Oil Pressure concerns
Discussion in '1st Gen Tundras (2000-2006)' started by baldwin007, Apr 13, 2018.
  1. Apr 13, 2018 at 8:53 AM
    baldwin007
    baldwin007 [OP] New Member
    2003 V6 Tundra
    none
    Hi. As not to waste anyone's time, I tried reading previous posts on oil pressure issues but could not find the exact same issue... so I thought I would reach out for some advice. I have a 2003 V6 and noticed the oil pressure was fluctuating in reverse to what others had shown on the website. The issue I have is the oil pressure during the constant driving rpm of 2100 will slowly drop to just above the lowest mark and stay there. If I let off the throttle and coast at 60MPH, the pressure jumps up to above half way as normal. At idle, it stays about normal on the lower end. If I take it up to 3000 rpm, the oil goes up as normal to the mid/high part of the gauge. See the attached image to see where it sits at constant throttle
    Thanks in advance for any thoughts.
  2. Apr 13, 2018 at 9:37 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Could it also be the oil pump going bad?
    NewImprovedRon likes this.
  3. Apr 13, 2018 at 9:44 AM
    baldwin007
    2003 V6 Tundra
    none
    Thanks. Throwing no codes nor is it running any worse than normal .. yet
  4. Apr 13, 2018 at 9:45 AM
    nk1794
    San Jose, CA
    Yeah, they hardly ever failed but you never know.
  5. Apr 13, 2018 at 9:46 AM
    nk1794
    San Jose, CA
    Are you using the recommended oil weight?
  6. Apr 13, 2018 at 10:05 AM
    baldwin007
    2003 V6 Tundra
    none
    5-30 oil
  7. Apr 13, 2018 at 10:08 AM
    nk1794
    San Jose, CA
    When was the last time you change the oil and the filter? Bad filter, perhaps?
  8. Apr 13, 2018 at 11:36 AM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    The V6 and some early V8 engines had crappy oil sending units. There was a TS-B out on it.
    NewImprovedRon, ColoradoTJ and nk1794 like this.
  9. Apr 15, 2018 at 8:57 AM
    baldwin007
    2003 V6 Tundra
    none
    Thanks. Oil was changed about 800 miles back but the truck does not get driven much. It has 67000 miles from new but f that gives you an idea
    I bought a sensor and will put it in today to see if that does the trick.
    NewImprovedRon and nk1794 like this.
  10. Apr 15, 2018 at 11:22 AM
    nk1794
    San Jose, CA
    Let us know how it goes.
  11. Apr 15, 2018 at 6:58 PM
    baldwin007
    2003 V6 Tundra
    none
    Installed and it seems to have solved the issue (fingers crossed). Thank you all for helping!
  12. Apr 15, 2018 at 6:59 PM
    nk1794
    San Jose, CA
    Good job!
