Oil leak might not be where you think
Discussion in '1st Gen Tundras (2000-2006)' started by USERidiculousNAME, Apr 27, 2024.
  1. Apr 27, 2024 at 9:56 AM
    USERidiculousNAME
    USERidiculousNAME [OP] ToyTurd
    Josh
    New Orleans
    250K on Early 2004 tundra DC 4.7 v8, SR5, RWD, A/T, LSD, w/ABS,TOW, OFF ROAD, ZERO RUST FRAME, BILSTIEN 5100, AAL, 17" 265/70
    Backup camera, camper shell, double din stereo, amp, sub, blind spot cameras, modest lift, newer Tacoma rims, large AT tires, interior lighting upgrades, in bed, under hood, as well as leds in cab, blue foot well strips (night driving)or bright white strips if need to see, 3 additional white leds on ceiling front L/ R and center, toggle switch's and added accessory fuse box.
    I'm half passing along info while also confirming it. First gen tundra appears to have oil leak from pan gasket in front left corner right above the cross member. Also appears to have oil leak around filter or the oil cooler, as well as a hose or 2 in that area. I believe all of this is actually coming from the seal where the oil cooler mounts to the engine and looks like a figure 8. I read this and sounds right I'm getting ready to do timing belt water pump, plugs valve cover/S.P. gaskets ECT. I'm going to see if I can get the gasket if not I'll go with the 103 or black/grey right stuff. Ill update within the week
    rock climber likes this.
  2. Apr 27, 2024 at 11:31 AM
    shifty` In South Dakota Trouble ain't hard to find
    ATBAV8 likes this.
  3. Apr 28, 2024 at 9:53 AM
    USERidiculousNAME
    Josh
    New Orleans
    No sorry, just this kind of tech dumb
