Oil change gone wrong… Drain bolt spun on
Discussion in '2.5 Gen Tundras (2014-2021)' started by newemi, Oct 10, 2021.
  1. Oct 11, 2021 at 3:01 PM
    #61
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Hard Tri-Fold Tonneau Cover, OEM Bed Mat, OEM All Weather Floor Mats
    I am with you on this, especially after reading this thread. Seems this is not the only DIY project that has led to other issues through no real fault of the DIYer. And yeah I know 99% never have a problem. But my problem is I always make up that 1%!
    50Shades[QUOTED] likes this.
  2. Oct 11, 2021 at 3:01 PM
    #62
    50Shades
    50Shades Sin City Tundras
    J
    West Coast
    2021 Tundra SR5 CrewMax Trail Edition 4x4
    alright alright fine. I will look into this :D
    GODZILLA[QUOTED] likes this.
  3. Oct 11, 2021 at 3:16 PM
    #63
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    Meh, just get some JB weld and seal it all up. Sorry for your troubles and I know the sinking feeling of having issues with something so new.
    snivilous and 50Shades like this.
  4. Oct 11, 2021 at 3:20 PM
    #64
    xJuice
    xJuice This guy...
    Josh
    DFW, TX
    '19 MGM DC SR5 4.6 TSS
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill, Remote Start, One-touch Auto Windows
    Too much ugga dugga for brass threads. Final answer.
  5. Oct 11, 2021 at 3:23 PM
    #65
    18" TRD Off Road Wheels
    But this one looks like it was cross threaded, over tightened, or the wrong thread pattern. Not a fault with the product necessarily.
  6. Oct 11, 2021 at 3:35 PM
    #66
    50Shades
    J
    West Coast
    they used the german torque wrench, "gud n tite"
    WILLINH, 2mchfun and xJuice[QUOTED] like this.
  7. Oct 11, 2021 at 3:36 PM
    #67
    Again, not about time. Pretty sure the oil drains faster without the valve, or close to. It's about the lack of mess. This is an unfortunate event for sure, but it's also an extreme case and not the norm. Almost no one has issues with the Fumotos and they are used by TONS of cars and trucks.
    15whtrd and 50Shades like this.
  8. Oct 11, 2021 at 3:56 PM
    #68
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    Try draining the oil with the RCI plate in place. I had to soak up a cup of oil that drizzled onto it. The Tundra can be a messy oil change especially with the drain bolt angled towards the front tire, ask me how I know.
  9. Oct 11, 2021 at 3:57 PM
    #69
    I can understand where you're coming from, but to put the risk in perspective I have some questions. What kind of water heater do you have in your home? Do you have a shut off valve on the inlet pipe? That has the same, or more, risk of malfunction as a fumoto valve. They are extremely simple.
    Your level of caution also indicates you would not be cross threading, over tightening, or installing without checking your threads because you would be being super super careful. I'm as capable a car mechanic as a half trained monkey in a diaper (and the diaper is the important part of that equation), and I installed it with no issue. It took a moment or two to get the threads to line up, but it was not difficult.
    As far as the OP's situation, it sucks, but accidents happen. The drain bolt can be cross threaded or over tightened for the same result as well, so by doing a one time install of a valve you are eliminating all those future chances of issues with removal and installs. Now, that only counts if you are keeping the truck long term. If you trade of/switch rigs every 2-5 years, maybe not a big deal.
    I may be a little biased, because I hate wearing oil. :laughing:
    Ely010606, JLS in WA, BTBAKER and 2 others like this.
  10. Oct 11, 2021 at 4:16 PM
    #70
    a_double
    a_double New Member
    Is the B27 or B28 stamp significant in terms of the correct part? I'm going to install the F133N with B28 stamped and just want to make sure it's the right part.
    On another note, Tundra owners need a specific oil funnel/catch setup that goes inboard enough to catch the oil that would drip onto skid, and outboard enough and deep to catch the drain rate and prevent splash on wheel, with adjustable elevation to slide under the pan with just enough room to get your hand in there and undo the drain plug.
    I'd buy one and would forego the Fumoto.
  11. Oct 11, 2021 at 5:15 PM
    #71
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    ^^THIS is exactly what happened ^^
  12. Oct 11, 2021 at 5:20 PM
    #72
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    sorry to hear the news Mike. I’m just down the hill in Redlands, hope the dealer has your pan.
  13. Oct 11, 2021 at 5:24 PM
    #73
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    The risk of using the Fumoto valve is only marginally greater than the risk of crossthreading the OEM plug. And the benefit is real, a cleaner oil change saves cleanup time even if the oil change itself is no faster. So the thousands of people who have benefited from the Fumoto have shown the benefit/risk is very good. I don't know exactly what happened with the OP. It sounds like he either crossthreaded it (could have done the same thing with them OEM plug), he overtightened it, or he had the wrong model.
    There is absolutely no reason to criticize such a helpful a popular tool just because you don't want to try it. I have it on my vehicles and have seen that it definitely saves time and helps to avoid the mess.
    15whtrd likes this.
  14. Oct 11, 2021 at 5:30 PM
    #74
    Fair enough, but with the skid, that valve is well protected. I even got the one with the long nipple (insert Beavis and Butthead snickering here) and it's got great coverage from the skid. It'd be mildly difficult for me to intentionally damage the valve swinging a hammer, so I'm ok with it's odds vs inanimate objects.
    Still, nothing wrong with not using the valve. Perk to having your own truck is that you can build it as you like.
    Cock-A-Doddle-Do likes this.
  15. Oct 11, 2021 at 5:39 PM
    #75
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    I just purchased a ValvoMax to put on mine (insert Beavis and Butthead snickering here)....
    glowblue and Rodtheviking like this.
  16. Oct 11, 2021 at 5:42 PM
    #76
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    15ftlb isn't much, I actually bought a little torque wrench at Oreillys for this.
  17. Oct 11, 2021 at 5:54 PM
    #77
    Cock-A-Doddle-Do
    Brett
    Cypress, Texas
    Ft Lb is determined by bolt size & bolt head identification, I'm sure the Fumoto guys did their homework when they calculated the required Ft Lbs for the valve in question...I tend to have the attitude of "Tighten any bolt as tight as you can get it" but that way of thinking is definitely not the best for all applications
    NewImprovedRon likes this.
  18. Oct 11, 2021 at 6:06 PM
    #78
    crewmaxlmt
    scott
    Definitely not for brass. If you don’t have ft. Lbs specs for brass, snug it up and then give it just a little bit more. Kinda like a heavy snug. There is a reason why I love machining 360 brass and it is not for the scrap metal value; well maybe a little.
    2mchfun likes this.
  19. Oct 11, 2021 at 6:15 PM
    #79
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    Agree.
  20. Oct 11, 2021 at 6:19 PM
    #80
    LuvCRVs
    LuvCRVs New Member
    San Antonio
    2021 TRD Sport
    And it is likely you don't fiddle with your water heater inlet valve 2-3 times a year. I have lived in my bought new house for 14 years. I have turned off that inlet valve exactly once. And a plumber turned if off exactly once.
    BTBAKER likes this.
  21. Oct 11, 2021 at 6:37 PM
    #81
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Fumoto valves are an outstanding product and I would never go back. Anyone who has changed oil on the 5.7L engine knows that shit comes out like a rocket. This was simply bad luck for the OP and I feel bad for him.
    But, it could easily happen with the standard drain bolt which is coming out and going back in WAY more times than the one time that Fumoto goes in so I’d argue the odds are a lot worse for this scenario with the standard drain bolt.
    I was a bit skeptical at first but I did thorough homework and I feel 100 percent confident in the Fumoto performance. I literally have never had an easier oil change. I don’t spill a drop.
    Just added one to the Wifes 2020 Highlander. I needed a cheater to get the filter housing off thanks to the dealer dipshits.
    Crows feet work great for torquing the Fumoto to spec.
    glowblue, 15whtrd and GODZILLA like this.
  22. Oct 11, 2021 at 6:40 PM
    #82
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Screw a nut on both to check threads. Having a Fumoto valve eliminates the risk of stripping the threads in the pan. This in addition to being cleaner.
    15whtrd and BTBAKER like this.
  23. Oct 11, 2021 at 7:25 PM
    #83
    crewmaxlmt
    scott
    It might be a standard metric thread but I would not be surprised if it is an odd ball being that it is a drain plug. Your typical nuts and bolts are almost always a standard metric thread. But when you get into things like drain plugs and such, the part becomes custom to the manufacture and the engineers can do what they want.
    You are probably right though. I am just a little pessimistic because of what I see from day to day. For example, I have one customer that will design a part with a .235”-28 thread to throw of after market suppliers.
  24. Oct 11, 2021 at 8:09 PM
    #84
    newemi
    newemi [OP] New Member
    2020 Tundra CM Ltd CB
    Wow didn’t realize I was starting a fomo fight
    … haha!
    8pm update: taking too much time as I have an obligation to kids and spouse too :)
    New oil pan is installed. Hopeful the liquid gasket sealed well :fingerscrossed:
    I’ll concede that this was probably a user error. I installed the fomo with a 10” crescent wrench. I didn’t think I was over tightening it, but that last quarter round to get it aligned was likely the expression of evil demons. Lesson learned.
    That said, I’ll still support fomo. Yes it was a headache, but this could just as easily happen with a regular drain bolt. For the ease and cleanliness, I’ll run with fomo.
  25. Oct 11, 2021 at 9:03 PM
    #85
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Pretty confident the torque spec is 18ft lbs. I would follow that spec using a crows foot and torque wrench.
    JLS in WA likes this.
  26. Oct 12, 2021 at 5:41 AM
    #86
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    First, sorry that you had to replace the oil pan. I'm sure it was frustrating.
    Second, I am glad to hear that it was likely not a problem with the welds on the original oil pan. It would not be fun if I had to worry about the bung coming loose every time I drained the oil.
    Ely010606 and Oey12 like this.
  27. Oct 12, 2021 at 6:12 AM
    #87
    2mchfun
    FWIW, oil vac, no need to ever mess with drain plug or valve. :thumbsup:
    Katblackdiesel likes this.
  28. Oct 12, 2021 at 6:47 AM
    #88
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    The notch in the bung is the result of bean counters at corporate and ratified by former Chrysler engineer/curmudgeon Mike Sweers.
    Clemsonman14, Oey12 and 2mchfun like this.
  29. Oct 12, 2021 at 7:10 AM
    #89
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    How do you think the quick oil change places remove and replace the drain plug? Impact out, then impact back in. Get the plug out, drain most of the oil, put the plug back in, fill it with whatever oil like swill was on sale that month, get your money, rinse, lather, and repeat. If the drain plug is stripped or cross-threaded, it must have been damaged by the previous oil change company, they couldn't have made that mistake. You don't think that 10 minute oil changes are being done by highly trained professional oil technicians, did you?
    Katblackdiesel and 2mchfun like this.
  30. Oct 12, 2021 at 7:25 AM
    #90
    My brother ran a quick lube center for years. They never used air ratchets. He still had to replace oil pans and engines from time to time due to overtorquing.
    I also worked for Toyota in the maintenance shop. They never used air tools either.
    Guess things have changed?
    Ely010606, WILLINH, BTBAKER and 2 others like this.
