Oil of Choice... Synthetic or Natural?
Discussion in 'General Tundra Discussion' started by 03Yoda4x, Apr 2, 2015.
  1. Apr 21, 2015 at 5:21 PM
    erm626
    erm626 New Member
    Ed
    Norfolk, VA
    2014 Whire Tundra Double Cab
    What are your thoughts of when to change the synthetic oil, in the Tundra ? The manual says 10,000 miles, I think they are nuts !
  2. Apr 21, 2015 at 5:31 PM
    5K is my rule.
    Mike and mdavis like this.
  3. Apr 21, 2015 at 5:32 PM
    Mike Tread lightly.
    south carolina
    Read 5 post back on this same thread ... ;)
  4. Apr 21, 2015 at 5:33 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    Yep. X2
    jfrd30 likes this.
  5. Apr 21, 2015 at 5:38 PM
    erm626
    erm626 New Member
    Ed
    Norfolk, VA
    Since our newer Tundra's already have synthetic oil, the break in that is being discussed is not happening. Unless we dump the oil and put in 7.4 qts of reg oil.....
  6. Apr 21, 2015 at 5:58 PM
    Mike Tread lightly.
    south carolina
    If you put dino oil in with a engine that already has synthetic, i have read many reports as the engine sees more wear and blow-by to do to difference in oil (synthetic vs dino) with rings and bearings or worst spun out bearings. If your engine is already running synthetic enjoy it man makes life alot more simpler.
    If you want my .02 if the engine has synthetic in it keep using it. If the engine is dino oil then use dino oil unless you want the advance of synthetic in the engine. I have seen where people switch back and forth but in the long run the engine failed over a period of time (YMMV).
    jfrd30 and erm626 like this.
  7. Apr 22, 2015 at 11:18 AM
    erm626
    erm626 New Member
    Ed
    Norfolk, VA
    Keep it simple and like you said enjoy !!
    jfrd30 likes this.
  8. Apr 22, 2015 at 11:46 AM
    Primo
    Primo White Tundra
    Primo
    San Antonio, Texas
    2016 SR Double Cab
    Level kit and TRD Pro Grill Installed.
    Been using Mobile 1 Full Synthetic since 75 thousand miles. I have 167,000 on it now.
    Saltyhero13 and jfrd30 like this.
  9. May 6, 2015 at 6:30 PM
    Dave333
    Dave333 New Member
    Dave
    2015 Platinum CrewMax
    Agree with Mike. Bought my Tacoma with 290 miles on it. Did a gradual switch to synthetic. At 190k I just changed my valve cover gaskets and everything looked brand new. I change it's oil anywhere from 7,500 to 15,000 miles depending on how long it's sat, how it's been driven, etc. Normally once a year I'll send a Blackstone sample out to check it. I know my 15 says 5,000 mile for synthetic but that defeats the purpose of synthetic.
    I'm running Amsoil OE 0W-20 and Amsoil 75W-90 in the rear. Stock Toyota oil filters. What I normally do is change the filter at 5,000 and then top off from the loss of oil from the filter. Been working so far.
    jfrd30 and dandailey like this.
