Oil Filter Housing Cap ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by zebian2, Mar 27, 2019.
  1. Mar 31, 2019 at 12:26 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    You can spend a lot of money and get a genuine Toyota SST...Or, you spend not so much money and order this:
    https://www.amazon.com/dp/B078RJ2L2...&pd_rd_r=0d2eedb7-53eb-11e9-b6b9-cd59af5e4b95
    If you buy the SST, I expect you'll be one up on virtually all Toyota dealers. :D
    Angry Gunny and 4Runner like this.
  2. Mar 31, 2019 at 12:32 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
  3. Apr 1, 2019 at 6:23 PM
    zebian2
    zebian2 [OP] New Member
    Jamy
  4. Apr 1, 2019 at 6:33 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
  5. Apr 1, 2019 at 7:01 PM
    zebian2
    Jamy
    Any link for this SST tool you mentioned or a part #?
    Thank you
  6. Apr 1, 2019 at 8:20 PM
    JohnLakeman
    Actually, you were the one that mentioned a "genuine Toyota oil filter housing wrench". I'm pretty sure that Toyota has an SST (Special Service Tool) for removing the oil filter housing, but I don't need to know the part number for it. From my experience buying Toyota SSTs, I estimate it would probably cost $250 and not work any better than the Motivx.
    When I looked, there were a couple dozen tools for Toyota oil filter housings on Amazon. Some are cast aluminum, some are forged aluminum, some are bent steel, all are made in China. Experience from Tundra forums has the cast ones breaking and rounding out the 3/8" drive, and the bent steel ones, well, bending.
    The tool in the link I gave you is excellent...it is made of forged aluminum, and costs under $25. It has internal flats to engage the housing flutes and slots to engage the housing ears. No reports of them breaking. The link also included a drain valve and hose assembly to keep oil from running down your arm while removing the housing...if you don't mind the oil, then just buy the tool.
    https://www.amazon.com/Motivx-Tools...74868&s=gateway&sprefix=motivx,aps,190&sr=8-3
    matictundra and TTund16 like this.
  7. Apr 1, 2019 at 9:00 PM
    zebian2
    Jamy
    I truly appreciate that
    I’ll go ahead and get one
    Thank you
  8. Apr 1, 2019 at 9:23 PM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    The one I posted is what Toyota service guys use. Very heavy duty. I’ve had others with the “teeth” and the first one broke in half and the other tore up the filter housing.
  9. Apr 1, 2019 at 9:35 PM
    zebian2
    Jamy
    Thank you for the update
  10. Apr 2, 2019 at 1:34 AM
    trainracer
    trainracer New Member
  11. Apr 2, 2019 at 7:47 AM
    JohnLakeman
    @zebian2 If you need MORE data for a totally comprehensive analysis, here is a related four page thread of user experience with several different types and manufacturers of Toyota oil filter housing tools:
    https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3967067/1
    It also includes the Toyota part number for the "genuine Toyota oil filter housing wrench (SST 09228-06501)" which appears to be made by Assenmacher. Google that number and a whole world of cheap Chinese crap shows up. Motivx is made in Taiwan, which usually implies higher quality with higher cost. I previously thought OTC supplied Toyota SST, but that relationship must have changed.
    The main complaints for the Assenmacher version seems to be it has no slots to engage the housing ears (required by the OP), slips on the housing flutes, and is difficult to remove from the housing once the housing has been removed. Some of these problems are in the context of removing housings that have been over-tightened. If you torque it properly, almost any of those tools should work fine, maybe even those adjustable filter pliers from Harbor Freight (joking). ;)
  12. Apr 2, 2019 at 8:23 AM
    zebian2
    Jamy
    TTU19 likes this.
  13. Apr 4, 2019 at 5:33 AM
    novae500
    novae500 New Member
    2016 Tundra DC SR5 upgraded package
    for the first oil change, i switched out the plastic housing for the venza housing. Any you guys keep the skid plate off after the oil change or reinstall it?
  14. Apr 4, 2019 at 5:41 AM
    Trooper2
    JR
    mine has been off for almost a year, fine if not going offroad. have since cut a hole in it to access oil filter.20190308_144740.jpg
  15. Apr 4, 2019 at 7:58 AM
    zebian2
    Jamy
    That’s a perfectly cut hole
    Weld a small hinge and bolt on the other side and you’re set
  16. Apr 4, 2019 at 8:17 AM
    Trooper2
    JR
    Others have saved the cutout and made a hinged door, which looked nice. Think one guy used a baking cookie sheet for material and made a door. most were riveted.
    wasn't real worried abiut it.
    Believe the RCI replacement plate has an access door.
  17. Apr 7, 2019 at 11:57 AM
    Mr Badwrench
    Mr Badwrench New Member
    My hero! Was just about to convert the units, then I scrolled down and saw your post.
    JoshuaA[QUOTED] likes this.
  18. Apr 7, 2019 at 12:19 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Props goes to @nk1794, his vids are boss and where I got that from:
  19. Apr 8, 2019 at 6:53 AM
    #49
    blaserdude
    blaserdude New Member
    Eugene
    2019 Tundra Limited Double Cab
    none
  20. Apr 8, 2019 at 6:56 AM
    #50
    Trooper2
    JR
    Amazon and Ebay are in $20 range.
    #50
  21. Apr 9, 2019 at 4:34 AM
    #51
    rsgt
    rsgt New Member
    2019 crew cab TRD sport 4x4
    all stock
    Just got my first oil change at the dealer for Toyota care. I mention the plastic cap is know to crack. Service manager said Yep thats why we put a new one on when do the oil. to many owners coming back with oil dripping cause the oil cap cracked taking it off or on .
  22. Apr 9, 2019 at 5:32 AM
    #52
    JohnLakeman
    Sounds like the Cap'n was blowing smoke up yer butt. BUT, if true, then the Service Manager should be little more like the Cap'n in "Cool Hand Luke"!
    https://www.youtube.com/watch?v=452XjnaHr1A
  23. Apr 9, 2019 at 6:22 AM
    #53
    rsgt
    rsgt New Member
    all stock
    Love that movie ! Smoke up my ass could be, but dang how did they get my old cap in a sealed plastic bag take in out and installed it while I watched ! Oh the smoke got into my eyes.
    TWJLee likes this.
  24. Apr 9, 2019 at 6:23 AM
    #54
    rsgt
    rsgt New Member
    all stock
    John suggestion never mind !
  25. Apr 9, 2019 at 2:24 PM
    #55
    JohnLakeman
    My point was this: If his technicians are being told to replace that plastic filter housing every time they change oil to avoid cracked housings, and they are not responsive to being told to not over-torque the housing, then they need to have their attitude adjusted, as in TERMINATED. One time use on that part simply because their technicians think the only wrench is an impact wrench is absolutely unacceptable.
    Here's another "John" suggestion for you, but I'm sure you'll do what you want: Don't ever go back to that dealer. If they're over-torquing every plastic filter housing, a part clearly not designed for impact wrench installation, they're over-torquing everything else...your oil drain plug, your lug nuts, everything. When you start seeing the expense of shredded threads, then I think you'll get it.
  26. Apr 9, 2019 at 3:59 PM
    #56
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    The fact that you have a degree of worry regarding the dealer service should..................should...................should...............well, I've said it many time in many other threads.
    Let's all just hope it works out for you with nothing but glowing reports of good and accurate service. :thumbsup:
  27. Apr 10, 2019 at 3:04 AM
    #57
    rsgt
    rsgt New Member
    all stock
    I agree for sure that if done properly the cap should not have to be replaced. I just noted what the dealer does. Yes shows the they don't know what their doing when it comes to tighting the canister cap !!
  28. Apr 10, 2019 at 5:38 AM
    #58
    NH2BV
    NH2BV Daily drivers!
    Las Cruces, NM
    2024 Tundra TRD Off Road
    Rock Stock OEM beast
    Obsolescence in design! Well, they couldn't actually do that so they opted for the next best thing. Consumable replacement parts. It sounds like something Raytheon has designed (long story there). Just go out and buy the aluminum housing and forget about cracking that plastic cup. It IS going to fail eventually, (even with the OEM SST) so just throw the $20 bucks at it and get it over with. I am still in the "Toyota care" cycle and I handed the aluminum housing to the Toyota techs and they agreed to just swap it out on the "periodic" oil change. I thought I would get a little blowback from them, but they just nodded and changed it. I glyptoll'ed the bolt heads on the skid plate to see if they actually changed it. They did. I had to do the same on my 2015 4Runner too.
  29. Apr 10, 2019 at 5:43 AM
    #59
    rsgt
    rsgt New Member
    all stock
    Great idea that’s what I’ll do. I’ve got to oct. So I’ll research what to get. Thanks for the constructive reply !!
  30. Apr 10, 2019 at 5:51 AM
    #60
    Trooper2
    JR
    Dealerships do not use their Master mechanics to do oil changes. Oil Changes are often performed by the fairly untrained, high turn over, or Porter types. Guessing too many vehicles to "Train" them on to do it correctly.
    P-Factor likes this.
