Oil leak
Discussion in '2nd Gen Tundras (2007-2013)' started by Nickw007, Aug 3, 2022.
  1. Aug 3, 2022 at 9:35 PM
    Nickw007
    Nickw007 [OP] New Member
    Hi
    does any one know if you can remove oil filter without draining oil pan from 5.7 tundra ?
    just changed oil but have leak from
    Filter, need to remove filter cap to change o ring
    any tips on how to remove cap is greatly appreciated
    The housing itself comes out fine but the grey cap is jammed to the housing
  2. Aug 4, 2022 at 10:26 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    If you mean the cap at the bottom of the housing?? You will need to tighten the plastic housing and try to jerk the cap loose. if the housing turns with the cap then lightly overtighten the housing.. then go back to the cap and try to loosen the cap by tappinh the ratchet handle for leverage.. If I'm understanding what you're saying...
    If you're talking about the cap the turns the housing you may need to tap it from all sides with the handle of the ratchet, atleast this how I've done it over the years..
    I've had to check the o-ring 2 weeks ago and I drained the filter rolled it down just enough to check and retightened it when I made sure I had replaced it.. added half a quart after and checked over the next couple of days.
    Hope this helps some.
  3. Aug 4, 2022 at 11:47 AM
    Nickw007
    Thanks a bunch for that info!
    I was able to get the cap of the housing holding the housing down as hard as I could with an oil filter wrench and the highest setting in 3/8th impact wrench and it broke free
    it was way to over tightened last time
    But anyways after breaking it free and putting in new o rings I still have the same leak that seems to be from the cap
    I’ve pulled the damn filter housing out 3 times now pitting new o rings and it leaked each time
    the housing and cap looks fine I don’t see any cracks where the oil could leak from
    But I’m probably just gonna order an aluminum housing ok Amazon for 20 bucks and put that in and see if the leak stops
    Probably the easiest/cheapest thing to do
  4. Aug 4, 2022 at 11:57 AM
    EmergencyMaximum
    EmergencyMaximum Synthetic member
    Maybe you're putting o-ring in the wrong thread. There's a channel that is made for the o-ring. You really shouldn't even tighten the housing a lot because o-ring does all the leak proofing.
    Do you have a hairline crack somewhere from previous frightening? It could've been damaged by heavy hand last time.
    MoneyMan55 likes this.
  5. Aug 4, 2022 at 12:08 PM
    Nickw007
    Yeah I’ve tried 3 different o rings and made sure they were in the channel desjunges for them
    they definitely weren’t on the wrong thread cause I just pulled it out 3 times and checked but it must be a very small crack I can’t see or something
    For only 13 bucks I’ll get a aluminum one on Amazon and see if the leaks stop and then I’ll know if this plastic housing currently on it is bad
    I’m thinking it must that since I didn’t have this issue the past few times I changed the oil
    I’ll update here in 2 days once bezos delivers the new filter housing
    EmergencyMaximum likes this.
  6. Aug 4, 2022 at 12:28 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    I would highly recommend buying the OEM Toyota housing instead of a cheaper aftermarket one, it might save you from having the same problem. Good luck.
    Nickw007[QUOTED][OP] likes this.
  7. Aug 4, 2022 at 1:15 PM
    blackdemon_tt
    there is a figure 8 gasket that you may want to get as well.. that's probably your failure, but idk, I can't see it.. its 50cents online, I got it for my 93 Lexus which applies to the Tundra as well...FYI
  8. Aug 4, 2022 at 2:34 PM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    ^^^^This! Proper placement shown...
  9. Aug 4, 2022 at 6:00 PM
    Nickw007
    Yeah that’s exactly what it was
    Canceled the order for the cheap one and picked one up just now at Toyota for 52 bucks
    more than online but got to test it today and definitely seems better quality
    Used same o rings and no more leak
    There must be some micro crack not really visible on the other plastic filter housing since there’s no more leak with the new one
    the old filter housing wasn’t leaking at rest or if u take it out and fill with oil but once motor is on it starts leaking so must be the pressure pushing it out of small crack
    does anyone else only drain around 5 quarts when they change oil on 5.7 ?
    never seem to drain full 8 quarts every time change the oil
    Is that normal?
  10. Aug 5, 2022 at 4:14 AM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    I just changed the oil and got about 7.4 quarts as expected. Maybe you had leaked the extra 2.4? You drained from both the filter and drain plug separately, right?
  11. Aug 5, 2022 at 4:36 AM
    Trogdog
    Trogdog New Member
    Trog
    North West GA
    2020 Crewmax SR5
    It looks like you still need to switch over the taller center support screen/tube from your old cap to the new cap. The Aluminum comes with a shorter one foe a different engine and the unsupported part of the filter element can colapse if you leave the shorter center screen/tube.
  12. Aug 5, 2022 at 4:39 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    I was just thinking the same thing good catch!
    I feel for the OP. He must have gone through 5 gal of oil by now
    GODZILLA likes this.
  13. Aug 5, 2022 at 4:47 AM
    NewImprovedRon
    Ron
    NW Arkansas
    Yes, OP will definitely need to switch out the center tube in the oil filter housing with the tube from the old housing. OP, are you sure you are changing the oil while parked on level ground. You should be getting more oil out than 5 quarts.
  14. Aug 5, 2022 at 7:55 AM
    Nickw007
    Oh wow I wasn’t aware the shorter tube in filter housing made a difference
    do you think it would be fine to leave until next oil change or will cause serious damage and should be done immediately ?
    it at least isn’t leaking
    I’ll call Toyota and ask if they can check if the shorter tube is or isn’t compatible with the motor
    would suck to have to take it out for 4th time but is what it is I guess
    Also yeah the drain pan was drained separately before the removing the filter and was done on level ground but still didn’t even drain 5 quarts
    in the pic is all the oil drained not even 5 quarts
    The dipstick didn’t show it was that low before draining the oil to only get barely 5 quarts
    It was dripping a decent amount from the filter housing before changing it but wouldn’t think lost 2 quarts through it
    But at the same time the last 3 oil changes I don’t think I’ve ever filled more than a full 5 quart jug with the old oil not sure why keep draining less oil unless it might be burning since the motor looks dry and doesn’t look like it’s leaking from anywhere
  15. Aug 5, 2022 at 2:24 PM
    EmergencyMaximum
    I'm draining full(mad full) 5qt bottle and then a bunch of water bottles. Check the tailpipe, do a swab, does she look dark? (Mine us 4.6l btw, not 5.7)
    Edit: one other thing, when you change oil and check level, do you check AFTER starting motor? Because if you only check before starting motor, all that space and filter is empty and after start, it will get filled up. That might be your extra 2 quarts that you maybe never added after checking after engine start?
  16. Aug 5, 2022 at 6:36 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    I would definitely swap over the riser tube ASAP.
    oil starvation is NOT something you want to risk... Especially on an engine this expensive to replace.
    I would also start checking your oil level every couple weeks. There should be way more than 4 quarts draining from your sump.
    I assume you are not draining the transmission thinking it's the motor oil.?
  17. Aug 5, 2022 at 6:37 PM
    COTundie
    Trey
    Pretty things
    Just draining the filter won't spill THAT much oil. Shouldn't be too expensive to replace
  18. Aug 5, 2022 at 7:02 PM
    EmergencyMaximum
    Pretty sure it's just a one off for the OP. He's been draining and refilling so much due to this leaking fiasco, perhaps he overlooked the level one time and didn't fill her up.
