Old man emu lift?
Discussion in 'Suspension' started by Tundra1794E, Jan 24, 2018.
  1. Sep 18, 2020 at 11:37 AM
    #271
    DesertGorilla
    DesertGorilla New Member
    Eric
    Tucson
    12 CM SW 4x 35s
    17" Methods 35x12.5 BFG KO2 - OME 612 Kit Dakar Rears OME Shocks & Shackles. - Nitro 5.29s and Auburn LSD
    Agreed...but I went with 612s since I was sticking with the factory bumper (5.7) and no winch...but I seem to be higher than advertised, but with time and settling we'll see where I end up.
    HulkSmurf14 and Mountun Goat like this.
  2. Sep 18, 2020 at 12:07 PM
    #272
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Like my pants...they might start out at 33 waist, but when they're all used and "settled" they tend to lean closer to a 36 ;)
    RLHULK and Mountun Goat like this.
  3. Sep 18, 2020 at 12:20 PM
    #273
    0.S.T.
    0.S.T. New Member
    EAST COAST
    2007 BLACK TUNDRA 4X4 CREWMAX LIMITED 5.7 LITER
    For the money, You can't go wrong w/ OME & CoachBuilder about 4" total!
    Honestly, I am getting older and I didn't want to go any higher for both me & my wife.
    Even this guy stopped and asked about my set up w/ 35"x20s.
    But I think he nutz!
    :monocle: (w/o his top hat on)
    O.S.T.
    BigTaco, equin, betotundra and 2 others like this.
  4. Sep 22, 2020 at 4:15 PM
    #274
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    HELP!!!
    I’ve got the front coil overs installed and the front put all back together but there’s a pop sound, on each side, each time I bounce on the front bumper. Feels like it’s the UCA. Any ideas????
    The sound actually sounds like it’s coming from the just installed SPC UCA.
    Ideas?!?
    Mountun Goat likes this.
  5. Sep 22, 2020 at 6:27 PM
    #275
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I had a pop sound when I turned full lock only one way when I first installed. It went away after it settled. Could be a fluke. Or something worse. Have the shop inspect it when they do the wheel alignment?
  6. Sep 22, 2020 at 8:40 PM
    #276
    The Patriot 1776
    '16 TSS CM 4x4
    This happens sitting in the shop, no movement other than someone pushing up and down on the front bumper. I’ll ask the alignment guy but I've already done 90% of the alignment. Toe set close to zero, camber close to zero and caster at ~3.5. This has me stumped! I can hold the shock stub and not really feel the pop/bump but when I put my hand on the UCA I feel it pretty strongly. Odd.
    Mountun Goat[QUOTED] likes this.
  7. Sep 22, 2020 at 9:05 PM
    #277
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Is everything torqued to spec? Was it all torqued sitting on the ground and not on a lift/jack stands?
    Mountun Goat and DesertGorilla like this.
  8. Sep 23, 2020 at 7:16 AM
    #278
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Huh that is odd. Uca rubbing something maybe? Like @Squatting Pigeon said the torquing on ground maybe.
    It’s a major bummer getting an upgrade and finding an issue with it. Hopefully you figure it out ASAP :)
    Squatting Pigeon likes this.
  9. Sep 23, 2020 at 7:23 AM
    #279
    The Patriot 1776
    '16 TSS CM 4x4
    Torqued to spec, yes. I torqued everything on jack stands, as I've installed Literally dozens of lifts and the front being torqued on jack stands has never been an issue, but I re-torqued everything on the ground after this popping and it changed nothing.
    Thanks!
  10. Sep 23, 2020 at 7:36 AM
    #280
    Squatting Pigeon
    Holden
    North Texas
    Happy to (try and) help! :hattip:
    I have a pop on the front end of mine too but I think it’s the sway bar. I’m going to remove it and grease the bushings when/if I ever have time, and see if that does it.
  11. Sep 23, 2020 at 8:06 AM
    #281
    ckkone
    ckkone New Member
    SLC, UT
    Upper control arm ball joints are bad.
  12. Sep 23, 2020 at 8:35 AM
    #282
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Brand new spc’s? :monocle:
  13. Sep 23, 2020 at 9:20 AM
    #283
    The Patriot 1776
    '16 TSS CM 4x4
    That's what it sounded like but they're brand new.
    ***UPDATE***
    Took the truck for a short drive (~1 mile) & I couldn't get it to pop. Got back on the bumper and bounced the hell out of it & can't get it to pop again. Woohoo!!! I guess something was in a bind & it quickly worked itself out. Thanks for all the input fella's!
    Lift info:
    2613 front springs
    medium load rear Dakar full leaf packs w/greasable shackle kit
    Rock Auto SPC UCA's
    Rear OME fit kit
    Pre-lift measurements (w/ARB Summit & 10K winch installed = ~260lbs.):
    PS R 24.25"
    PS F 21.25"
    DS R 24.25"
    DS F 21.5"
    Post lift w/1 mile on the lift:
    PS R 27.25"
    PS F 26"
    DS R 26.75"
    DS F 26.125
    So far I got 4.75" on front & 2.75" on rear. It has a very, very little rake, which is what I wanted.
    I had one + rear spring, I put on DS, & one 0 spring, I put on passenger side. The kit came w/zero instructions but is pretty straight forward. I tried to do the no spring compressor method & there's no way in hell it was going to work w/the springs (2613). I had to take them to a shop to get the top hats installed & they installed the bottom coil bucket upside down, which I didn't notice until I got the entire PS front installed. I had to uninstall all that & take back to the shop, flip the bottom coil bucket & re-install. Total install time was ~11 hours but that includes eating lunch, going to shop twice (1hr), driving around trying to find a shop to do the coils (1hr.), trying to figure out the correct process of installing rear shackles (.5hr.), trying to do the no compressor method (1hr.). Every project I do on trucks takes more time than it really should!
    I maxed out lower cams for rear tire clearance (front cams all the way in & rear cams all the way out). UCA set to neutral 'D' position, which is actually +2° caster. I did a quick alignment which gave me roughly 0° on camber, 3.5° on caster & haven't messed w/toe yet. I'm taking it to a Toyota alignment guy today or Friday to dial it in exactly.
    GODZILLA, Mountun Goat, equin and 2 others like this.
  14. Sep 23, 2020 at 9:22 AM
    #284
    Squatting Pigeon
    Holden
    North Texas
  15. Sep 23, 2020 at 9:52 AM
    #285
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Nice to hear! (Or not to hear it anymore) I’m on 613’s as well- glad your noise went away like mine haha!
  16. Sep 23, 2020 at 3:38 PM
    #286
    DesertGorilla
    Eric
    Tucson
    12 CM SW 4x 35s
    Rock Auto carries SPC upper control arms? can you post a line to the item...I found what looks like spc but they are labeled MEVOTECH is the the same as spc if so that price is pretty great.
  17. Sep 23, 2020 at 3:39 PM
    #287
    Squatting Pigeon
    Holden
    North Texas
    Those are the ones!
    There's a thread on here somewhere all about it, Mevotech is the same as SPC for way less.
  18. Sep 23, 2020 at 3:45 PM
    #288
    DesertGorilla
    Eric
    Tucson
    12 CM SW 4x 35s
    I was just doing a side by side and the only difference i can see is that the spc is has a greaseable ball joint...I wonder if an spc ball joint could be add after a couple years of wear and tear.
  19. Sep 23, 2020 at 3:51 PM
    #289
    Squatting Pigeon
    Holden
    North Texas
    Scroll through this thread here: https://www.tundras.com/threads/mevotech-ucas-same-as-spc.60435/
    I think somewhere in there I recall seeing someone posted that they got greaseable ball joints on theirs*
    *but I could be wrong
  20. Sep 23, 2020 at 4:47 PM
    #290
    The Patriot 1776
    '16 TSS CM 4x4
    Mine came w/one greasable & one not. Make sure you add grease as there wasn't hardly any in the non-greasable unit.
    The ball joints say SPC on them.
  21. Sep 23, 2020 at 7:49 PM
    #291
    The Patriot 1776
    '16 TSS CM 4x4
    Pic of mine w/613’s, Toyo M/T 285/75R18 and Level 8 MK6 wheels. Btw, I have zero rubbing anywhere but haven’t wheeled it yet. Maxing out the cams worked great! IDK what more of y’all don’t do it. :monocle:
  22. Sep 23, 2020 at 7:51 PM
    #292
    DesertGorilla
    Eric
    Tucson
    12 CM SW 4x 35s
    OLD MAN EMU does the trick.
  23. Sep 23, 2020 at 8:31 PM
    #293
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Looks boss af. Can you explain the cams?
  24. Sep 23, 2020 at 8:55 PM
    #294
    The Patriot 1776
    '16 TSS CM 4x4
    If you have SPC UCA's, you can max the front alignment cams all the way in, max the rear ones all the way out. This moves the wheel/tire forward & outward giving you maximum space between the rear of the tire & rear of the fender/cab mount. Doing this & putting the SPC @ neutral/D position (which is actually +2° caster), you should get between 3.5-4° caster & can adjust the ball-joint in/out to get your camber dialed in. Since I have an aftermarket bumper, there's no issues in hitting anything in the front.
    I hope this is understandable! If not, feel free to ask any questions & I'll answer the best I can. I'll snap some pics of the room between the rear of the tire & rear of the fender tomorrow.
  25. Sep 23, 2020 at 9:00 PM
    #295
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Nice thanks, it makes sense. I’ll be interested to see a couple pictures of the cams to reference as well if your under there please:hattip:. I have the spc’s and arb Safari bumper so wouldn’t have frontward issue either. I’m really curious to see how mine are set as I had zero input on the alignment setup. Gunna have to see in the morning
  26. Sep 24, 2020 at 7:01 AM
    #296
    The Patriot 1776
    '16 TSS CM 4x4
    Here ya go! First pic is wheel turned all the way to the right. Next pic, wheel is straight.
    EE56E1A0-29AB-40A6-AE67-A2B54FA5E057.jpg DBF7523A-1E9B-4681-B668-2013675B397D.jpg
  27. Sep 24, 2020 at 7:12 AM
    #297
    The Patriot 1776
    '16 TSS CM 4x4
    DS front cam then DS rear cam:
    80C535F6-9B8D-4E6C-A04F-6BA0E81C913B.jpg A979B660-FF81-448C-A900-A8AA6115010F.jpg
  28. Sep 24, 2020 at 7:12 AM
    #298
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks, lots of room for flex :)
  29. Sep 24, 2020 at 7:14 AM
    #299
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    This is exactly what I thought you were explaining. Thanks for the pics. I’m gunna have a look at mine.
  30. Sep 24, 2020 at 7:19 AM
    #300
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Wow mine are damn near centered front and rear. This explains a lot for my truck. I’ll be adjusting those this weekend and looking for a new alignment. My 37s need all the room they can get! Thanks for this info!
    Edit, I just covered the cams in kroil, they look tight haha
