Oil Change Issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Major, Dec 30, 2019.
  1. Jan 27, 2020 at 7:44 AM
    #61
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    I do this too (ramps). Much easier than floor jack + jack stands plus it is clear under the truck so I can scoot around at will with the creeper. At my age (70), it is the easiest method (for my Tundra as well as my wife's Sequoia).
  2. Jan 27, 2020 at 9:42 AM
    #62
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    What kind of ramps are y’all using? All I’m seeing locally are poly ramps
  3. Jan 27, 2020 at 10:27 AM
    #63
    Bergmen
    Bergmen New Member
    Ukiah, California
    I have Rhino car ramps. They are reinforced plastic and highly rated (I bought the heavy duty ones at Auto Zone). Look them up and you will see what I mean (I don't have a link).
  4. Jan 27, 2020 at 11:27 AM
    #64
    TheHutchTTU
    TheHutchTTU Wreck 'Em
    North Texas
    2020 Midnight Black Metallic TRD Pro
  5. Jan 27, 2020 at 11:32 AM
    #65
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    I bought the harbor freight ones that are the equivalent of the higher rated rhino ramps. I've used them several times already. really good quality. I still use jack stands with a double locking pin though. Even though the ramps are rated for 13,000 lbs, I like having that second layer of safety in case something would happen to the ramps. I bought the red torrin 6 ton jacks with the locking pin. I know it's all overkill for the weight rating, but you can never be too safe when you're crawling under a truck.
    wakeboarder likes this.
  6. Jan 27, 2020 at 11:34 AM
    #66
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    Patiently (not really) waiting for the jowett oil cap to say "in stock".... This week maybe?
    Bravohook likes this.
  7. Jan 27, 2020 at 12:46 PM
    #67
    WestexSBK
  8. Jan 27, 2020 at 2:07 PM
    #68
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    You'll love it, i bought one when I bought the truck with 69k miles on it and the plastic one was so tight from wherever the previous owner got the oil changed i couldn't break it open with an impact or 1/2" breaker bar.
    TIP for when you do get it. The first time you put it on put oil on the threads it will install and seal much better then throwing it all in there dry. You do use an o-ring but putting oil on the threads of the housing helps it thread on easier
  9. Jan 27, 2020 at 2:45 PM
    #69
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I read 20 also. It is not that the techs don't own it is a matter of using. After dealer put mine on to about 130 ftlbs and I complained to the service manager he claimed to have done another training session on using a torque wrench.
    BTBAKER[QUOTED] likes this.
  10. Jan 27, 2020 at 2:48 PM
    #70
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    Over use of a torque wrench is pretty prevalent on this forum. Just snug it up.
    Ronin73[QUOTED] and Johnsonman like this.
  11. Jan 27, 2020 at 2:51 PM
    #71
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Right On!
  12. Jan 27, 2020 at 4:50 PM
    #72
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    I was holding this find for myself, but have come to the conclusion I won’t move on it for a while. He was willing to ship when I talked to him.
    https://offerup.co/RbuHGe4tB3
  13. Jan 27, 2020 at 6:05 PM
    #73
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    That's a hell of deal ^^^^.
    I'm pretty sure that I paid somewhere around $150 for my Jowett with Fumoto and the socket.
    Someone get on it like a drunk Gamma Phi sorority freshman.
  14. Jan 27, 2020 at 6:15 PM
    #74
    Bravohook
    Addame
    NY
    2007 RCSB
    Cool Things
    I got mine for a little over 80 bucks with the socket and ez drain valve. He had a run of "blemished" units but I couldn't see anything wrong with it when I got it. I still would have paid full price for it tho. Its an awesome piece and I like that it is made by a small time kinda guy. And it works flawlessly
  15. Jan 27, 2020 at 6:26 PM
    #75
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    Aluminum housing, motovix tools and filter drain with fumoto valve with retaining clip was the best decision I’ve made. I just did my first oil change after installing them and loved being able to drain the oil into old 5 liter oil container from the previous oil change. It’s such a cleaner oil change and I eventually got over being worried about the fumoto. Very glade I switched to it.
  16. Jan 27, 2020 at 6:38 PM
    #76
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    I had Fumotos on Tacomas and now on Tundra. On the Tacomas they are protected by skid but more exposed on Tundra which kind of concerned me. No problems so far. For $150 I can deal with the oil on my hands with the drain hose. I have boxes of latex gloves.
  17. Jan 27, 2020 at 7:34 PM
    #77
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Wow! My research has shown 18ft lbs on canister and 9 on the cap.
  18. Jan 30, 2020 at 11:21 AM
    #78
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    These are back in STOCK!!!
  19. Jan 30, 2020 at 11:27 AM
    #79
    18" TRD Off Road Wheels
    Thank you for this head's up. Still says out of stock, but at least I could put the order in.
  20. Jan 30, 2020 at 11:29 AM
    #80
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    I went to his web site and it quotes a price of $119
  21. Jan 30, 2020 at 11:32 AM
    #81
    Yup. $126 if you want the valve with a nipple for a hose. Below the drop down it says they have 0 in stock but orders will be taken.
  22. Jan 30, 2020 at 1:34 PM
    #82
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    What type of canister fitting will you use? Seems the Fumoto type valve will really limit your options. I use the Motivx, so it wouldn’t work with this setup.
  23. Jan 30, 2020 at 1:40 PM
    #83
    Not sure I am understanding your question. Are you meaning the socket to remove the jowett cap? If so, Jowett sells a socket for it.
  24. Jan 30, 2020 at 1:42 PM
    #84
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    He sells an adapters for it also.
  25. Jan 30, 2020 at 2:04 PM
    #85
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Damn, now I may have to put the order in.
  26. Jan 30, 2020 at 2:06 PM
    #86
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Exactly. I call it the canister. What’s the price for the socket?
  27. Jan 30, 2020 at 2:07 PM
    #87
    Socket was $17.00.
  28. Jan 30, 2020 at 2:08 PM
    #88
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Not bad. I think I may go this route. Thank you.
  29. Feb 13, 2020 at 2:57 AM
    #89
    coTony
    Tony
    Montrose, CO
    Got mine delivered yesterday
    GODZILLA likes this.
  30. Feb 13, 2020 at 2:59 AM
    #90
    Awesome! I put an order in as soon as I saw orders were being taken. I really hope I can get it before my first oil change is due. I'd rather not have the dealership mess anything up on the truck before I make the swap.
