Oil Pressure "Gauge"
Discussion in '3rd Gen Tundras (2022+)' started by WasAChevy, Mar 12, 2022.
  1. Oct 25, 2023 at 5:25 AM
    nodak67
    nodak67 New Member
    JR
    funny part, alot of toyota dials sit in the middle cause most people freak out when they have a gauge with a center point. they think sitting in the middle is suppose to be norm instead of reading the dial for what its worth.
    i remember toyota dials being the old way and then people complained so much toyota went back to making dials read center.
    SnrDisregardo likes this.
  2. Oct 25, 2023 at 5:49 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    I'd say that's normal operation. I have a '18 and it does the same thing. Just below 1/2 when warm and idle, but increases the more load the engine is under.
  3. Oct 25, 2023 at 6:29 AM
    windblown101
    windblown101 New Member
    2019 CrewMax Limited
    The oil pump isn't impacted by load on the engine. It's mechanically driven and spins in direct relation to engine rpm. The oil pressure is simply a result of oil viscosity, pump flow, and resistance from moving thru the oil passages and bearing clearances.
  4. Oct 25, 2023 at 6:44 AM
    SnrDisregardo
    Wade
    IL
    I used "load" as more of a generic term. I had a feeling someone was going to point that out. lol.
