Oil pressure issue??
Discussion in '1st Gen Tundras (2000-2006)' started by Knielsen1981, Jan 5, 2019.
  1. Jan 5, 2019 at 2:44 PM
    Knielsen1981
    Knielsen1981 [OP] New Member
    Kelly
    2004 Toyota Tundra
    None
    Iv read a few of the older threads already but none seem to be the same issue. Mine use to start up and idle at 1/4 now on start up its at 1/2 and after 10mu s it settles but is still higher then normal. Any ideas? 04 tundra v8 thx
  2. Jan 5, 2019 at 3:56 PM
    15whtrd
    15whtrd Mr. Blonde
    Oil change recently?
  3. Jan 7, 2019 at 10:26 PM
    Knielsen1981
    Kelly
    2004 Toyota Tundra
    None
    That’s in the list of to-dos this weekend but it has since returned to normal....??
  4. Jan 7, 2019 at 10:31 PM
    15whtrd
    15whtrd Mr. Blonde
    I thought it might be possible if you had fresh oil that may give you a little better oil pressure or something wrong with the new filter.
  5. Jan 7, 2019 at 10:37 PM
    LML 3500HD
    Idle control valve could be faulty. I would first check if the throttle body (clean with throttle body/choke cleaner) is dirty and clean the MAF sensor (with MAF sensor cleaner) and this usually resolves most issues.
  6. Jan 7, 2019 at 10:37 PM
    Knielsen1981
    Kelly
    2004 Toyota Tundra
    None
    I think she (the truck) is going though menopause and is being a little extra in the drama department. Lol
    ColoradoTJ and 15whtrd[QUOTED] like this.
  7. Jan 7, 2019 at 10:39 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Might be time to retire her and update for a new PRO
