Oil leaking after jump
Discussion in 'General Tundra Discussion' started by Tundrahelp, Jul 18, 2021.
  1. Jul 18, 2021 at 3:20 PM
    #61
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Drive it really fast until the check engine light comes on.
    Sumo91, Baja Mike, T-Rex266 and 2 others like this.
  2. Jul 18, 2021 at 3:34 PM
    #62
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The oil in the pics looks like it might just be the mess they made at Sloppy Seconds Lube Shop (or wherever you took it) and never cleaned up. But who knows. Clean it all up, see what returns, and go from where.
    Or buy UV dye and a black light.
    This jump tho… Was it intentional? We need details bruh!
    ColoradoTJ, 15whtrd and Wallygator like this.
  3. Jul 18, 2021 at 3:47 PM
    #63
    Maybe it's the cam tower. :rolleyes:
    RainMan_PNW, Hightide, Fotnot and 4 others like this.
  4. Jul 18, 2021 at 3:55 PM
    #64
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    Have you checked the blinker fluid? :monocle:
    Joro43, 2mchfun and Wallygator like this.
  5. Jul 18, 2021 at 3:58 PM
    #65
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    He said the fluid have no scent…so I think it’s the windshield washer bottle
    Wallygator likes this.
  6. Jul 18, 2021 at 4:15 PM
    #66
    GatorBodine
    GatorBodine New Member
    This ^^
    I was gonna ask who did the oil change, some clown at quik lube? Probably spilled oil all over. But going airborne also throws the diagnosis for a loop.
    15whtrd likes this.
  7. Jul 18, 2021 at 4:18 PM
    #67
    Tundrahelp
    Tundrahelp [OP] New Member
    5100s front
    Steep train tracks too fast
  8. Jul 18, 2021 at 4:25 PM
    #68
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
  9. Jul 18, 2021 at 4:34 PM
    #69
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Wallygator, R65, 2mchfun and 3 others like this.
  10. Jul 18, 2021 at 4:41 PM
    #70
  11. Jul 18, 2021 at 4:43 PM
    #71
    Hightide
    Abalama
    Magic School Bus
    Do it in reverse, see if that fixes it.
  12. Jul 18, 2021 at 4:55 PM
    #72
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Seriously, I wonder if seal on the oil filter housing seated correctly and the leak after the jump is just coincidental. As in, "Oh shit, did I just f**k something up?" Start looking around and discover the oil leak that was already happening?
    Oil will likely run down and back due to gravity and air flow, thus coverage on pan wouldn't surprise me. Or, perhaps the jump somehow cracked the oil filter housing (or smashed drain plug).
    Good luck, OP. I'd be lying if I said I've never made a bad decision regarding the treatment of a vehicle. Hope any damage is minimal.
  13. Jul 18, 2021 at 5:19 PM
    #73
    waynescaggs
    waynescaggs No more of that .
    Wayne
    Idaho
    2019 tundra Crewmax Limited
    319A80C8-4A12-42FD-8C13-0ACD30945A24.jpgjumped my truck
    RainMan_PNW and Rodtheviking like this.
  14. Jul 18, 2021 at 6:01 PM
    #74
    Tundrahelp
    5100s front
    Thank you for the kind words. I’m hoping the oil leaking was coincidental. Dipstick still shows the correct amount and oil seems to be evaporating from the undercarriage. Will update later.
  15. Jul 18, 2021 at 6:17 PM
    #75
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  16. Jul 18, 2021 at 6:19 PM
    #76
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    The oil is evaporating? :monocle:
    JLS in WA, snivilous and 2mchfun like this.
  17. Jul 18, 2021 at 6:30 PM
    #77
    Tundrahelp
    5100s front
    Of the bottom the truck
  18. Jul 18, 2021 at 6:33 PM
    #78
    68vert
    68vert New Member
    AZ
    2011 Rock Warrior
    if I have to guess - I'll say your Tundra pee'd its pan after that jump.
    RainMan_PNW and Black@Blue19 like this.
  19. Jul 18, 2021 at 6:39 PM
    #79
    Gravy
    Yucaipa, California
    Well, you may have gotten lucky then. I can only think of 2 fluids in the engine bay that evaporate at a rate you'd be able to notice. Better check your coolant level, and don't worry 'bout your washer fluid...
  20. Jul 18, 2021 at 6:54 PM
    #80
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    Welcome back Elk hunter :hattip:
    RainMan_PNW, hagrid, T-Rex266 and 6 others like this.
  21. Jul 18, 2021 at 7:25 PM
    #81
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    0W20 does that. :crapstorm:
  22. Jul 18, 2021 at 7:48 PM
    #82
  23. Jul 18, 2021 at 8:07 PM
    #83
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I ramped my truck a couple weeks ago while on vacation, was drunk at the rental cabin, accidentally backed down the super steep slope while trying to re park the truck for some reason, so I just had to back up, get momentum, and send it! Bent my running boards pretty good, but all is well. Wish I had it on video, she still drives straight though :bananadead:
    Kgfit85 and Gravy like this.
  24. Jul 18, 2021 at 8:10 PM
    #84
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    A few things...
    You never mentioned what color it is. Does it have a sunroof or not?
    You said it got a new starter, did you see if it was full after the install?
    You never mentioned what kind of oil was leaking and where. Shock oil? Tranny oil? Engine oil? Rear differential oil? Front differential oil? Middle differential oil? Door hinge oil? Muffler bearing oil? Hydrosolator oil?
    How high off the ground did you get it? Are we talking Xgames height here?
  25. Jul 18, 2021 at 9:02 PM
    #85
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    :rofl::rofl:
    Just WTF should his starter be full of? High speed electrons? :D
    RainMan_PNW likes this.
  26. Jul 18, 2021 at 9:05 PM
    #86
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Obviously hydrosolator oil, please don't add confusing comments to this thread
    Gravy, Wallygator, dgtulsaguy and 4 others like this.
  27. Jul 18, 2021 at 9:08 PM
    #87
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Well, doh. My bad.
    Wallygator, R65 and Black@Blue19 like this.
  28. Jul 18, 2021 at 10:27 PM
    #88
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Not sure on the source of the oil leak, but I do love all the custom bronze accents under the truck.
    Does that come in a kit or did you install all that bronze stuff separately?
  29. Jul 19, 2021 at 12:09 AM
    #89
    Tundrahelp
    5100s front
    Just watched this starter replacement video. If you skip to 8:20, you will see he needs to move the axle away from the front differential which causes the oil to leak. Is there a possibility this is the cause of my oily mess? https://youtu.be/Rlx6MGuh9iU
    Barrett50 likes this.
  30. Jul 19, 2021 at 11:44 AM
    #90
    Saltyhero13
    Saltyhero13 Throbbing Member
    "Hydraulic lines cut from incoming fire!"....
    OOPS...wrong thread.
