Oil changes suck!
Discussion in '2.5 Gen Tundras (2014-2021)' started by bfd300, May 15, 2019.
  1. May 15, 2019 at 6:06 PM
    bfd300
    bfd300 [OP] New Member
    Did my 3rd oil change today 15k mile. It so sucks dropping and installing the skid plate. Plus that crazy oil filter housing. My 11 Tacoma, 9 minutes. Filter right on top, no skid to drop. Loved it. This thing ....ugh!! So I today I decided to make a trap door in the skid plate. Thank you Mr Plasma Cutter.. lol. And I also changed to the Aluminum filter housing. Hopefully next oil chang will go faster.
  2. May 15, 2019 at 6:11 PM
    bfd300
    I cut a door in the plate ,hopefully that helps
    gosolo and Watt maker like this.
  3. May 15, 2019 at 6:12 PM
    bfd300
    Similar to this.
  4. May 15, 2019 at 6:22 PM
    Mr Badwrench
    Mr Badwrench New Member
    I agree, OP. Changing the oil on these is pretty terrible. Skid plate is not overwhelmingly heavy or cumbersome, but unless your truck is lifted, it is tough to get under there. The oil filter is goofy... it is just goofy. Would a canister type filter be too much to ask for? And what is with the check-ball drain valve on the oil filter cap??? That is really the best they could come up with?
    AND... the drain plug is about 1/4" off the very bottom of the oil pan, so, the most contaminated oil with the heaviest particulates will remain in the pan regardless of how long you let it drain.
    TO TOP THINGS OFF... those three screws that go into the lower valence. How long do they expect the the plastic poppets on the valence to last? 3 oil changes if you don't go over 1/4 ft*lb of torque.
    ALSO, you have 2 gallons of oil pointed directly at your front passenger brake rotor when you get the drain plug off.
    FURTHERMORE... How is my fat American ass supposed to squeeze under this truck to get to the back bolts on the skid plate?
    Couldn't agree more OP.
    *indignant mic drop*
  5. May 15, 2019 at 6:28 PM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    Buy the RCI skid plate and the motivx oil filter wrench.
    Use all the time you'll save to do nothing. And enjoy it.
  6. May 15, 2019 at 6:29 PM
    bfd300
    Reading that I so had to laugh lol, Sir I am going to have a beer in you honor lol
  7. May 15, 2019 at 6:31 PM
    Mr Badwrench
    :cheers: yeah buddy!
    Trooper2 likes this.
  8. May 15, 2019 at 6:50 PM
    Berettafan
    Berettafan New Member
    2017 CM
    my solution:
    TRD skid plate
    1/2" coachbuilder spacers
    275/70 tires
    I can now easily fit under the truck and use a clear plastic bin to drain the oil.
    I had a BMW with the canister oil filter but the canister was topside near the radiator. much easier to deal with.
    Hbjeff likes this.
  9. May 15, 2019 at 7:04 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Two Rhino brand plastic ramps. I think they're 12,000 pound rated. $32 for a pair at Wally World. Mega easy access to the bolts, etc. Mega.
  10. May 15, 2019 at 7:12 PM
    Inquiringone
    Ter
    NorCal 408
    Not many yet, mostly stock.
    Harbor Freight floor jack 3 ton W/ coupon $ 99.99 will fix the clearance problem, majic creeper $46.99 so you can get that belly going. RCI skid plate and fotomo valve $49.00 for the filter and theres another valve that has a safety on it, I think the the engine pan bolt It's from jowlett performance. But I'm still waiting for Jowlett to have them made. May not help this moment but in the future. Nuts / bolts for thought
    Black Wolf and Trooper2 like this.
  11. May 15, 2019 at 7:20 PM
    bfd300
    I’m only 160lbs lol no prob fitting under... my gripe to having to remove skid and that crazy filter housing. If I ever find an oil filter relocation kit with a spin on I am so buying it. This thing is just plain insane.
    Black Wolf likes this.
  12. May 15, 2019 at 7:21 PM
    AZTundra
    Paul
    Phoenix, AZ
  13. May 15, 2019 at 7:28 PM
    kleiker0303
    kleiker0303 New Member
    Kyler
    Kansas City
    ‘16 Platinum
    Bilstein 6112 @ 1.9" Bilstein 5100's in rear Afe drop in filter Afe intake tube Afe throttle body spacer Afe catback with vibrant resonator added Stubby antenna TRD front grill Paint matched door handles Paint match mirror caps RCI skid plate All LED bulbs Undercover flex cover 20% tint all around Husky floor liners ESP under seat storage 2018 headlight mod Baja designs fog light kit 275/60/r20 falken wildpeak at3w 20x9 fuel ripper
    +1 on the rci skid plate and motivx wrench. Cuts changing time damn near in half
  14. May 15, 2019 at 9:09 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Lol same here. I fit under to install the wire for tailgate release.
    I also use rhino ramps if needed. I used them on my 1500 Silverado to do oil changes before it had lower clearance.
  15. May 15, 2019 at 9:33 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The rhino ramp are way too tall. Just drive up on a stretch of 2x4. I’m 200lbs and can easily fit under
  16. May 16, 2019 at 12:49 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I was just bitching to my wife about changing the oil on the tundra the other day... she made fun of me. This thread vindicated my pain!! So thank you. Thank you all.
    Trooper2 and Watt maker like this.
  17. May 16, 2019 at 5:11 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    You don't have my same problem.
    Watt maker, Y0TA PR0, Rica25 and 3 others like this.
  18. May 16, 2019 at 5:55 AM
    Stig
    Stig New Member
    Hmm, lots of threads on this. Toyota/Lexus have been the easiest oil change for me, with the right tools to help.
    Removing the skid plate is an extra step but if you raise your truck up on jack stands it's pretty easy after you've done it once.
    15whtrd likes this.
  19. May 16, 2019 at 6:19 AM
    :drool:
    Rica25 likes this.
  20. May 16, 2019 at 6:24 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Been thinking of removing the skid plate on my truck to speed up oil changes. Truck is only used on the highway.
    Rica25 and Hbjeff like this.
  21. May 16, 2019 at 6:30 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Word. It’s so thin I’ve been wondering the same thing
    Rica25 likes this.
  22. May 16, 2019 at 6:32 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I just cut a hole my skid plate. No door or anything. Just a fat hole. Works wonders.
    Jrharvey02, Hbjeff and Rica25 like this.
  23. May 16, 2019 at 6:40 AM
    Rica25
    Ricardo
    Tulare
    Just order one from RCI and problem solved
  24. May 16, 2019 at 6:45 AM
    AK 6.7PSD Replacement
    AK 6.7PSD Replacement New Member
    IL, MO, KS, DE, IL, AK, SC...
    2018 SR5 DoubleCab 4x4
    My RCI steel skid plate and Fumoto valve are due to arrive by FEDEX this coming Tuesday. I’m using my last free oil change at the dealer that Friday and telling them to leave the stock skid plate off the truck and installing the RXI over the weekend. Looking forward to using legit synthetic oil at my own interval and knowing it’s done right (with a hell of a lot better protection for the power train)!
    Mountun Goat likes this.
  25. May 16, 2019 at 6:53 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    The skid plate (ARamirez73 you too??) on my 1997 T100, 4WD, is actually plastic. Light as all get out. And it face bolts with 4 simple bolts. I'd love to get back to that kind of simplicity.
    Full disclosure. I just deal with the partial (my word) hassle of the Tundra steel skid plate. As I've said before I want to have a GOOD look around when I'm down there. Just to keep an eye on things. This is one of the HUGE BENEFITS of doing your own oil change. Another part of the "peace of mind" that comes from self performing.
    15whtrd likes this.
  26. May 16, 2019 at 7:04 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    True but if you aren’t dragging offroad an RCI is extreme overkill
    Rica25[QUOTED] and Mountun Goat like this.
  27. May 16, 2019 at 7:10 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    If oil changes suck, a guy could just not change oil. I seemed to get away with like 30k oil changes in my old beater Camry haha.
    Y0TA PR0 and Rica25 like this.
  28. May 16, 2019 at 11:08 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Mine also but I like that it is there. Bouncing rocks from 18 wheelers, chunks of 4x4 wood bouncing around, things like that. Not common but possible.
    RitcheyRch[QUOTED] likes this.
  29. May 16, 2019 at 11:25 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Me too, never pass up an opportunity!
  30. May 16, 2019 at 11:34 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    RCI skid plate lol talk about buying a $300 solution where no problem exists.
    what is so difficult about this stupid skid plate? it's like 6 little bolts. You don't even have to remove the skid plate, it's made to hang down off its hooks. If you do remove it (i do) the entire process of pulling it off and putting it back takes 2 minutes.
    a tacoma oil change will spoil anyone...
    nuclearlemon, 15whtrd and Rica25 like this.
