED] likes this.
  13. May 12, 2021 at 7:25 AM
    #433
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Alright folks. The incessant squeaking from my Dakar leafs is killing me. I replaced the shackles with the greasable OMEs, and the bushing squeak is now gone but the leafs themselves are making noise.
    Have any of you solved this?
    Thoughts on me adding the overload spring so the leafs don’t compress as much during everyday driving?
    I really want to fix this rather than do something drastic like buy new Alcans.
    Groged67 and Mountun Goat like this.
  14. May 12, 2021 at 7:37 AM
    #434
    taytor
    taytor New Member
    2019 Crewmax SR5
    Any one with the OME greaseable shackles and a 295/70-18 or larger spare tire in stock location?
    Do the OME shackles rub on the tire? Clearance?
  15. May 12, 2021 at 7:38 AM
    #435
    Squatting Pigeon
    Holden
    North Texas
    I don’t have a larger spare than stock, but I will say the OME shackles are fairly low profile. Nowhere near as wide as some of the other aftermarket ones out there.
    t-bear and Mountun Goat like this.
  16. May 16, 2021 at 7:04 AM
    #436
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Dang hey. I’m one of the weird ones that doesn’t have leaf squeaks. You try fluid film or anything like that?
  17. May 16, 2021 at 7:17 AM
    #437
    Squatting Pigeon
    Holden
    North Texas
    I’ve tried a few different silicone lubricants, graphite, Wd-40, retorquing everything, and no change.
    I haven’t tried fluid film yet, but that would be less expensive than new leafs :rofl:
    Mountun Goat[QUOTED] likes this.
  18. May 16, 2021 at 7:24 AM
    #438
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    :notsure::notsure::notsure:
    Can't remember where I read it - perhaps straight from ARB? To use marine grease between each leaf? When I eventually get this kit I will be adding the D28XL add a leaf - so I'm gonna try the marine grease while I have the packs disassembled.
    Now whether marine grease is fundamentally different than what you choose, I dunno?
  19. May 16, 2021 at 7:24 AM
    #439
    frichco228
    Can you post a few more pics and different angles with the stock rims/tires and lift?
  20. May 16, 2021 at 7:25 AM
    #440
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I wonder if you jacked up the frame and let the axle droop fully if blowing compressed air through the leaf cracks then greasing would help?
  21. May 16, 2021 at 7:31 AM
    #441
    Squatting Pigeon
    Holden
    North Texas
    I really don’t wanna take these things out again, and then to take them apart is another layer of fun added on :bananadead:
    If I do that, I’ll be adding the overload leaf for sure. Maybe I’ll try it, I just worry about the grease needing to be reapplied over time, and just how often.
  22. May 16, 2021 at 7:33 AM
    #442
    Squatting Pigeon
    Holden
    North Texas
    Fingers crossed that will work, because I just had them out putting the shackles on and I’m not a fan of removing them. Lol
    I might jack up the frame, pressure wash between the leafs and let it dry. Then add grease where I can, and fluid film it all after for good measure.
  23. May 16, 2021 at 7:41 AM
    #443
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Let us know how it turns out :fingerscrossed:
  24. May 16, 2021 at 12:19 PM
    #444
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Did your guys OME kits come with the greaseable shackles? I see conflicting pictures (most without) and parts lists (with them listed as included).
  25. May 16, 2021 at 1:30 PM
    #445
    Squatting Pigeon
    Holden
    North Texas
    No they’re an add on from most suppliers
  26. May 16, 2021 at 2:35 PM
    #446
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    OK thanks. I thought that extra almost $200 squeeze was too tempting for them. LOL.
  27. May 16, 2021 at 6:05 PM
    #447
    taytor
    taytor New Member
    2019 Crewmax SR5
  28. May 16, 2021 at 7:12 PM
    #448
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles. Dirty Deeds standard 10 exhaust. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5.
    I have the icon AAL on mine and they were squeaking crazy. I would press down on the tailgate and it would squeak. So I parked the truck over the curb in front of my house opposite side of the squeak. Pressed down on the tailgate and squeak was gone. What this did was extend the leafs so they weren’t rubbing metal on metal and that told me that’s where the squeak was. Used some Lucas red tacky spray grease in between the leaf springs where there was space and now squeak is gone. Good luck.
  29. May 18, 2021 at 12:03 PM
    #449
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    Got the 3" OME 612s + Dakars + Add-A-Leaf and SPC UCAs installed over the weekend. Truck drives SOOOO much better, nice and planted, no body roll in the corners. Need to take some measurements and see how much it came up, eyeballed, it looks more than 3", so I'm curious how it will settle...
    Before:
    After:
    Mountun Goat and 406Michael like this.
  30. May 18, 2021 at 12:31 PM
    #450
    taytor
    taytor New Member
    2019 Crewmax SR5
    That came out nice. What size wheels/tires?
