Oil Change Items
Discussion in '2.5 Gen Tundras (2014-2021)' started by Firefly412, Mar 3, 2019.
  1. Mar 3, 2019 at 7:53 AM
    Firefly412
    Firefly412 [OP] New Member
    Robert
    2018 SR5 Double Cab
    Can anybody advise on the proper oil change items I need to do a first oil change. Vehicle is a 2018 SR5 DBL Cab with the 4.6L engine.
    I’ll need the filter adaptor wrench, oil filter kit, oil plug gasket, and oil. Not sure if I need the drain hose adaptor. I have torque wrenches.
    Thanks!
  2. Mar 3, 2019 at 8:02 AM
    VTYOTA
    VTYOTA I DECLARE BANKRUPTCY!!
    Howard
    'Merica
    2014 SS CM TRD
    I think the filter normally comes with a plastic piece that helps drain the filter housing.
    It is not “needed”, but I purchased a Fumoto F103N drain plug valve that I will install on my pan at my next oil change. I also bought the MOTIVX Oil Filter Drain Hose and the OEM metal oil filter housing + metal plug.
    Here is a thread about the Fumotos and there are also links to get the MOTIVX tools and OEM metal filter housing + plug.
    https://www.tundras.com/threads/fumoto-valves.38897/
    If you haven’t bought the oil fiter wrench, MOTIVX has the wrench and oil filter drain hose as a bundle and will be cheaper. Both seem to be high quality tools.
  3. Mar 3, 2019 at 8:34 AM
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    Assuming the oil spews out with force on the 4.6 like it does on the 5.7, id advise a piece of cardboard laud up against the inner part of the passenger front wheel. As the person above stated, i too got a Fumoto valve to install on my next oil change.
