Oil Leak
Discussion in 'General Tundra Discussion' started by tacomawv, Jan 25, 2018.
  1. Jan 25, 2018 at 6:13 AM
    tacomawv
    tacomawv [OP] New Member
    Richard
    After looking at a Lexus GX460 for the wife and finding one with a major oil leak i took a good look under my Tundra. I found a small damp looking spot on the transmission pan. No drips. I will post a pic later. At work and the truck is at home. The question is when is it a problem. The truck is a 14 with 32000 ish miles on it. Is this something that can be fixed under warranty.
    ColoradoTJ likes this.
  2. Jan 25, 2018 at 6:24 AM
    I had no leaks at 89k miles. My cam tower seal started weeping a bit.
    Dealership as soon as you can. Oil leaks never get better.
    Let us know if it is engine oil, transmission fluid, or coolant.
  3. Jan 25, 2018 at 6:29 AM
    tacomawv
    Richard
    Had a pic.
  4. Jan 25, 2018 at 6:32 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Hard to be certain but that doesn't look like oil to me.
    joonbug, Wynnded and kenomouth64 like this.
  5. Jan 25, 2018 at 7:59 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    I am not sure why but that looks like coolant to me. However I am not sure where this leak is at in relation to the rest of the truck so it is hard to say.
    831Tun and 15whtrd like this.
  6. Jan 25, 2018 at 8:21 AM
    FISHLIPWASHINTON
    FISHLIPWASHINTON New Member
    2007 CM
    2007 CM 4X4 ALPINE EQ BACKUP LIGHTS LED JL 1000/1MONO BLOCK. 2 10IN JL 450/4 MIDS & HIGHS FOX COILOVERS & BILSTEIN REARS DEZ'S SABM MAGNAFLOW 7031 PROCOMP 35x12.50x18 AMG Battery BUSHWACKER PAINTED FENDER FLARES
    Coolant leak from weeping hole time to change waterpump and timing belt
  7. Jan 25, 2018 at 8:46 AM
    No timing belt on a 14 Tundra.
    Wynnded and 15whtrd like this.
  8. Jan 25, 2018 at 8:56 AM
    FISHLIPWASHINTON
    2007 CM
    Correct !!! Serpentine belt change
    TundraTss and ColoradoTJ like this.
  9. Jan 25, 2018 at 9:51 AM
    tacomawv
    Richard
    The black pan is the transmission pan. The leak is on the front side. Taking it to the dealer tomorrow. I am going to look at it better when in get home.
    kenomouth64 and ColoradoTJ like this.
  10. Jan 25, 2018 at 11:29 AM
    tacomawv
    Richard
    I drop the truck off tomorrow if they have the gasket. One one small melt down there. Not bad for me. Something about charging 100 bucks to look at it. I am sure they hate me.
    15whtrd and ColoradoTJ like this.
  11. Jan 26, 2018 at 4:30 PM
    tacomawv
    Richard
    Got the truck back today. Invoice says one gasket and 6 quarts of ATF. Hope its fixed.
    kenomouth64 and ldale like this.
