Oil filter housing cap? (not the usual questions)
Discussion in '2.5 Gen Tundras (2014-2021)' started by RichterScale, May 18, 2023.
  1. May 18, 2023 at 7:16 AM
    RichterScale
    RichterScale [OP] I identify as a potato
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I'm looking to order a factory (plastic) oil filter cap, so I have a spare on hand, should I ever damage the current cap during future changes. (Don't want a metal or aftermarket cap).
    Every online dealer parts site seems to list the caps for 2007-2020. When I type in my truck, it says "this part will not fit your vehicle".
    It's a 2021 SR 2wd 5.7 w/tow pkg.
    I'm confused, as there's nothing about the truck, engine or oil filter assembly that's any different from the previous years. At least not that I can tell or know of. I even had one site pull up a screw on, external filter for my truck (maybe confused with 2022 on their site?)
    I dunno what the deal is.
    Seems highly unlikely, but was there a very minor change for one model year? doesn't seem very Toyota-ish to do that. Is 2021 the bastard middle child year?
    Anyone else deal with trouble finding this part for a 2021?
    Anyone know that I can just go ahead and order one for a different year and it will be identical?
    EDIT:
    Now the number is showing up on Sparks as the right part#. They only show one in stock so it's in the cart. Can anyone verify this is right?
    15620-0S010 - Engine Oil Filter Housing Cover - 2007-2021 Toyota | Sparks Parts
    EDIT: EDIT:
    Also, I lost the thread about filter wrenches (I don't think I have my old one from last Tundra). Anyone got a link or part#?
    Thanks.
  2. May 18, 2023 at 7:31 AM
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
  3. May 18, 2023 at 7:37 AM
    SnrDisregardo
    Wade
    IL
    I also came up with PN 15650-0S010 for a filter cap housing assembly. This may come with a filter already. I looked up a 18 since when I tried with a '21, it said to contact dealer.
  4. May 18, 2023 at 7:41 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  5. May 18, 2023 at 7:51 AM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
  6. May 18, 2023 at 8:21 AM
    SnrDisregardo
    Wade
    IL
    I've only read good reviews about the one I linked. I was going to go with what you showed until I saw people saying the "teeth" or drive nut broke off after a couple of uses.
  7. May 18, 2023 at 8:30 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    MotivX made 2 versions of the wrench (I have both). One has the gaps to engage the tabs on the housing and the later one just works on the outside diameter.
    WILLINH and texasrho83[QUOTED] like this.
  8. May 18, 2023 at 8:58 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Yeah, so I'm im not nuts. At least, not because of this. I was getting similar results when I typed in 2021. Weird.
  9. May 18, 2023 at 9:35 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    See the wording of the link I copied earlier?
    I type it in now and it's back to saying it doesn't fit. But it's for a 5.7 Tundra with tow pkg and oil cooler. which I have. I surrender.
    Just FYI, it says that number is for non tow pkg, but I don't know how accurate any of this crap is now.
  10. May 18, 2023 at 9:59 AM
    SnrDisregardo
    Wade
    IL
    I just looked up a '20, since it's sans oil cooler and it gave me 15650-0S010. I didn't pick a trim either. Just the basic one. Just to be sure, I'd call a dealer with your VIN.
    RichterScale[OP] likes this.
  11. May 18, 2023 at 10:20 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I contacted Sparks. Waiting for a response.
  12. May 18, 2023 at 4:11 PM
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    Part # from Toyota dealership is 15620-?????
  13. May 18, 2023 at 4:32 PM
    Jack_A_Lope
    Aaron
    It's weird it keeps showing this one though.
  14. May 18, 2023 at 4:40 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Curious why you wouldn't want the Toyota Aluminum canister?
  15. May 18, 2023 at 4:54 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Well, never had an issue with the original plastic housing on previous 2 Tundras. I don't see any advantage to switching. Mostly because, as far as I know, you have to remove the stand pipe from the plastic housing and install it in the metal housing. It's not really designed to be removed. I dunno, I just feel like it's a part that doesn't need to be upgraded or modified of monkeyed with. I'll be doing all oil changes myself (always have) so I don't have to worry about someone else over tightening it or breaking anything. I may never need it, but I figured I'd like to have a spare just in case I do something stupid at some point. I won't have to wait a few days for a new one and drive my wife's little Ford bronco to work. I couldn't care less about the rhinestone steering wheel cover. I don't want people seeing me in a Ford.
    So, I want a spare on the shelf.
  16. May 18, 2023 at 5:06 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Yeah, I had that one show up in one of my many attempts. Not sure what that's all about.
    I contacted them shortly after placing the order, to confirm fitment. They never answered and then I got an email that it shipped a few hours later.
    At this point, I'll just wait for it to show up and I'll compare it to the one in the truck when I change the oil.
    The whole filter housing assembly is different than the 4wd 2011 and 2015. Not sure if that's because this one is 2wd, or if it's a change for the 2021.
  17. May 18, 2023 at 5:27 PM
    It does notncome with a filter. When I replaced it on my previous truck, it was just the housing and the tube, and possibly the oring....I don't recall.
    SnrDisregardo[QUOTED] likes this.
  18. May 18, 2023 at 5:36 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    Yeah, I ordered the cap and 2 filters. The filters come with all the O rings.
    Weird, the housing that comes with the filter was $100.
    I ordered a cap and 2 filters, + $20 shipping and it was $90.
  19. May 19, 2023 at 9:27 AM
    SnrDisregardo
    Wade
    IL
    I never understood it either. Millions of Toyotas are running the plastic cap. I will admit, I did break one on my Prius, but that was my own fault for not wanting to spend the money on the proper tool to get it off. Other than that, there is no reason to upgrade it. There is literally a skid plate guarding it.
    Y0TA PR0 likes this.
  20. May 19, 2023 at 9:33 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I wish i had seen this in time. i have 2 plastic caps for the 5.7s that came off my last tundra and my current sequoia when i swapped to the metal housing. i would have sent you 1 for free
    Trooper2 and RichterScale[OP] like this.
  21. May 19, 2023 at 9:38 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    First time I tried to remove the plastic cap I broke it and the tool.
  22. May 21, 2023 at 9:39 PM
    Dukhnt
    Dukhnt New Member
    It's probably a good idea to have a spare. I'd be happy to buy one and pay shipping if you wont ever use them.
    Fotnot[QUOTED] likes this.
  23. May 22, 2023 at 5:14 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    i have 2 i think. i would like to keep one. if ya want it, PM me and i'll see about sending it to ya:thumbsup:
  24. May 22, 2023 at 5:20 AM
    SouthWestGA
    SouthWestGA New Member
    I could use a housing: the tabs on mine are cracked and gone.
  25. May 22, 2023 at 5:34 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    same thing, PM me and i can send ya one. i'll get it to the one that responds to me first since i want to keep one just in case.
  26. Jul 1, 2023 at 10:21 AM
    BulldogDan
    BulldogDan New Member
    Cement…Tundra #9
    Getting back to the question at hand…I too would like to order a back up filter cap assembly for my 2018 2wd…so do I order the 15650-0S010, the 15650-38010 or the 15620-0S010? Mine has the 5.7L with tow package.
  27. Jul 1, 2023 at 7:57 PM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    Having a backup is definitely a good idea.
    I had one break on me a few years ago while doing an oil change on a Saturday. I was just barely able to make it to a Toyota dealer who had one in stock before they closed that day.
