Oil pressure light
Discussion in '2nd Gen Tundras (2007-2013)' started by Alltime, Feb 11, 2025.
  1. Feb 11, 2025 at 5:48 PM
    Alltime
    Alltime [OP] New Member
    2010 Tundra 4x4
    TRD SC 3.5" lift 1.5" spacers 33's on Fuel 18's Drilled and slotted rotors w ceramics Rear anti sway Sequoia front anti sway
    Hi everyone, my "10 Tundra 5.7 with 91k started illuminating oil pressure light (the "!") while the gauge is reading normally.
    Always keep up on oil changes every 5k and she's topped off, so started with the pressure sending unit. O'Reilly's was the only place in stock and got it, though the reviews aren't good. Back to normal for a week and started (!) again. I started over with a dealer unit and no love.
    I sprayed some D5 on the contact still with no luck.
    Interwebs saying could be clogged pick up, bad filter, or failing pump, but those failures would read low pressure on the gauge i would think.
    Hoping I might gain some insight or ideas, thanks
  2. Feb 11, 2025 at 8:56 PM
    lr172
    lr172 New Member
    07 DC
    Need to do some research. Sometimes the idiot light is based on the primary op sensor with ecu turning on light at certain level. Other times they use a separate sender for the light. Have no idea how its done on tundra
  3. Feb 11, 2025 at 9:06 PM
    Alltime
    2010 Tundra 4x4
    I noticed there is a sending unit and a separate pressure switch. Possible that is the fault though nothing I have seen suggests that.
  4. Feb 12, 2025 at 5:50 AM
    lr172
    lr172 New Member
    07 DC
    OP gauge reading normal with warning light on is contrdictory; One of them has to be wrong. A brand new press sender along with the fact that they rarely indicate perfectly normal with low oil pressure should point you to the warning circuit.
  5. Feb 12, 2025 at 6:03 AM
    Alltime
    2010 Tundra 4x4
    As in, something wrong with the green wire or connector, correct? My next step will be removing the skid and having a friend monitor the light while I'm underneath.
    My big concern is doing damage to the engine, do you feel that as long as the gauge is reading normal I'm safe to drive? Thanks for your replies
  6. Feb 12, 2025 at 6:55 AM
    lr172
    lr172 New Member
    07 DC
    Hard to say if it is wiring, connector or the sender itself. typically a sender like this either opens or closes a set of contacts when the OP is above a set PSI. Should be easy to test with a meter. If it were my engine, I would not be concerned as the oil press gauge is behaving as it had for the last many thousands of miles. I would also confirm the other sender just to be sure, as there is a very small chance of an issue. I would confirm the the OP gauges moves as it used to at startup and coming off idle. If this is the case, very smal chance it is not accurate.
  7. Feb 12, 2025 at 9:24 AM
    Dr_Al
    Dr_Al New Member
    Al
    I would just get a cheap analog gauge and plumb it into the system. You can just leave it under the hood but it'll tell you exactly how much pressure you have. Then you will know if you are doing damage to the engine while you try to figure out what's not working right.
    Mdl likes this.
  8. Feb 12, 2025 at 2:21 PM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Never trust reviews. Check the wiring and use quality parts
