Oil change gone wrong… Drain bolt spun on
Discussion in '2.5 Gen Tundras (2014-2021)' started by newemi, Oct 10, 2021.
  1. Oct 12, 2021 at 7:58 AM
    #91
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    As in many things, 90% of the quick oil change shops ruin the reputation of the other 10%. Your brother ran a good shop. Those are hard to find. It doesn't surprise me that Toyota doesn't use impact wrenches on the oil plugs, they don't want angry customers. Customers do get a bit miffed when they hear that the oil pan has to be replaced. They get down right cranky when their car starts leaking oil from a cross threaded plug, and they tend to get stomping mad when the drain plug falls out and the lack of oil damages the engine. All in all, if I have to rely on quick change oil shops, I'll just roll it into the ditch and get it over with.
    ColoradoTJ[QUOTED] and 2mchfun like this.
  2. Oct 12, 2021 at 8:34 AM
    #92
    It’s a shame if this is how customers are treated.
  3. Oct 12, 2021 at 9:11 AM
    #93
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I haven’t seen Toyota use impacts in the few times I’ve actually used them but I definitely haven’t seen them use a torque wrench either.
    ColoradoTJ[QUOTED] and Oey12 like this.
  4. Oct 12, 2021 at 9:24 AM
    #94
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    @Randy Morton
    BTBAKER likes this.
  5. Oct 12, 2021 at 9:26 AM
    #95
    newemi
    newemi [OP] New Member
    2020 Tundra CM Ltd CB
    Impact or not, I’ve had my run ins with poor performing techs
    Had to have our 4runner skid plate replaced after a tech either cross threaded or over torqued multiple bolts.
    then later, same vehicle the tech over tightened the canister filter, to the point that I broke my filter wrench trying to remove it.
    Shark Bait likes this.
  6. Oct 12, 2021 at 9:34 AM
    #96
    coldcanuk
    coldcanuk New Member
    2021 Tundra Platinum
    Agreed.
    One more reason for me. I've never stripped an oil drain plug but it always occurs to me everytime I tighten one down that it's going to start turning easily and my stomach will turn. I've mentioned before, first thing I do to a new vehicle I get, never had a problem, appreciate it every time I use it. Japanese quality.
    Fumoto Tips:
    Put a light smear of high temp sealant on the threads along with the blue washer
    Paint pen a line marker when you're done tightening, a quick look over the years will tell you it's never moved.
    BTBAKER likes this.
  7. Oct 12, 2021 at 9:54 AM
    #97
    Randy Morton
    Randy
    Are you sure it's a dumb rumor and not an inconvenient truth? I guess it depends on which side of the impact wrench you're on.
  8. Oct 12, 2021 at 11:03 AM
    #98
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Weird because on the Fumoto site they only show B27's and a B1 as compatible with the 5.7. Where did you find the B28?
    Just looking for some reason why people are using it.
    Personally I went with the ValvoMax but had a Fumoto on my 4.7 without any issues.
  9. Oct 12, 2021 at 11:34 AM
    #99
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Same here on the oil filter cover after last free change. I had to use a 2' cheater bar and buy a new filter wrench. My neighbor had the hold my legs. I am guessing 130 ft lbs based on past experience doing front end work. I doubt they used a cheater bar to tighten it. Manager says the techs all have torque wrenches. I said you better teach them how to use them.
    WILLINH and BTBAKER like this.
  10. Oct 12, 2021 at 7:50 PM
    #100
    Shark Bait
    Shark Bait Not new anymore
    David
    2019 Platinum
    Rumor? I personally witnessed it. Lol.
    hagrid and Cock-A-Doddle-Do like this.
