Oil change
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by David18921, May 29, 2023.
  1. May 29, 2023 at 7:14 PM
    David18921
    David18921 [OP] New Member
    I’m looking at a 2020 5.7 v8, it has 44000 miles on it and was services pretty regularly, except for one gap in the carfax where it looks like the old owner went 14000 miles with no oil change, then he went 10000, other than that though it was done every 5000. Would you guys avoid this truck?
  2. May 29, 2023 at 7:20 PM
    No
    Synthetic can also be done every 10k or so. I always did mine every 5k regardless
    JLS in WA likes this.
  3. May 29, 2023 at 7:22 PM
    David18921
    What about the one time where he went 14000? Is that not a little excessive?
  4. May 29, 2023 at 7:22 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Based on just that? No.
  5. May 29, 2023 at 7:24 PM
    wh4x4
    wh4x4 New Member
    10k is the standard interval on the 2020. Check for an oil leaks, any premature rust. With all the flooding lately in various parts of the country, check for signs of flooding in the engine bay and floor boards. Otherwise if a good price, go for it!
    Wynnded likes this.
  6. May 29, 2023 at 7:27 PM
    David18921
    Ok, the only thing that I would be worried about would be that affecting the longevity of the motor, if it was run on dirty oil for 4000 miles (the time he went 14000) could that damage the motor long term? I just want my engine to last well into 200000 like it should
  7. May 29, 2023 at 7:27 PM
    wh4x4
    wh4x4 New Member
    I wouldn't rule it out because of that, not at all a deal breaker. The fact that you see regular service, frankly infers to me the owner was diligent and took care of it.
  8. May 29, 2023 at 7:35 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The oil can't really be thought of as good from 0-10000 miles and suddenly bad from 10000-14000. There's no real way to know what actually happened, it's entirely possible that it was serviced but the documentation didn't to through, or the owner decided to do the service themselves on that one occasion.
    wh4x4 and JLS in WA like this.
  9. May 29, 2023 at 7:38 PM
    EddieBolt
    EddieBolt New Member
    David
    2020 CM SR5 4x4
    I'd still consider it if it's a good deal. Not a dealbreaker.
  10. May 29, 2023 at 7:40 PM
    David18921
    The only reason I don’t think he did it off the books is because he seemed to take it to the dealer for all the maintenance otherwise, and this is the second owner. This one seemed to pish off maintenance a little more than the last one
  11. May 29, 2023 at 7:43 PM
    David18921
    As long as the engine still has a chance of lasting and being dependable that’s all I care about. That’s the only reason I’m a fan of Toyotas and I want this one to last as long as possible. I’m not super mechanically inclined but obviously I have common sense and know that oil changes are important. So is it possible that running dirty oil for a few thousand miles could affect that longevity that toyota engines are known for?
  12. May 29, 2023 at 7:44 PM
    David18921
    Other than that the service records are clean and the truck seems to run like a top
