Oil Leak
Discussion in 'Performance and Tuning' started by AlexWV, Mar 3, 2018.
  1. Mar 3, 2018 at 11:43 AM
    AlexWV
    AlexWV [OP] Trophy Husband
    Alex
    WV
    2014 White SR5 TRD CrewMax
    ARE CX Series shell Rhino Rack cargo basket Leveling Kit 35x12.5 Thunderer TracGrip tires Rough Country 30" light bar
    8F0A3C90-14B9-46F2-A2A2-3AB405768B04.jpg I noticed some oil spots in my driveway and climbed under the truck to find the skid plate soaked. I peaked through and this is the source. Is the cap missing completely or is that how it looks and it’s just leaking. Had my oil changed just a few weeks ago. Just wanted some info before I go back to the place that changed the oil and let them have it.
  2. Mar 3, 2018 at 11:45 AM
    I would say they screwed up the o rings or not in the correct place.
  3. Mar 3, 2018 at 11:47 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Yeah that looks like the inner o ring is either missing or damaged
  4. Mar 3, 2018 at 11:49 AM
    AlexWV
    Alex
    WV
    I’m not seeing any oil on the dipstick. Think it is still safe to take the 5 miles or so to the place?
  5. Mar 3, 2018 at 11:50 AM
    ninjajay
    Spoolston, TX
    Definitely would not recommend it... Can you do an oil change at home?
    Prostar 190 likes this.
  6. Mar 3, 2018 at 11:53 AM
    AlexWV
    Alex
    WV
    Could just add some, but I want them to have to fix the problem they caused. Oil change costs a ton in this to be done wrong
  7. Mar 3, 2018 at 11:56 AM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Add oil, then take it to them. Raise Hell.
  8. Mar 3, 2018 at 11:58 AM
    No way would I drive it if you can't see oil on the dipstick.
  9. Mar 3, 2018 at 12:06 PM
    AlexWV
    Alex
    WV
    Called the place. They’re sending out a mechanic to my house to add the oil and check it out.
    mudslinger79 likes this.
  10. Mar 3, 2018 at 12:10 PM
    proachman
    proachman New Member
    Reno Nv
    2017 Tundra Platinum 4x4
    4" Fab-Tech lift with dirt logic coil overs in front and shocks in rear, 20" Raceline Wheels, TOYO AT 295/65 R20, TRD Dual exhaust, K&N 77 Series CAI, 2018 Platinum Grille, 100% LED Lighting, Spray-in Bed Liner, Tri-Fold Tonneau Hard Cover, Color matched handles and mirror caps, Ceramic window tint on all 7 windows, TRD Shift knob, Nerf Bars, Driver side grab handle, Clear bra on entire front end.
    that's good service... I hope it works out...
  11. Mar 3, 2018 at 12:18 PM
    15whtrd
    15whtrd Mr. Blonde
    Depending on how much oil was lost it could’ve shortened the life of the engine now. Tell them you want them to pay for an extended powertrain platinum warranty. 100,000 miles or 10 years.
    SouthBoundSteve and mudslinger79 like this.
  12. Mar 3, 2018 at 1:57 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Let us know what happened.
  13. Mar 3, 2018 at 2:06 PM
    AlexWV
    Alex
    WV
    They came out and checked it and added oil. I drove it to the shop and they changed it, the filter, and all free of charge. They said they’ve had some trouble with different gaskets, and they used a different brand one this time. Just said to keep an eye out for it to make sure this one does ok
  14. Mar 3, 2018 at 2:08 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Lame. They would be cleaning my entire under carriage. And if you truly didn’t have oil on the dip stick they would be giving me some kind of warranty. This wasn’t a Toyota dealer?
  15. Mar 3, 2018 at 2:08 PM
    AlexWV
    Alex
    WV
    Man, you’re making me nervous with all that. They said there didn’t appear to be any filings or anything to worry about in it. Of course they should say that I’m sure too, but they seemed like honest guys to me.
    15whtrd[QUOTED] likes this.
  16. Mar 3, 2018 at 2:10 PM
    AlexWV
    Alex
    WV
    They did clean up the skid plate for me. And no, it is not a Toyota dealer. There isn’t one in my town, and this was the easiest place for me to get it done with my hectic schedule
    BTBAKER[QUOTED] likes this.
  17. Mar 3, 2018 at 2:20 PM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    how much oil did they have to add? only takes about 1.5 -2 quarts low to not show on dip stick. so you could still have 6 quarts in engine which wouldn't cause any damage in short time like that. just trying to help ease your mind.
    landphil and BTBAKER like this.
  18. Mar 3, 2018 at 2:22 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Had the same issue went to another dealership and tech said they never put the o ring in properly.
    BTBAKER likes this.
  19. Mar 3, 2018 at 3:37 PM
    AlexWV
    Alex
    WV
    I didn’t ask. Maybe I shouldn’t...
  20. Mar 3, 2018 at 3:51 PM
    RonW
    RonW New Member
    Oh man, you just need some slick 50 and then you don' even need oil. You guys remember those infomercials?
    Since you caught it before any warnings went off I'd say it is probably ok. I'm sure if it got to a dangerous level there would be some sort of light. Right?
    darkknight2014 and Upgrayedd like this.
  21. Mar 3, 2018 at 4:28 PM
    AlexWV
    Alex
    WV
    I can tell you this. He had one jug with him when he came to check on it. He added just a little bit and pulled the dipstick and it was on there then. They changed the oil completely at the shop and didn’t seem concerned.
  22. Mar 3, 2018 at 4:28 PM
    AlexWV
    Alex
    WV
    That’s what I was thinking.
  23. Mar 3, 2018 at 4:32 PM
    Upgrayedd
    Upgrayedd Toyotaholic
    Josh
    Northern Virginia
    2015 DC MGM SR5 4x4
    Jiffy Lube strikes again.
  24. Mar 3, 2018 at 6:34 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I’m sure you are fine but if this was some quick lube place I would HIGHLY recommend you find a reputable place or do it yourself. I will drive wherever it takes to know my truck is being taken care of correctly. The crackheads and stoners at the quick lubes will never touch any of my family vehicles..
  25. Mar 4, 2018 at 12:00 PM
    AlexWV
    Alex
    WV
    I was pleased the way they took care of it yesterday, but have come across another slight issue and think I’m fine with the place. When the re-installed the skid plate, they did not re-attach the front bumper valence with the bolts. Ugh. Should it go over or under the skid plate?
  26. Mar 4, 2018 at 12:36 PM
    ninjajay
    Spoolston, TX
    The tabs from the bumper go under the skid
  27. Mar 4, 2018 at 1:01 PM
    AlexWV
    Alex
    WV
    Great...here’s how they left it... I was going to unscrew the bolts and fix it but they appear to be missing completely.C70D1885-8C2F-4032-8220-BFBA5114D8DF.jpg
  28. Mar 4, 2018 at 1:06 PM
    AlexWV
    Alex
    WV
    Anybody know what size bolts and washers I need to just attach it myself, so I don’t have to deal with them any more?
  29. Mar 4, 2018 at 1:09 PM
    15whtrd
    15whtrd Mr. Blonde
    The plastic retainer clips that the screws screw into a really cheap at the dealer. Mine were stripped from the factory. I’m sure the screws won’t be much more.
