Oil Change on the 2015 5.7
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by gosolo, Jun 3, 2017.
  1. Jun 3, 2017 at 7:17 PM
    gosolo
    gosolo [OP] You Don’t Know Who I Am But I Know Where You Live
    Ray (or maybe Dale)
    NW Oregon
    I have spent most of the last 3 hours searching for information on changing the oil. I'm sure i previously have seen in depth threads but can not locate them. I found some utube information that looks pretty good but I don't trust it completely. Now that the Toyota care is history I want to do this and do it right and not have a mess. I would appreciate any solid information and solutions with links and part numbers for the upgrades and tools.
    Thanks in advance!
  2. Jun 3, 2017 at 7:54 PM
    beaver6713
    beaver6713 2015 CM
    Kleve
    Safford Arizona
    2015 Tundra CM
    6 inch Pro Comp lift. OME rear springs with Coach Builder +3 shackles. Coach Builder tie rod ends. ICON 2.5 front and rear shocks with remote res. ICON Hyd bump stops. 35" Nitto Trail Grapplers on 18" fuel rims. Kenwood DNX 892 head unit with JL audio and RF amp pushing 2 Image Dynamics idq10 subs. SABM, S POD switches for 42" in bumper and 32" behind grille LED light bars. Full interior and exterior LED conversion. LED flush mount back up lights in rear bumper. Valentine one radar detector. V Leds under dash and seats foot well lighting. TRD pro head lights and grille. Full AJT dash kit
  3. Jun 3, 2017 at 8:05 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  4. Jun 3, 2017 at 8:14 PM
    veg hed
    veg hed Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    I'm about ready to do this...How many quarts of oil does the 5.7 take?
  5. Jun 4, 2017 at 5:12 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    8 quarts.
  6. Jun 4, 2017 at 5:15 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    If you buy a yota genuine filter (I do, hear they are truly better than aftermarket) they come with a plastic cartridge drain. It's cheap but will get the job done.
  7. Jun 4, 2017 at 5:35 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    So, all of the after market filters are substandard?
  8. Jun 4, 2017 at 8:26 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I just got an OEM filter for 5 bucks at the dealer. He threw in a couple crush washers too
  9. Jun 4, 2017 at 1:53 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    According to a video of multiple filters that were cut open brand new yes. OEM has more surface area for filtering. Look up oil filter comparison videos on YouTube.
  10. Jun 4, 2017 at 2:14 PM
    saadi996tt
    saadi996tt New Member
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Limo Tint (all around), Weather Tech Floor Mats, Morimoto XB LED Fog Lights, Nerf Bars, Paragon Bed cover (Paint to match), Bilstein 6112’s (F) & 5100’s (R), Wireless iPhone charger, TRD rear sway bar, swing case, led bed lights, pop-n-lock...
    I have used the TRD oil filters for the past 3 oil changes and they look really sturdy. Fairly inexpensive from Amazon and I have them in 2 days with prime.
    15whtrd likes this.
  11. Jun 4, 2017 at 2:20 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I'm getting the tools listed above and will order filters. Do you know the part #?
  12. Jun 4, 2017 at 4:43 PM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
  13. Jun 4, 2017 at 4:52 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Thank you
  14. Jun 4, 2017 at 5:55 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    For the 1st oil change before installing the no-mess drain plug, make sure you have a tall enough drain bucket. With 37's and a small lift my oil pan is pretty far up there, and my 1st go round I used a regular oil drain pan and the oil came shooting out and made a mess off the garage floor and tire/wheel etc. Use a 5 gal bucket if you can get it under there. Good luck with all............
  15. Jun 4, 2017 at 6:03 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I'm trading a water tank for this oil change to a guy who has a mobile service and has been doing work on my wife's Taco for years. He's a good guy but I'm not sure he knows this truck or will have the right stuff. I'm going to be ready to take over if need be. If he's all good, I save my stuff for next time.
  16. Jun 4, 2017 at 10:00 PM
    This piece connects after taking oil filter cap off you screw this on and has a valve you turn or twist it drains oil from filter to drain pan no mess also if you order the fumoto valve be sure to get hose as well to connect hose to valve to drain pan no mess
    Watt maker likes this.
  17. Jun 4, 2017 at 10:08 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Thank you sir, you are handier than Velcro!
  18. Jun 5, 2017 at 8:32 AM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    I got my fumoto valve and my filter hose attachment not too long ago. this coming weekend will be oil change time and I've never been so excited to change oil before in my life. I gotta get a hose for my fumoto though, anyone know off the top of their head the diameter I need?
  19. Jun 5, 2017 at 8:43 AM
    The fumoto website sells it...im sorry not sure on size or you can take valve with you to local hardware store or home depot or lowes find right size or auto store n get black hose find size n cut to length
  20. Jun 5, 2017 at 8:52 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    Try oreily auto parts for hose if u have one near u
  21. Jun 5, 2017 at 8:59 AM
    TNTundra08
    Blake
    2008 DC 4x4
    I have all of those stores around me. I'll just bring the valve with me, no biggie. while I was in here chatting I just thought "hmm, I don't have the hose yet" haha
  22. Jun 5, 2017 at 9:11 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @TNTundra08 let me know what you learn and if you have any suggestions or surprises!
  23. Jun 5, 2017 at 10:58 AM
    Let me know size n length when ya get it
  24. Feb 27, 2018 at 9:47 AM
    15whtrd
    15whtrd Mr. Blonde
    Reviving an old thread. I want to buy the fumoto valve. Just concerned with the depth of the threads going into the oil pan. I don’t like leaving any oil in the pan. Concerned that there will be a small amount of oil left if the threads are too long. I have been known to dump a little fresh oil in at each oil change with the drain plug removed. I always picture sludge buildup in the bottom of the pan. Anyone have any input on this?
    It seems that on almost every car I’ve changed the oil on, the drain plug is situated so that small amount of oil is left behind. I don’t know why they can’t just put it at the lowest location.
  25. Feb 27, 2018 at 10:29 AM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    There was a lengthy discussion on this over at TacomaWorld a few years back. Some guys started notching their fumoto to get a full(er) drain. Post 44 at this thread: https://www.tacomaworld.com/threads/engine-oil-drain-valve-fumoto.319232/page-3
    Personally, I’m in the “anything left will be so diluted by the 7+ quarts that it won’t be an issue” camp.
  26. Mar 1, 2018 at 8:54 PM
    15whtrd
    15whtrd Mr. Blonde
    Sounds reasonable. I do lift up the driver side with the jack little bit to get a few more ounces out. I wish I could take the pan off every time and wipe it out!
  27. Mar 8, 2018 at 4:00 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Just ordered my parts from Amazon. Nothing like a little peace of mind knowing your baby is in the right hands!!!:yay::yay:
