Which oil filters to use?
Discussion in '2nd Gen Tundras (2007-2013)' started by Bucks04, Feb 18, 2018.
  1. Feb 18, 2018 at 4:02 AM
    Bucks04
    Bucks04 [OP] New Member
    2013 TRD Tundra
    Working on it
    just purchased 2013 4.6L V8 tundra trd offroad SR5 Had about 1-1/2 months great truck, love driving .Looking at oil change , wow what a difference. Need info on filter numbers, and amount of oil. Seen guys saying Toyota filters on e-bay by the case , but are they putting in stock Toyota , or TRD filters with metal frame on ends ? Quite a difference in price. Thanks for any advice.
  2. Feb 18, 2018 at 6:55 AM
    I use OEM oil filter as for that 4.6 not sure on part number I'm sure someone on here will chime in and assist or call dealership with your VIN #...also if you want a no mess oil change look up the fumoto valve I put mine on couple oil changes ago love it!!!
    ColoradoTJ and 15whtrd like this.
  3. Feb 18, 2018 at 8:06 AM
    LML 3500HD
    If you have your owners manual, all that information will be in the maintenance section. I do believe the oil filters are the same on the 5.7/4.6 V8 equipped trucks. I used either Mobil 1 filters or stock ones. I did get a better price on them at the Lexus dealership if I purchased 4. They were around 3.00 each.
    Glad you’re lovin the truck. What’s not to like right?
  4. Feb 18, 2018 at 8:10 AM
    LML 3500HD
    Great advice. I’ve been using Fumoto valves since 05’, and it makes the whole oil change experience “mo better”.
  5. Feb 18, 2018 at 8:25 AM
    Bucks04
    2013 TRD Tundra
    Working on it
    the 4.6L is the displacement mines 4.6L V8 not 5.7L, as far as the manual goes , its a 2007 year manual, some how the dealer I bought it from said it came with it . Most everything in it seems the same ,are they that close over 6 yrs. As for filters , no one uses the TRD filter?
  6. Feb 18, 2018 at 8:29 AM
    I believe someone on here has used before not sure who though
  7. Feb 18, 2018 at 11:07 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    Off the top of my head... the TRD filter is PTR43-00081. The standard OEM Toyota filter is 04152-YZZA4. They're the same for 4.6 and 5.7, oil capacity is 7.9 quarts with the filter change. The book says 7.9, some guys say 8.5 and i read one post where someone said 9.1. I use 8 quarts of Toyota 0W20 and the level on the dipstick is right where it should be. I used one TRD oil filter and honestly didn't notice any difference or benefit, however my truck is a flex fuel so I change my oil every 5000 miles. For someone going 10,000 between changes the TRD filter may be more beneficial. For me it only amounted to any extra $5 for a filter.
  8. Feb 18, 2018 at 11:12 AM
    duece292
    Greg
    Green Bay, WI
    Also, make sure to change the aluminum crush washer on the oil pan drain plug. If you get your oil and filter from a dealer they'll usually give you one. If not, they can be ordered on Amazon or eBay.
  9. Feb 18, 2018 at 4:43 PM
    Bucks04
    2013 TRD Tundra
    Working on it
    thanks ,I think I'm gonna go with the trd filter, I heard if you run the regular filter they can come apart if run to long . And I'm looking at 5w20 mobile1 . Also I've read about the fumoto valves and I just can't bring myself to trust it. To simple to not leak or get hit.
  10. Feb 22, 2018 at 6:41 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    I use WIX oil filters. I have not see them mentioned on Forum.
    Years back I read an unbiased study on oil filters. They did a dissection of many name brand filters and commented on quality; pleats, check valves, construction etc. I recall many of them were speculated to be the same just rebranded, and the famous orange one being of the lowest quality. WIX was rated at the top. I find them in the $8-10 at local parts stores. When in hand they actually feel like they are quality.
    12-15 years later there may be more quality oil filters out there, just have not seen a more recent study.
