Oil for 2018 Tundra
Discussion in '2.5 Gen Tundras (2014-2021)' started by bigfoot17, Jul 20, 2023.
  1. Jul 22, 2023 at 5:32 AM
    #61
    EmergencyMaximum
    EmergencyMaximum Synthetic member
  2. Jul 22, 2023 at 7:40 AM
    #62
    NWPirate
    Zach
    WA
    Damn things, shitty deal there.
  3. Jul 23, 2023 at 7:27 AM
    #63
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    hagrid and ZappBrannigan like this.
  4. Aug 9, 2023 at 4:07 PM
    #64
    619Iron
    619Iron Desert Diva
    Amber
    San Diego
    2018 Tundra TRD-OffRaod CrewMax
    Method NV wheels 0 offset with Micky Thompson 36” tires and TRD wheel caps , fox 2.5 DSC coil overs, Camburg KINETIC UCA's, TRD front & Rear sway Bars, TRD Skid plate, Addictive Desert Stealth Fighter front Bumper, Rigid 40" curved Light Bar, 2 BAJA DESIGNS 10" AMBER driving lights, Baja Designs 40" ONX6 and S8 Amber behind the grill lights, 40" Radiance SR Pro RBGW light bar in hood Bulge, Rigid DSS pro Ditch Lights, pro Comp RGBW rock lights. Amp running boards with custom red LED lighting system, Custom TRD dual air intake with use of GTEK fab and 4" Spector intake tube and Mishimoto silicone fittings, AFE throttle body spacer, Dual Switch Pro 9100 lighting & electrical systems, Pedal commander, Warn Zeon 10K S Platinum winch, SDHQ dual battery Kit with Power steering Upgrade. TRD Pro Front Grill, with Color Matched Hood bulge, Coach Builder Shackles and coil over spacers, Coach Builder bump stops and bushings. Coach Builder tie rods, and steering bushings, IKON RST leaf springs, SDHQ traction bars, Dirty Deeds straight exhaust with Helmholtz resonator, RCV front axles, Total Chaos lower control arms, and Camburg spindles. SDHQ Arb on board twin compressor.
    Neo Synthetic Oil outperforms all other oils. It’s a fact. You want to tool around let’s put your motor mouths to the test. I’m certain I have done more work on Tundra’s than most in this forum. I had one of the first Tundras in San Diego back in October of 1999 and put it through numerous off road conditions. Wish social media was more accessible then. My 2018 Tundra is been to Ocotillo Wells, Glamis, and Pismo, and no issues whatsoever other than pulling stuck Ram Rebels out of the Sand. Amsoil is garbage Mobile One is not a bad option especially every 3k miles. Do whatever you want with your truck. If you want to discuss the best quality oil Neo is the best. Don’t take my word for it. Call the guys at Camburg Engineering. They know what’s up. I have been in the off-road scene since the 70’s when I was very young my family comes from a long line of off road drivers and racers. I don’t mess around when it comes to maintenance on my motor. 0-20 and 5-20 are designed to help with mpg and environment, not truck longevity.
    Vince likes this.
  5. Aug 9, 2023 at 5:31 PM
    #65
    Vince
    Vince New Member
    Vincent
    Terre du lac, Missouri
    2011 White DBL cab 5.7
    K&N intake, Air bags
    10w 30 Castrol conventional I used 5w30 moved up to 10w 30 for my personal reasons
    Mike59 and Leo's first like this.
  6. Aug 9, 2023 at 6:07 PM
    #66
    pursuit2550
    pursuit2550 New Member
    LOL, You really think that the majority of people that drive like a normal person to and from work cares about what oil outperforms what oil. I will tell you what, I will put my motor to the test and I can guarantee you, aside of a manuf defect, that my engine will function the same at 100k, 200k, 300k, etc miles than and engine with Neo oil. Just like the million mile tundras did it on OEM Toyota oil. You can waste your money the way you see fit, but I can guarantee you that you will never know the actual benefits of Neo oil vs any other in normal driving conditions. I will not argue when it comes to hard core racing or off-roading, but for everyday driving, oil is oil. Show me an oil that can prevent a manuf defect on a bearing from failing. Show me a blind test where any 2 different types of oils were used for 100k+++ amount of miles on 2 of the same engines that shows one oil was better than the other. No manuf that I am aware of has done this because they know that a engine driven normally with any oil will look pretty much the same and show that the cost of the more expensive oil doesn't justify the performance.
    Mike59, PermaFrostTRD, ATV25 and 2 others like this.
  7. Aug 9, 2023 at 6:34 PM
    #67
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Lmao this man has a point. Like the 5w 30 or 0 20 matter. Just change it. Tranny now it gets the amsoil.
  8. Aug 10, 2023 at 1:32 AM
    #68
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    does NEO make their own base stock? wondering.
  9. Aug 10, 2023 at 3:05 AM
    #69
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    There's a LOT of oil brandnames and packaging out their.
    I wonder how many actual motor oil manufacturers there are.
    I'll bet, not many.
    nobodyintexas and ATV25 like this.
  10. Aug 10, 2023 at 3:49 AM
    #70
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I love Oil threads.
    question...
    how did that dude's tundra go 1 MILLION miles on dealer oil? was that a fluke?
    has there ever been an oil related engine failure that related to brand and/or viscosity? (ALL oil failures come from starvation)
    and to say Amsoil is "garbage" is quite the statement. we ALL know it's some of the best, we just don't want to pay $13/qt for the EXACT same performance we get from Kirklands @ $3/qt.
    now, let's get this thread off the rails and start the Ad Hominem motor.upload_2023-8-10_5-48-54.png
    Terndrerrr, coldcanuk, Mike59 and 3 others like this.
  11. Aug 10, 2023 at 4:26 AM
    #71
    PermaFrostTRD
    Northern NY
    3k mile OCI’s??
    ok, lazy.
    If you’re not stopping in an intersection and changing your oil during your daily commute- why even own a vehicle?
  12. Aug 10, 2023 at 4:54 AM
    #72
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    This is the way.
    I'm hoping Tioga Corp goes back to "total loss" lube systems with a 100gal oil tank in the bed.
    PermaFrostTRD and nobodyintexas like this.
  13. Aug 10, 2023 at 5:16 AM
    #73
    pursuit2550
    Yeah, he really lost all credibility when he said Amsoil is garbage. I don’t care for it or think it’s worth it to pay that much for the reasons I said but it’s not garbage oil. Wonder what he thinks of Super Tech then. :monocle:
  14. Aug 10, 2023 at 5:22 AM
    #74
    nobodyintexas
    nobodyintexas What?
    South of Houston
    most of the love for particular expensive oil brands is confirmation bias, or ugly baby syndrome.
    they paid too much for an engineered product. and want to justify it.
    in a previous lifetime, I repaired/maintained emergency gen-sets on tug/barge units out of Texas City. those units (usually cummins) ran bulk oil of various viscosity. I never saw boutique oils on those boats (even for the main engines!). and those systems support LIFE. there is no room for error.
    so, go buy your expensive oil...just don't holler in my ear about your choice. I'm rolling DEXOS certified Kirklands.
  15. Aug 10, 2023 at 5:32 AM
    #75
    nobodyintexas
    nobodyintexas What?
    South of Houston
    NEO 5w-30 is $16/qt.
    Kirklands is $3/qt
    can someone post an oil analysis after 5k miles, running this NEO stuff on a 5.7 Tundra?
    then, I'll post my kirklands....let's see if the bull is shitting in the buckwheat.
  16. Aug 10, 2023 at 8:12 AM
    #76
    CTundraForMe
    CTundraForMe New Member
    It's regularly > 100 degrees here ambient during the summer. It was 113 in Tucson the other day when I was there. I can only imagine how hot the engine gets.
    That's why I use 5w-30 amsoil. Why go cheap on oil on a very expensive truck??
    coldcanuk likes this.
  17. Aug 10, 2023 at 10:52 AM
    #77
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    This is the logic of a lot of people. And I totally get it. But I'll have something like a truck for a long time. I'd rather spend a lot more on a speed queen commercial grade W&D than a samsung home depot special, etc. I totally understand the reasoning there. I won't have motor oil for a long time.
    But, people apply this to motor oil and I have to ask,....how exactly do you know amsoil is better than mobil, or penzoil, or castrol, or any of the oils that Warren makes for anyone? Is it the smell? The taste? the way it pours out of the bottle? The color? The color of the bottle? Does your stereo sound better? Etc. Or, is it "better" because they charged more for it, so it must be? Is it going to last longer? See, I would spend double on oil if it lasted twice as long, because then I'd only have to change the oil half as much. It ends up costing the same, but saves time and work. I can see the logic there. But I would't run any oil for twice as long, no matter what they claimed. So, If I'm paying double and still changing my oil every 5k, then I'm wasting money.
    I don't understand the logic of paying double for something that you replace so often, especially when there's no real data to support that your engine will last longer, perform better or be less likely to mechanically fail. The "cheap" motor oil brands don't spend money on advertising or sponsor race teams. That's one of a few reasons why it's cheaper. I've yet to hear of an engine failure because of what brand an oil was. And I'd like to see some actual data that shows why really expensive oil makes your engine run better and last longer. And by actual data, I don't mean marketing nonsense that's not even true, from the people selling it.
    All I'm saying is that your truck won't run better or last longer than a truck using Costco or Walmart oil and being changed every 5k because you spend 3x as much for a name.
  18. Aug 10, 2023 at 11:05 AM
    #78
    nobodyintexas
    nobodyintexas What?
    South of Houston
    agreed.
    how does one know if an oil is able to run 10k? are you testing it?
    I was.
    my Kirklands had a TBN of 4.6 @ 5k miles. that's strong. but it was starting to go down from it's original #.
    so how long does one keep motor oil in the motor? do you wait for a 2.0 TBN?
    what is the TBN of NEO/AMSOIL/etc after 5k miles? I bet it's damn similar to kirklands.
    and I had zero wear metals. so don't go there.
    and what does "outperform" mean? really.
    let's call a spade a spade here....base stock come from 2 maybe 3 companies. then it's just an additive package.
    it's like those ultra fidelity, remastered gold CD's that were sold back when....they cost more, had the same base stock, and the only difference was something un-measurable. did I just date myself?
  19. Aug 10, 2023 at 11:31 AM
    #79
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Was it Lucas or amsoil that had the little plastic gears in a clear box in the auto parts stores? You could turn the little crank and see the gears turn in the oil.
    That was kinda cool. In a -I'm still a 7 yr old and like to play with things on the counter- kinda way. I never bought any, but I played with it every time I was in there.
    nobodyintexas and Leo's first like this.
  20. Aug 10, 2023 at 11:40 AM
    #80
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Found it! It was Lucas.
    Anyone a student of marketing and/or psychology?
    Can anyone tell me why there was a picture of a dragster or funny car on the display?
    ATV25, WILLINH, nobodyintexas and 3 others like this.
  21. Aug 10, 2023 at 11:45 AM
    #81
    EmergencyMaximum
    Wait a moment, I have those! Washer is scary, but dryer is decent. Where do you get the dairy queen that you mentioned? Are they longer lasting?
    Leo's first likes this.
  22. Aug 10, 2023 at 11:52 AM
    #82
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I haven't bought them yet, but as soon as budget allows, I'm going to purchase a set for home. From what I understand, a lot of the parts that are plastic in all the residential units are still made of metal in the commercial line.
    All I know is that the majority of people I've heard talking about W&DS in the last decade say they rarely get more than a few years out of them without needing repairs. Regardless of the brand or features or what they spent.
    We have a speed queen washer at work and the custodial staff use it a dozen times a day and beat the hell out of it. All their nasty rags and mop heads etc. And it's still going strong after 5 yrs. All the other buildings buy the cheaper brands from home Depot and they buy a new washer every 2-3 yrs.
    I was skeptical about paying big $$ for "speed queen", but I've seen with my own eyes. This washer at work would last 20+ yrs in a home. Easy.
    I don't know where they bought it.
  23. Aug 10, 2023 at 11:55 AM
    #83
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    And I just use regular cheap motor oil in it
  24. Aug 10, 2023 at 12:11 PM
    #84
    pursuit2550
    I have asked for this proof over and over. Still waiting for someone to post it. I have also asked for proof that any engine has failed because of a specific manful oil, Mobil, Penzoil, Castrol, etc. Not one person has yet to post an engine failure that was caused by oil. A engine fails because of a manufacturing error or lack of maintenance, never doing an oil change. The 3rd gens that have had bearing issues are because of manuf error, not because of the OEM Toyota oil or whatever oil the person put in afterwards. But hey, its peoples money and if it makes them feel all fuzzy inside to say they run Amsoil or Neo(blue/red pill), then have at it.
  25. Aug 10, 2023 at 12:12 PM
    #85
    pursuit2550
    I use to play with that all the time. Great advertisement.
    Leo's first and Oey12 like this.
  26. Aug 10, 2023 at 12:15 PM
    #86
    pursuit2550
    On another note, I was about to buy Toyota WS trans fluid and holy shit, it has sky rocketed. I was buying it at like $3+/- and it's at $12 now.
    WILLINH likes this.
  27. Aug 10, 2023 at 12:26 PM
    #87
    CTundraForMe
    I have seen "evidence" from third parties that Amsoil oil is top quality, if not the top quality. I say "evidence" because in today's misinformation age, it's hard to prove anything definitively, and "reviews" and "studies" generally find what they are paid to find.
    There is also the adage, you get what you pay for. Granted, that only goes so far, and there are plenty of scammers out there happy to take your money. But it also applies to a good many things, and I have yet to see a reason why it doesn't apply to Amsoil.
    I certainly wouldn't put "Amazon basics" oil in my truck. (I wouldn't use amazon basics anything!!) Likewise I'd have to think cheap kirklands oil is, well, cheap.
    Really, at the end of the day, being happy about your choices means a whole lot. Just don't insult others because they took a different path, and don't try to push your goods on them.
    CallsignKodiak and Leo's first like this.
  28. Aug 10, 2023 at 12:28 PM
    #88
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Because the advertisement works, there are suckers born everyday!
  29. Aug 10, 2023 at 12:39 PM
    #89
    pursuit2550
    Well everybody and their mothers have seen "evidence" from a 3rd party. A paid 3rd party most of the time. Nobody is saying Amsoil is cheap, like you are calling Kirkland cheap, but there is no evidence that shows that an engine running Amsoil runs any better or is protected any better than an engine running Kirkland. And I can guarantee you that Amsoil wouldn't put it to the test because in the end, the results would prove that as long as you do regular oil changes, any oil will protect it just fine. And it is being happy in the end of the day and not saying that the oil others use is cheap. Amsoil vendors remind me of extended warranty vendors. I still have one DMing me on FB for about a year now.
  30. Aug 10, 2023 at 12:56 PM
    #90
    CTundraForMe
    From a cost perspective, Amsoil is "expensive" and Kirkland is "cheap".
    You can reach whatever conclusion you wish from that. If you apply the "you get what you pay for" to those prices, then there's an obvious conclusion.
    No insult intended to anyone. Whatever works for you bro!
