Oil pressure gauge with pic
Discussion in '1st Gen Tundras (2000-2006)' started by AZ59apacheguy, Apr 14, 2017.
  1. Apr 14, 2017 at 8:03 AM
    AZ59apacheguy
    AZ59apacheguy [OP] New Member
    Pete
    2003 SR5 TRD Tan
    Still a newbe and I know that the 1st gen Tundras read low oil pressure idle, but is this reading ok? This is with the engine up to temp and tranny in Drive, in Park, it reads slightly higher. Engine sounds and runs GREAT, 4.7L and 123,000 on the odo. Can other Tundra owners share their readings. IMG_0240.jpg
  2. Apr 14, 2017 at 8:31 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  3. Apr 14, 2017 at 8:35 AM
    csuviper
    Broomfield, CO
    @Mike might be able to help too
  4. Apr 14, 2017 at 8:36 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
    My '03 looked just like that, my '06 was a little closer to the middle.
  5. Apr 14, 2017 at 8:41 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You may be able to get an actual psi value to see if it's in the acceptable range. It's probably not going to be very high under the circumstance you describe. As mentioned, that's pretty usual.
  6. Apr 14, 2017 at 2:16 PM
    Mike Tread lightly.
    south carolina
    With that engine temp is normal... The 2uz-fe engine doesn't do alot of oil pressure on idle. The oil pressure switch is just that, a idiot switch gives you a rough idea not a (real value idea).
    If you want real value you have to change the switch and use a real meter for accuracy.
  7. Apr 14, 2017 at 3:12 PM
    AZ59apacheguy
    Pete
    2003 SR5 TRD Tan
    Hi everyone. Thanks for all the responses, definitley feel better about everything now. Just for the heck of it, I bought a new Toyota OEM oil pressure sender ( part# 83520-60051 ), we'll see if it changes anything. I think the one in there now is the original because it has an " 03 " stamped on it, the one I bought has a " 15 " stamped on it. Does Toyota date stamp their parts?
  8. Apr 15, 2017 at 4:36 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    This is from my Haynes manual, says at idle 4-5 psi. Chunk.
  9. Apr 15, 2017 at 6:49 PM
    Tundracollector
    Tundracollector New Member
    16 Dc trd pro, 04 Dc, 08 rcsb
    That's normal.
  10. Apr 16, 2017 at 6:23 AM
    Mike Tread lightly.
    south carolina
    The supplier might stamp the year on the part it was made. Rare that oil pressure units fail compared to oxygen sensors.
    NewImprovedRon likes this.
  11. Apr 17, 2017 at 8:05 AM
    AZ59apacheguy
    Pete
    2003 SR5 TRD Tan
    Thanks again for all the reply's
  12. Apr 17, 2017 at 9:47 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    Yes, that is normal on a first gen. My oil pressure gauge would drop even lower than that on hot days.
  13. Apr 17, 2017 at 4:53 PM
    AZ59apacheguy
    Pete
    2003 SR5 TRD Tan
    Thanks for the reply. So I got my new Oil Pressure Sender. I'm ready to put it in and was wondering if I need to put any thread sealler on the thread? Please get back as soon as possible, trucks up on the ramp as I'm writing this. Thanks!
  14. Apr 17, 2017 at 6:12 PM
    Mike Tread lightly.
    south carolina
    If there isn't a seal (o-ring) you must use tape... Make sure to torque the sensor to the proper setting.
  15. Apr 17, 2017 at 6:59 PM
    AZ59apacheguy
    Pete
    2003 SR5 TRD Tan
    Thanks fpr getting back. What is the proper torque spec?
  16. Apr 17, 2017 at 9:20 PM
    Mike Tread lightly.
    south carolina
    Get a Haynes manual to confirm the torque value you need.. don't quote me but it like 12 or 15 ft pounds?
  17. Apr 17, 2017 at 9:48 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    My 2000 ran just a little higher than that at idle and went close to the middle once the rpms were up. 186k and never had to change the sensor. The only time I ever had an oil pressure issue was when I put a non Toyota filter on it. The pressure was all over the place. In case you didn't know this, don't use anything other than the oem filters. They have a check valve to keep the dirty crap from going back into the pan as well as a pressure relief valve.
    Sampson likes this.
  18. Apr 18, 2017 at 8:43 AM
    AZ59apacheguy
    Pete
    2003 SR5 TRD Tan
    Hi, thanks for the response. I use nothing but Toyota filters in this truck. I found them to be cheaper online than going to the dealer.
  19. Mar 1, 2019 at 6:39 AM
    moose102
    moose102 New Member
    none
    I have an issue also. I used some heavier oil than normal but on the gauge it was high but fine. Some time recently it went way below low. So thinking it might be a blocked oil filter or something I change the oil and put in fresh 5w30. It made little difference. I then reeplaced my sender with an OEM as mine was rusty, thought it may be the issue, but it still is way below low but moves a bit when started ( but not even to the low mark ). Any ideas here?
  20. Mar 1, 2019 at 6:57 AM
    dryota
    dryota New Member
    dusty
    05 dc tundra
    following
    I have a buddy of mine has 01 same issue but never a problem I think they just run that low I think if that's the case Toyota should have made a lower pressure gauge to read high for peace of mind
  21. Mar 1, 2019 at 8:48 AM
    moose102
    moose102 New Member
    none
    Not just low, below low. It was working fine with good pressure. I beleive the heaver weigh oil I used screwed it up somehow. Like a spring sprung but I don't believe there are spring in the gauge.
  22. Mar 6, 2019 at 6:20 AM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    I think it’s pretty normal. My 2002 reads like that
  23. Apr 16, 2019 at 12:48 PM
    Need to know stuff
    Need to know stuff New Member
    2000 black Tundra TRD
    3 front 2 rear leveling
    Sorry if this has been taught or if u can't see what i wrote, but this is my understandin20190416_124836.jpg g
    Sampson likes this.
  24. Apr 16, 2019 at 1:08 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    The OP's gauge looks exactly what my 1997 T100 V6 with synthetic oil looks like at idle. Reeeeeeeeeeaally low. And has been NO problems for me.
  25. Apr 16, 2019 at 2:01 PM
    Aerindel
    Aerindel New Member
    Montana
    Exactly the same as my 2000
    Filthyphil likes this.
  26. Apr 16, 2019 at 2:21 PM
    Professional Hand Model
    Hand Protectors
    Looks normal for the 2002... except my ‘idle low’ never drops below where the needle is sitting in that pic (unless engine is turned off). My idle (no foot on gas) sits just as pictured. Never fluctuates off that spot.
    Is yours fluctuating?
  27. Apr 16, 2019 at 3:20 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Double thread revival! Yes, low is normal.
    abcinv likes this.
  28. Apr 17, 2019 at 7:34 AM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    I’m new to the Tundra. My first week saw low oil pressure.
    I replaced the oil pressure sender with a generic unit.
    It worked poorly.
    I reordered the factory sender AND a factory oil filter.
    Works perfect now.
    Not sure if it was the filter or sender.
    Either way, it’s perfect now.
  29. May 2, 2019 at 7:31 AM
    Gordon
    Gordon New Member
    So I too am new to my 2002 Tundra with 57K miles. My oil pressure gauge does not work and I am not getting an oil idiot light on the dash. Is there such a light or only a gauge?
  30. May 2, 2019 at 7:36 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Before you start the engine, you should see a red oil can lamp somewhere on the dash. It does that as a means for you to see that the lamp works. That's why all those lights illuminate prior to starting the engine.
