Oil Change Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra14Platinum, Feb 15, 2020.
  1. Feb 15, 2020 at 6:21 AM
    Tundra14Platinum
    Tundra14Platinum [OP] I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    Does or did your Tundra, have or come with this metal washer? The Tundra is not new to me had it for about 2 1/2yrs. The metal washer was there when I changed the oil the first time. I did not do the first two or three oil changes. I know the blue gasket gets changed every time I change oil. Thank you. 20200215_091147.jpg
  2. Feb 15, 2020 at 6:32 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    No Toyota uses a bare metal washer like that. Toyota oil drain plug gaskets are aluminum faced with gasket material on each side. That looks like one on the right. Toss that bare metal washer, ID is too large anyway.
    Tundra14Platinum[OP] likes this.
  3. Feb 15, 2020 at 6:44 AM
    Tundra14Platinum
    Thank you. And do you guy's put a little oil on the blue gasket so it does not stick to the oil pan? Tossed metal washer.
  4. Feb 15, 2020 at 7:36 AM
    JohnLakeman
    I never have. The drain plug washer is different than an o-ring, where there may be a full turn or more with the dry rubber o-ring trying to adhere to the sealed surfaces. Applying a oil coating wouldn't hurt anything if you want to do that, but may not help you with "sticking" to the pan either. Sticking to the pan isn't usually a big problem, you just have to be sure you remove the old gasket.
  5. Feb 15, 2020 at 7:40 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    For the OP's consideration: get the heck out of the stock oil pan drain bolt business. And install a Fumoto drain valve. On the Life Simplification Scale = 100!!!!
    http://fumotousa.com/
