Oil filter wrench
Discussion in '2nd Gen Tundras (2007-2013)' started by RR1975, Jul 31, 2018.
  1. Jul 31, 2018 at 8:23 AM
    RR1975
    RR1975 [OP] New Member
    Hey Tundra Owners,
    Do you have a recommendation on an oil filter wrench. I have read some bad reviews on some and so I'm a little hesitant and buying 1 before the first oil change.
  2. Jul 31, 2018 at 8:25 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome, your first oil change is free isn't it? The first 3 were for me.
  3. Jul 31, 2018 at 8:28 AM
    Welcome from Texas
  4. Jul 31, 2018 at 8:31 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome from TX!
    Get a metal one from local parts store, the "beefier" the better.
  5. Jul 31, 2018 at 8:33 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Welcome from CA
  6. Jul 31, 2018 at 8:42 AM
    AxelsHumanDad
    AxelsHumanDad Get off my lawn.
    KAIG, NW of The Frozen Tundra
    2015 CM Platinum
    Some suspension tweaks
  7. Jul 31, 2018 at 8:51 AM
    nk1794
    San Jose, CA
  8. Jul 31, 2018 at 10:08 AM
    Chu
    Chu New Member
    2014 Crewmax
  9. Aug 1, 2018 at 7:29 AM
    UNTMatt
    UNTMatt New Member
    2015 Attitude Black 4x4 Limited
    TRD Pro grille, TRD Pro black badging, TRD Pro shift knob, LED under dash lights, GBS, Llumar ceramic tint, BackFlip HD.
    The Motivx is the one I have and it is very well built (forged aluminum). You should not have any issues with it as long as you own your truck.
    --Matt
    MajorC and nk1794[QUOTED] like this.
  10. Aug 3, 2018 at 7:44 PM
    nuclearlemon
    nuclearlemon New Member
    wyoming
    2012 dc
  11. Aug 3, 2018 at 8:39 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    This^^^^^
    Also...check and follow the torque specs...especially with the plastic housing.
  12. Aug 4, 2018 at 3:31 AM
    hillbillytoyo
    hillbillytoyo Just a country boy
    Daniel
    WV
    21 Limited Cement CM TRD OF
    I have one from NAPA, it's well built and very sturdy.
    nuclearlemon likes this.
  13. Aug 4, 2018 at 8:16 AM
    MT1794PRO
    MT1794PRO New Member
    Paul
    2014 MGM 1794 CM
    Debadge, Dechrome, TRD Pro Grille, 2018 Headlights, Amber Grill Lights, Carbon Wrapped Wood Trim, Pace Edwards Switchblade Tonneau....
    The Motive wrench is good, best to change out the plastic cap and get the metal one on Amazon or I’ve seen them at local parts stores. Wrench matters a lot less with the metal cap.
    hillbillytoyo and nk1794 like this.
  14. Aug 4, 2018 at 10:28 AM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
  15. Sep 16, 2018 at 6:05 PM
    KS25-06
    KS25-06 New Member
    2008 Red Tundra Max cab TRD
    none
    Gentlemen, I have been having my oil and filter changed for several years at a business that started out very well in the beginning. Having changed hands three times in the last two years, I have became dissatisfied with their services and increased prices. I have been told that there are a couple of seals that have to be installed properly or the filter will leak. Is this true? If so, can some one give instructions to avoid this problem? Is there any thing else I need to purchase other than what is shown here? Thank you for any help, James.
  16. Sep 16, 2018 at 6:24 PM
    GWalker
    GWalker New Member
    North Carolina
    2014 White Tundra Double Cab Limited
    James, The above suggestions are great, look into purchasing the metal filter housing and Motivx wrench, I have both. There are 2 o-ring seals included with every Toyota filter element. Replace both of them at each oil change, instructions on box, very simple, just coat the o-rings with fresh oil at time of installation and torque per the specification. I have never had a leak.
    WVI and MajorC like this.
  17. Sep 16, 2018 at 8:44 PM
    TRD Pro Rookie
    TRD Pro Rookie New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
  18. Sep 17, 2018 at 7:32 AM
    11SilverPlatinum
    11SilverPlatinum New Member
    Dave
    2011 Platinum Tundra
    Plastidip emblems, Pace Edward bed cover w/lumber rack, remote start, TRD intake and exhaust, TRD front and rear sway bars, color match grill surround, LED headlight upgrade.
    I agree as well. I drive 150 miles a day so my oil changes are about every 5 weeks. I installed the metal cap and use both the metal wrench that fits the slots or the socket style that fits the bottom of the cap. My favorite tool was the drain valve that screws into the bottom of the filter to drain it before you remove it. Saves a lot of messy oil leaking all over your hands. I got mine on Amazon. You might check into that.
    TRD Pro Rookie likes this.
  19. Sep 18, 2018 at 11:43 AM
    polartundra
    polartundra New Member
    2007 Super White Tundra Limited Crewmax 5.7 Bedrock Leather
    * 3" leveling kit - Front * MB Chaos black with Nitto Terra Grapplers * HID light system - Low beam and fog lights * Metal Bumper Guard * Matching hard bed cover * AMP Research step * Super bright lights LED all interior
    Welcome from Texas.
    I purchased my filter wrench from walmart costing me less than 5 bucks along with a 27mm socket which was 8 bucks. Purchased Mobil one synthetic 0-20w also and will be installing a fumoto valve to help make it easier for future oil drains like I did on my tacoma. Hope this helps.
    https://www.amazon.com/Fumoto-F-103N-Engine-Drain-Valve/dp/B003UT822G
  20. Sep 18, 2018 at 11:48 AM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    Put a quality oil in and do your inspection at 5k miles, change at 10k miles. I have been running Liqui Moly in my personal truck, I have sent samples out at both 5k, 10k, and 15k for all them to come back exactly the same. So I stick to the 5k inspection and 10k change per the owners manual. I also have the Fumoto valve which is awesome!
  21. Sep 18, 2018 at 12:03 PM
    MacCTD
    MacCTD New Member
    2010 CM 4x4
    5100s
    The drain plug on the filter that takes the 3/8" extension is apparently tighter than the filter housing, I think it may have come out the first time but every other oil change I have just used the 3/8" extension to remove the filter housing.
    kenomouth64 likes this.
  22. Sep 18, 2018 at 6:42 PM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I believe the torque spec on the filter drain is 9lbs and the filter housing is 18lbs
  23. Nov 9, 2018 at 1:48 PM
    wallyblackburn
    wallyblackburn New Member
    Wally
    2018 Black Tundra SR
    nk1794[QUOTED] likes this.
  24. Nov 9, 2018 at 1:51 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    It fits on my '18
  25. Nov 9, 2018 at 2:35 PM
    jtwags
    League City, TX
    2018 Tundra CM
    X2^
  26. Nov 9, 2018 at 2:37 PM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    How much do you want to spend...
  27. Nov 9, 2018 at 2:41 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    PMG likes this.
