Old man emu lift?
Discussion in 'Suspension' started by Tundra1794E, Jan 24, 2018.
  1. Feb 2, 2021 at 3:21 PM
    #331
    Dank
    Dank New Member
    2010 Black Tundra 4wd
    Both LF & RF are 24 1/2. Both RR & LR are 27 1/4. The rear is measured with 200-250 lbs in the bed. When I initially measured it empty it was 5/8’s in higher. Also, I have the metal RCI skid plates front, mid and gas tank. That adds a few pounds and may affect the height a bit.
    Took it out today with the wife for a shake-down. City/highway streets, county roads, gravel/dirt roads with plenty of washboards and rocky forest roads with 2-4 in rocks in/on road. Must say that the ride has immensely improved from before. Wife did not complain at all and did not mind the ride. Truck felt more planted on the roads and was not thrown around as much. Could feel the bumps but they were more muted. Felt like I was in more control of the truck!
    Guess I needed the new suspension for quite awhile! Almost 127k miles with 1 1/2 - 2 in blocks/spacers and original suspension. Will have to see how it is with towing a 7k travel trailer now.
    Also, looking at new tires. Will buy the same BFG KO2 but might go up to 35’s. Currently LT275/70r18. Undecided yet since I use it for a lot of towing.
  2. Feb 2, 2021 at 3:24 PM
    #332
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    Thanks!
    I tried the same 613 coils & it lifted my truck 4.5". I swapped to the 614 springs & it lifted it 4". I guess my truck is just an anomaly. I have an ARB bumper & 10K winch w/steel cable so my weight should be the same as yours or maybe even heavier. My suspension has about 2,500 miles on it so it's settled. Mine measures 25.5" DS & 25 7/8 PS now.
    Dank likes this.
  3. Feb 2, 2021 at 3:29 PM
    #333
    Dank
    Dank New Member
    Maybe yours is a bit higher if you are not running skid plates and side steps. Just a thought.
    joseph_womack likes this.
  4. Feb 3, 2021 at 6:16 AM
    #334
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    looks great, even with that size tire. I run OME on my 4runner and when it is time to lift the Tundra OME and Dobinsons are the two I am looking at. How does it feel running those stock UCAs?
    Think hard before you install 35s with the towing you plan to do. You may be happier with 34s.
    Dank[QUOTED] and HulkSmurf14 like this.
  5. Feb 3, 2021 at 2:58 PM
    #335
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    I have no problem towing w/ my OME set and 35" tires.
    O.S.T.
    joseph_womack and Dank like this.
  6. Feb 3, 2021 at 3:00 PM
    #336
    Dank
    Dank New Member
    Had that discussion with Desert Rat about UCAs. They said stock should be fine with what is being installed unless they are worn out. I do not plan on any serious rock climbing off-roading with my Tundra. We use it mostly for towing and plenty of forest roads. No over-landing. Too big of a vehicle for that.
    Also, leaning towards just keeping the same size tires. LT275/70r18 (33”). They might look a little small but work really well for towing, especially in the mountainous west. The last thing I want to do is to install gearing because I have too big of tires. Spent enough money already!
    Mountun Goat and joseph_womack like this.
  7. Feb 3, 2021 at 8:36 PM
    #337
    The Patriot 1776
    '16 TSS CM 4x4
    I don’t either. These trucks have 381HP so it’s not like towing with a Tacoma, which sucked ass.
    Mountun Goat likes this.
  8. Feb 4, 2021 at 8:30 AM
    #338
    frichco228
    Happy for you, but the person I responded to was planning to tow a 7000lb trailer. With a loaded truck and that trailer it will be about at limit for payload. I have done plenty of towing with 35 inch tires and lifted trucks and when you get up there close to capacity it is NO fun and hard on the truck. 35s look great and are fun but if you tow often and tow heavy they put a ton of stress on the steering, suspension, transmission (because the trans will be hunting). Just offering that person some advice based on experience.
    Dank, joseph_womack and Mountun Goat like this.
  9. Feb 9, 2021 at 7:38 AM
    #339
    Bareborn
    Bareborn New Member
    2020 Tundra Limited CM
    Recently got the OME 2.5" system from Boss Off-road. VERY happy with the look and ride. Going to take my time and upgrade the 31's to 33's but other than that very pleased on me 2020!
  10. Feb 9, 2021 at 9:01 AM
    #340
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    Awesome! post some pics of your set up.
  11. Feb 23, 2021 at 5:25 PM
    #341
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Anyone have issues with the finish on their shocks? These are my rear shocks after about 10k miles, lots of pitting with rust. Not too happy about it. I live on a dirt and gravel road but otherwise regular daily driving and weekend warrior off roading. My stock shocks didnt have any issues. I'm thinking of getting some shock covers.
  12. Feb 23, 2021 at 5:46 PM
    #342
    Dank
    Dank New Member
    Thanks for your reply and advice! I do plan to continue towing quite a bit so I think I will stay with the 33s. They seem to be a good balance of looks and abilities. Especially here in the west!
  13. Feb 23, 2021 at 7:24 PM
    #343
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Ya mine are crap too. I installed some 2” coolant hose over the rears for some protection. Fronts are pitted on mine too from road junk.
    Black Wolf likes this.
  14. Feb 23, 2021 at 7:30 PM
    #344
    My rear OME's on my 07 got the rock tick marks. Hard to avoid that when off road. I just bought Toytec Aluma's for my 14. The boots are on the bottom which makes a lot of sense. Rebuildable and only $90 more than the OME's. A no brainer for me.
  15. Feb 23, 2021 at 7:36 PM
    #345
    That's a good idea. The OME's are a very good shock.
    Mountun Goat[QUOTED] likes this.
  16. Feb 24, 2021 at 7:32 AM
    #346
    The Juice
    The Juice THE JUICE IS LOOSE !!
    COLORADO NATIVE
    2013 TUNDRA W/ ROCKET BOOSTERS
    FLUX CAPACITOR/ HOVERCRAFT CONVERSION
    How much total lift is the rear over the stock height? I'm only asking because I have the same rear shocks and am about to put on new leafs. I can choose my height with these leafs and want to make sure I don't over extend the rear OME Shocks! Which model Coils did you put on the front from OME 612/613/614's? Thanks! Your truck looks PERFECT!
  17. Feb 24, 2021 at 8:02 AM
    #347
    ckkone
    ckkone New Member
    SLC, UT
    Yes, its a truck no big deal.
    Black Wolf and The Juice like this.
  18. Feb 24, 2021 at 8:10 AM
    #348
    The Juice
    COLORADO NATIVE
    Just saw this post/ please ignore the other. I'm a huge fan of your build. Hands down one of the best Tundras I've seen on this forum IMHO.:101010::101010:
    Dank[QUOTED] likes this.
  19. Feb 24, 2021 at 9:58 AM
    #349
    MaxPower
    MaxPower New Member
    18 Tundra TRD Off road
    OME sells bolt on shock guards that will help with the pitting and rust issue. The part number is OME 661. I have bought them from Cruiser Outfitters in the past because they stock them.
  20. Mar 12, 2021 at 4:02 PM
    #350
    COTundra23
    COTundra23 New Member
    Anyone have pics with the 612 up front?
  21. Mar 12, 2021 at 4:14 PM
    #351
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
  22. Mar 12, 2021 at 4:17 PM
    #352
    RLHULK
    Rich
    2022 Silverado LT.
    Mine look like that, dont care, only things that see it are potential road kill and cat convertor thieves LOL
  23. Mar 12, 2021 at 4:57 PM
    #353
    COTundra23
    looks good!Dakar's in the rear?
  24. Mar 12, 2021 at 5:13 PM
    #354
    RLHULK
    Rich
    2022 Silverado LT.
    Stock leafs with Toytec adjustable shackles.
    Dakars will go in when its time to replace tho. If I keep it that long LOL
    COTundra23[QUOTED] likes this.
  25. Mar 14, 2021 at 11:07 AM
    #355
    COElkHunter
    COElkHunter New Member
    Jeremy
    2012 Silver Tundra TRD limited Crewmax 4x4
    3" OME lift w/ UCAs. ARE overland shell w/ ARE roof rack. 34" Falken Wildpeaks. ARB awning. Road shower. Wilco Offroad Hitchgate Solo High Clearance. LED lighting upgrades. Lockerdown console safe. Weathertech floormats. Duluth deluxe rear seat cover to go under the offroad approved car seats.... :P
    I have had the OME 2.5 heavy kit and add-a-leaf w/ SPC UCAs on a Tacoma, LOVED it! Way better than stock, no body roll in the mountains going around curves at 75mph. Beat the stuffing out of it for years and had zero issues. I also have the AHC delete heavy 2.5 kit sitting in the garage for my LX470, but the AHC hasn't failed yet, so I still haven't installed it... I also picked up the 3" w/ Dakkar leafs and 612 springs w/ SPC UCAs, and a Toytech diff and carrier bearing drop for my new Tundra. Just waiting for warm weather to install it. It's a good reliable system and doesn't break the bank. Local supplier I have used in Colorado is Slee Offroad. Great LC shop, I have been going there for years with my LX470.
  26. Mar 14, 2021 at 11:10 AM
    #356
    COTundra23
    sounds like we are in the same boat!
    I had Slee install the same kit on my Tacoma which is why I'm going the same
    Direction with my tundra!
  27. Mar 17, 2021 at 6:52 PM
    #357
    COTundra23
    Pics???
  28. Mar 18, 2021 at 11:47 AM
    #358
    sturdy
    sturdy New Member
    Paul
    2017 Tundra SR5 Black
    None
    Very new to suspensions in general. 2017 Tundra SR5 Crewmax.
    Adding an AT Overland Atlas topper in June (350 pounds), DIY drawers, dog crates = 700 pounds-ish steady state. Does anyone have that much weight on the OME 2.5in Heavy Load lift kit? Thoughts?
  29. Mar 18, 2021 at 1:39 PM
    #359
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome you with that first post..
  30. Mar 25, 2021 at 3:22 PM
    #360
    HuntTruck
    HuntTruck New Member
    How are the folks of the 613 gang faring these days?
