Oil filter cartridge
Discussion in '2.5 Gen Tundras (2014-2021)' started by Oregon 1 Toyo, Apr 15, 2018.
  1. Apr 15, 2018 at 2:10 PM
    Oregon 1 Toyo
    Oregon 1 Toyo [OP] New Member
    2014 Tundra sr5 double cab 4x4
    Has anyone had problems getting the plastic oil filter cartridge out after draining the oil, have you switched to the alluminum ones and are they better?
  2. Apr 15, 2018 at 2:31 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Do you mean the plastic cap off? I didn't have an issue getting it off the truck however I didn't have it lined up right in the tool and that was a pita to get the cap out of the tool. I have seen on here people have had them crack on them. To avoid this I did just purchase the Aluminum one off Amazon and it should be here on wednesday.
    Also Welcome! What part of Oregon are you in? We have had a lot of new Oregon members the last couple weeks.
  3. Apr 15, 2018 at 2:48 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Torque spec is 18 ft Lbs. if you don’t exceed this it shouldn’t be a problem.
  4. Apr 15, 2018 at 3:42 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    I had to use a breaker bar to take the cap out. The mechanic at the dealer wayyyy over torqued it.
    GNTundra likes this.
  5. Apr 15, 2018 at 4:08 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Best reason to DIY.
  6. Apr 15, 2018 at 4:10 PM
    Considering that aluminum one
    TTund16, GNTundra and nk1794 like this.
  7. Apr 15, 2018 at 4:12 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    No reason to consider it, buy it. This will save you $ when you don't have to have your car towed to the dealer when you break the tabs off, and crack the plastic one and have no way to get it off. Ask me how I know.
  8. Apr 15, 2018 at 4:14 PM
    Roger that! Get home tonight, place order off Amazon
    GNTundra and mdavis[QUOTED] like this.
  9. Apr 15, 2018 at 4:17 PM
    tacomawv
    tacomawv New Member
    Richard
    I just did the first oil change in my wife's GX 460 and it took a breaker bar and everything i had to get it off. The tool is stuck on it. It is a part of the car now. I think they torqued it to 300 foot pounds.
    GNTundra and nk1794[QUOTED] like this.
  10. Apr 15, 2018 at 4:17 PM
    15whtrd
    15whtrd Mr. Blonde
    They are so cheap it’s a no brainer. Mine is waiting in my garage patiently for my next oil change.
  11. Apr 15, 2018 at 4:19 PM
    nk1794
    San Jose, CA
    They used an impact gun on it. :rofl:
  12. Apr 15, 2018 at 4:21 PM
    Anyone with link to it?
  13. Apr 15, 2018 at 4:22 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    Any idea what the part number is or exact name of the housing is. Been thinking of the metal housing since I just had my last free oil change done at the dealer and back to doing it myself. Already have the oil drain valve and hose. just need this housing and ill be GTG
  14. Apr 15, 2018 at 4:25 PM
  15. Apr 15, 2018 at 4:26 PM
    mdavis
    Michael
    Rock Hill, SC
  16. Apr 15, 2018 at 4:27 PM
    tacomawv
    tacomawv New Member
    Richard
    They could have. It was crazy tight.
  17. Apr 15, 2018 at 4:28 PM
    Wish S/C cud cost that much!!!
    15whtrd and mdavis[QUOTED] like this.
  18. Apr 15, 2018 at 4:31 PM
    nk1794
    San Jose, CA
  19. Apr 15, 2018 at 4:37 PM
    15whtrd
    15whtrd Mr. Blonde
    Just make sure you guys switch over the perforated filter tube. The one it comes with is to short.
  20. Apr 15, 2018 at 4:37 PM
    Wait! What?
  21. Apr 15, 2018 at 4:37 PM
    nk1794
    San Jose, CA
    Good to know. Thanks
  22. Apr 15, 2018 at 4:40 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    This is why I REFUSE to let the dealer and the oil change bone heads touch my truck. 18 ft lbs is to hard for those idiots.
    With that said I’m not completely sold on the aluminum model. When I threaded mine up it didn’t seem to seat as well. It probably is just fine but it didn’t feel right to me.
  23. Apr 15, 2018 at 4:44 PM
    15whtrd
    15whtrd Mr. Blonde
    It’s easy. The aluminum canister has a shorter tube built for a shorter filter. Its the only difference and why when you order it, it says this will not fit your vehicle. Just have to carefully bend a couple tabs then push and twist the tube out. Then just reverse order. It will make sense when you have it in hand.
    mdavis likes this.
  24. Apr 15, 2018 at 5:36 PM
    Skippy
    Skippy Standing for the Flag
    San Antonio US of A
    2016 Tundra 1794
    OK, I'll ask. How do you know?:crazy: :stirthepot:
    gosolo likes this.
  25. Apr 15, 2018 at 5:37 PM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    Just ordered the housing and a oil filter wrench. Should have everything to do the oil soon. Anyone know how to reset the paint due warning on the dash. I read it somewhere here but as much time as I spend on this forum, I can't recall which thread.
  26. Apr 15, 2018 at 5:43 PM
    15whtrd
    15whtrd Mr. Blonde
    Yes. With the key in the on position put it on trip A, turn the key off then hold down the trip odometer button and turn the key back on, hold it down until the little dashes count down.
  27. Apr 15, 2018 at 5:45 PM
    SMK Shoe
    Paul
    2017 Tundra TRD DC
    thanx, gonna have to remember that and write it on my toolbox lid. Maybe also tattoo it on my arm.
    15whtrd likes this.
  28. Apr 15, 2018 at 5:46 PM
    Juanjoolio007
    Oregon
    I went to grab the YouTube link but instructions were posted faster. Ps it’s on YouTube also.
    15whtrd likes this.
  29. Apr 15, 2018 at 5:47 PM
    Oregon 1 Toyo
  30. Apr 15, 2018 at 5:53 PM
    Oregon 1 Toyo
    Thanks everyone for the imput, I’ll probably take it somewhere next oil change and convert to alluminum sounds like they are better. I broke a couple plastic teeth off of mine before I gave up on it.
