Oil Change Issue
Discussion in '2.5 Gen Tundras (2014-2021)' started by Major, Dec 30, 2019.
  1. Dec 31, 2019 at 1:05 PM
    specter208
    specter208 New Member
    2017 Tacoma and 2005 Tundra RGCAB
    Let that thing cool down some before you try to unscrew. I broke a friends oil canister because the thing expands when hot and the soft plastic broke from the amount torque I applied to it. Use a wrench and use some impact force to get the cap loose.
  2. Jan 1, 2020 at 10:55 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Actually got a response from Brian saying they would be available at the end of the month. :yes:
  3. Jan 1, 2020 at 10:56 AM
    Nice.:thumbsup:
    Trooper2[QUOTED] likes this.
  4. Jan 2, 2020 at 6:30 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Ok I am ready to order!!!
  5. Jan 2, 2020 at 8:59 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    It is a thing of beauty. 2 years with mine and all is perfect with the world. LOVE LOVE the Fumoto valve feature.
    Prostar 190 and Trooper2[QUOTED] like this.
  6. Jan 2, 2020 at 9:03 AM
    coTony
    Tony
    Montrose, CO
    I bought the Volvomax instead of the Fumoto, have not put it on yet but this seems to be a no brainer to replace the plastic with the metal one
  7. Jan 2, 2020 at 4:41 PM
    Tundra14Platinum
    Tundra14Platinum I love reading the CoC in my spare time
    2014 Platinum CM Sky Silver
    TRD PRO Grill/Headlights, Swaybar, Eibach
    In.
  8. Jan 2, 2020 at 5:17 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    9ft lbs to be exact. If done correctly it slides right off. The problem is the “techs” don’t own a torque wrench.
    15whtrd likes this.
  9. Jan 2, 2020 at 5:31 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    My wife's was stuck on one time. Could not get it off to save my life. Hit it with my impact driver and it came right off.
  10. Jan 2, 2020 at 6:27 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    You guys with the fumoto valves in the drain and or filter housing. Do you ever worry about something in the road hitting the switch and leaking oil? I really like the idea of them and have almost purchased before but am just too paranoid about it getting opened up and leaking oil. I only change my oil once or twice a year so it's not a huge deal either way, just is obviously nice to not even need to get the wrenches out to change the oil.
  11. Jan 2, 2020 at 6:34 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Not really. The spring loaded lever must be raised over a notched area. But if you're really worried one of these can provide extra insurance : https://www.fumotooildrainvalve.com/lc-10.html
    Luck and enjoy those Toyotas. : ^ )))
  12. Jan 2, 2020 at 7:12 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    And messy as all get out. Removing the nut and using the hose is messy enough.
  13. Jan 4, 2020 at 9:07 AM
    denver kid
    denver kid New Member
    seems like most places including toyota dealers tighten too much, also they dont lube the o-ring on oil housing. I have been using a good silicone grease to lube the o -ring on housing no problems so far still have the plastic housing. I do have the aluminum housing just have'nt put it on yet
  14. Jan 6, 2020 at 3:23 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    OK, this may be a stupid question. But I just ordered a 2020 Tundra. They will start the building the truck Jan 17, 2020 and it should arrive end Feb 2020.
    I change the oil in all my cars. So, I wanted to change the oil in my truck. I want to be sure I understand this. See the very first pic posted on this thread. I used to think that your
    Billet Oil Cap for filter was just a replacement for the silver part with the square nut. But it replaces the ENTIRE unit? Is that correct?
    I’m in when they come of back order.
  15. Jan 6, 2020 at 5:55 AM
    Trooper2
    JR
    Yes, This would replace the plastic housing completely and has an integrated drain valve.
    Also, I believe there is a new tool / wrench to purchase for removal as well.
  16. Jan 6, 2020 at 7:18 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Darn....So I have to buy a tool to remove the old filet house just ONCE. Then replace it with the Jowett Performance replacement housing Billet Oil Cap and get another tool for its removal? Anyone have a pic of the tool? Looks like the proper size deep socket may work. Unless its huge.
  17. Jan 6, 2020 at 8:41 AM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    I just did my first oil change at 5k miles. Replaced the plastic filter housing with this item https://www.amazon.com/gp/product/B008BHP68A/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    When you replace the filter housing with the aluminum one, be sure to replace the perforated tube on the aluminum one with the tube from the plastic one as you'll see that the one that comes with the aluminum housing is a lot shorter than the stock one. Just get a flathead and bend the two tabs upwards and it will twist out.
    I also thought the factory skid plate was a flimy pile of garbage so I replaced it with the trd pro skid plate. It's really nice having that oil filter access door so you don't have to take off the entire skid plate everytime.
    This is the set of tools you wanna buy to get the filter housing off, put oil in the engine and drain the oil filter
    https://www.amazon.com/gp/product/B0791MWXDC/ref=ppx_yo_dt_b_asin_title_o03_s03?ie=UTF8&psc=1
    One problem I had on my first oil change was the drain plug gasket was really stuck on the oil pan. It is an blue aluminum washer. I got it off with a screwdriver from the side making sure not to damage the oil pan at all.
    rodm1 and Rebel Tundra Man like this.
  18. Jan 6, 2020 at 12:38 PM
    Rebel Tundra Man
    Rebel Tundra Man New Member
    Tyler
    Western Kentucky
    2016 Black Limited CM
    4" RCX Lift, 20x10 Fuel Coupler's, 35x12.50x20 Nitto Ridge Grappler's, Color Match Front End, LED Bulbs, RCX Tube Steps, Green LED Underglow
    This little guy is a life saver when draining the oil filter. The fumoto valve is for the oil pan. It is a life saver also because now I can just put the drain tube down into the old oil jugs I keep around for oil changes. no mess to clean out of the pan.
    fuzzamungus and Joe333x like this.
  19. Jan 6, 2020 at 1:12 PM
    #49
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Not at all.
    1. Fumotos have 25 years of development on them. JAPANESE development.
    2. You can get a plastic/nylon retainer clip that further locks down the lever/switch. New Fumotos (I just got one for the new 2019 Highlander I just bought) now come with this clip in the deal!!!!!
    Stop worrying. Simplify your life. GO FUMOTO!!!!!
    AZBoatHauler and GODZILLA like this.
  20. Jan 6, 2020 at 9:10 PM
    #50
    Joe333x
    Joe333x Member
    Boston
    I realllllyyy want to and still may but I know I'd just be super paranoid about it so it may not simplify my life lol atleast when the drain plug is on, i know it's closed and can't open with out a wrench. I over research everything and so far your definitely right they have a very good track record and very few story about failure plus they back up their product. The one down fall I have read is that is causes the oil to flow out slowly which could cause particles that would normally flow out to remain behind and that on some models the threads sit higher in the pan than the drain so it doesn't complete drain out.
  21. Jan 6, 2020 at 10:00 PM
    #51
    OV-1794
    OV-1794 New Member
    I have it and its great to change the oil with. If you're worried about the threads you could always let the oil drain slowly until it stops and then pull the plug to see it anything else comes out.
  22. Jan 7, 2020 at 6:00 AM
    #52
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    That's actually two alleged downfalls. :D
    I consider those better reasons than an unplanned opening. Fumoto seems to have plenty of good experience in that regard. Now breaking it off on a rock while off-roading...I would consider that possibility if I off-roaded.
    The idea of a Fumoto owner removing their valve after an oil drain to measure how much oil remains in the pan is a good idea. (hint-hint). We might be surprised by how little oil actually remains: the drain hole on UR engines is not positioned well to drain the pan completely, i.e. it is above the bottom level on the angled end, maybe deliberately to reduce exposure. (Aw ****, we'll have guys pulling their oil pan to get the last few ounces out. :facepalm:)
    GODZILLA and Joe333x[QUOTED] like this.
  23. Jan 25, 2020 at 5:53 AM
    #53
    coTony
    Tony
    Montrose, CO
    Are these still going to be available this month? I have an oil change coming up and wanted to get this ordered
  24. Jan 25, 2020 at 6:17 AM
    #54
    Trooper2
    JR
    In the same situation, waiting patiently.
    I figured I would inquire again closer to end of month if not available on website.
    WILLINH likes this.
  25. Jan 26, 2020 at 6:14 AM
    #55
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    I have seen a few videos online and a lot of people use a torque wrench. Is a torque wrench necessary to oil the Tundra oil change? Can't I just do it without? Those damn things are expensive!
  26. Jan 26, 2020 at 10:25 AM
    #56
    Joe333x
    Joe333x Member
    Boston
    I've done many oil changes on different vehicles and never used a toque wrench, most mechanics won't be either. The goal is just to not over tighten it so you can get it off next time. With that said I have been meaning to get a torque wrench just because it is good to have one for torque sensitive applications.
    Ronin73[QUOTED] likes this.
  27. Jan 26, 2020 at 8:38 PM
    #57
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    I had this same issue with both my tundra and the wife’s 4Runner. With a little bit of heat from a propane torch they came right out. I haven’t changed the oil since switching to the aluminum housing but I’m quite confident I will not have any issues as I know the difference in 10lbs and 100lbs of torque.
    Joe S
  28. Jan 26, 2020 at 9:26 PM
    #58
    OV-1794
    OV-1794 New Member
    Torque wrenches are about $10-15 at Harbor Freight. I understand not all their tools are of the best quality but I'd say their hand tools are pretty decent.
  29. Jan 27, 2020 at 4:28 AM
    #59
    coTony
    Tony
    Montrose, CO
    Torque wrench should be a necessity for any garage
    Willy224 likes this.
  30. Jan 27, 2020 at 5:26 AM
    #60
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    I run my Tundra up on a set of ramps. Not only positions things very well for engine oil evacuation but gives me much appreciated extra room to maneuver around under the truck for the oil service and any other "inspections" I may want to do at the time.
