Oil change
Discussion in '2nd Gen Tundras (2007-2013)' started by SlickRick2013Tundra, Sep 6, 2016.
  1. Sep 6, 2016 at 10:25 AM
    SlickRick2013Tundra
    SlickRick2013Tundra [OP] #10
    Rick
    Mandeville, LA
    13 TRD CM MGM 4x4
    Toytech Boss 3in Lift kit Iron Cross side step TRD Sway Bar TRD Cold Air Intake Blacked out Badges Blacked out front and rear bumpers
    Isn't 0w20 too light for oil? Shouldn't it be at least a 10w30?
  2. Sep 6, 2016 at 11:23 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 70mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    Depends upon what you're using it for. If you're thinking of putting it in your engine, look to see what your owner's manual says. Mine recommends it.
    ColoradoTJ likes this.
  3. Sep 6, 2016 at 11:42 AM
    Mike Tread lightly.
    south carolina
    The clearance/tolerance in today's engines are tighter than ever before..
    start up is the biggest to oil.. too thick of a oil will damage the engine over time...
    0w 20 is fine as long as you meet the guide lines set for owners book for 0w20... I hate to break it to you 0w20 is all but normal anymore for new cars and trucks.
