oil change and questions?
Discussion in '2.5 Gen Tundras (2014-2021)' started by usmealgle, Dec 28, 2020.
  1. Dec 28, 2020 at 5:18 PM
    usmealgle
    usmealgle [OP] New Member
    orjan
    White 2017 Tundra Limited CrewMaxx
    Folks i have a 2017 Limited Crewmax 5.7 and i purchased this early this year with 30,000 miles, its about to hit 40,000 and have a few questions. i have always changed my own oil so if i go that route what oil should i use and filter and is there anything else to changing oil than a normal vehicle? Also, if i take it to the dealership what should i expect to be charged for a standard or regular oil change?
    if i have left anything out please let me know.
    Thank you
  2. Dec 28, 2020 at 6:12 PM
    I use Mobil 1 0W-20 Synthetic. 0W-20 synthetic is what it calls for. I use either a K&N or Toyota oil filter, both are really inexpensive. The plastic tabs on the oil filter housing do tend to break off, so many of us have switched over to the aluminum housing. You do have to swap the center tube over from the plastic to the metal housing. Its really easy. I'll link the new housing for you.
    https://www.amazon.com/Genuine-Toyo...&keywords=(15620-31060)&qid=1609208078&sr=8-3
    15whtrd, WILLINH, JLS in WA and 4 others like this.
  3. Dec 28, 2020 at 6:25 PM
    usmealgle
    orjan
    I hate to ask but what is the link to above? Is this something that has to be replaced that I’m not aware of?
  4. Dec 28, 2020 at 6:29 PM
    SShooterZ
    SShooterZ New Member
    It’s basically an aluminum, hence stronger, version of the plastic cap on the oil filter that comes from the factory.
    WILLINH and Tundra234 like this.
  5. Dec 28, 2020 at 6:29 PM
    truckmax
    truckmax New Member
    Max
    Corona, CA
    2016 SR5 TRD CM 4x4
    LED lights,Rear sway,tint,cover,liner,cat protector,skid,running boards,mats,pedal commander,tint, and $$$ etc etc.
    [Also, if i take it to the dealership what should i expect to be charged for a standard or regular oil change?
    Besides being charged $60-100, you should potentially expect a lot of other issues, depending on the dealership mechanics, I would do my own oil changes as you have indicated you have in the past, you be $$$$ ahead of the game, and have the knowledge it has been done properly.
    Because I and most likely many others can tell you horror stories, about a simple thing as an oil change and what went wrong.
    Welcome to the board, you gonna like it.
    The link question:
    Genuine Toyota 15620-31060 Oil Filter Cap Assembly
    Brand: TOYOTA
    1,018 ratings
    | 443 answered questions
    Price: $33.99 & FREE Shipping
    Get a $100 Amazon.com Gift Card upon approval for the Amazon Business American Express Card. Terms apply.
    Brand TOYOTA
    Product Grade Performance Part
    Item Dimensions LxWxH 4.7 x 4.5 x 4.3 inches
    Item Weight 0.06 Pounds
    About this item
    • And Vehicle Specific
    • Manufacturer Warranty
    • Toyota Quality Assured
    • OEM, Not After Market
    • Vehicle Specific
    See more product details
    Compare with similar items
    New (11) from$33.98 + FREE Shipping
    Amazon Business:
    Over 100 million products at business-only prices. Get a FREE business account >>>
    coldcanuk likes this.
  6. Dec 28, 2020 at 6:34 PM
    usmealgle
    orjan
    Thank your for the quick response
    Yes I like doing my own changes as I know what’s been done.
  7. Dec 28, 2020 at 6:43 PM
    usmealgle
    orjan
    Ok one more question, how many quarts do you guys use?
  8. Dec 28, 2020 at 6:44 PM
    7.5 if I recall correctly.
    usmealgle[QUOTED][OP] likes this.
  9. Dec 28, 2020 at 6:45 PM
    SShooterZ
    7.9 I think for a 2017.
  10. Dec 28, 2020 at 6:47 PM
    KillaahCam
    KillaahCam New Member
    Cameron
    North East Texas
    2014 MGM 1794 Crewmax 4x4
    It uses 7.9 qts. Including the filter capacity. Torque specs are on the oil filter housing.
    usmealgle[OP] likes this.
  11. Dec 28, 2020 at 8:03 PM
    Zero One Actual
    Doesn’t it matter if he has Flex or non flex also? I think they take different amounts. I also “think” I read that in another thread. Let me see if I can find a link.
  12. Dec 29, 2020 at 5:22 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    8.5 qt in the manual and in real world.
  13. Dec 29, 2020 at 5:42 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Toyota says 5k for flex but it is a CYA assuming you run ethanol. If a dealership did last oil change assume the oil filter cap is over tightened. If so you might tear up the plastic one so just get the metal one. Also get the filter drain hose and maybe a fumoto valve for future changes.
    SShooterZ and usmealgle[OP] like this.
  14. Dec 29, 2020 at 1:45 PM
    SShooterZ
    There’s a nice package on Amazon that includes these accessories.
    https://www.amazon.com/dp/B0791MWXDC/ref=cm_sw_em_r_mt_dp_ln66Fb168F5GF?_encoding=UTF8&psc=1
    jhardy1979 and Joe333x like this.
  15. Dec 29, 2020 at 1:55 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    The motovix package here is great, I have it and makes draining the oil from the filter a breeze. Also as far as the metal cap goes, as long as its not over tightened the plastic one works fine, people tend of over tighten them and then break them trying to get them off so if you do it yourself with the plastic one just don't over tighten it. I personally run Shell Rotella 5w30 Gas Truck oil. The 5w30 quiets down the engine.
  16. Dec 29, 2020 at 6:17 PM
    ChrisLopez
    ChrisLopez New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
    Also replace the washer on the bolt. Learned that the hard way
  17. Dec 29, 2020 at 6:33 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    I have a 2017 5.7L and have put 8 quarts. I also change the filter each time since the price is cheap. I change every 5k miles. I swapped over to the aluminum filter housing recently. I've had the fumoto valve on mine with the nipple and hook a hose to it and drain straight into a big jug. It drains a lil slower, but I do the other stuff while that drains so it's no issues. Get the filters on Amazon in a pack of 5 or 10. Fumoto valve in amazon too. If interested, look on my build in my signature since i have it linked there.
  18. Dec 29, 2020 at 6:40 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    And you can get other "bottoms" for the funnel from Motivx that fit other cars. I have one for my son's Accord as well as an adapter for my wife's Sienna which isn't threaded, but has a half-turn cap. A fixed funnel is so much easier when you're pouring from a 5qt jug.
    SShooterZ[QUOTED] likes this.
  19. Dec 29, 2020 at 6:55 PM
    Joe333x
    Joe333x Member
    Boston
    What was the hard way? I leave mine since it's stuck and isn't a crush washer anyways.
  20. Dec 29, 2020 at 7:14 PM
    ChrisLopez
    Christian
    Chicago,Illinois
    On my 18 crew max it was leaking from the drain plug after I did my oil change. I thought I might of not tighten it enough and when I checked it was. I had to order some from Toyota and they said to replace the washer with every oil change. Had to re drain the oil replace the washer and leak was fixed. It’s like a piece of cardboard washer not a metal one.
    TILLY likes this.
  21. Dec 29, 2020 at 7:23 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    There was also reports of some knock-off washers being sold on E-bay and Amazon that had sealant on them that would dissolve and then leak. Make sure the washers you get are indeed from Toyota.
  22. Dec 29, 2020 at 7:33 PM
    Joe333x
    Joe333x Member
    Boston
    Its metal with a blue coating. Many people, like myself have had them stick to the drain pan. Unlike some who have risk damaging their pan trying to scrape it off, i just left it. So far no issues, i do have replacements if some day it decides to come off though.
  23. Dec 29, 2020 at 7:40 PM
    ChrisLopez
    Christian
    Chicago,Illinois
    I work at a body shop so I do order them from Toyota. They did mention of possible sticking to the drain pan so they recommend to replace with every oil change to avoid any issues. I bought my truck used last year and it happened on my first oil change. Haven’t ran into any issue after doing it myself.
  24. Dec 29, 2020 at 7:59 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    8 quarts of 0w-20 with a Toyota filter. I run synthetic for added assurance.
    Zero One Actual and SShooterZ like this.
  25. Dec 29, 2020 at 9:42 PM
    Toolaholic
    Toolaholic New Member
    David
    2021 black tundra SR5 SX 4x4
    TRD rear sway bar
    According to my Haynes tundra manual 2009-2017 7.9 quarts with filter.. 2018+ 8.5 quarts with filter, 7.9 w/o filter replacement. I can verify the 8.5 with filter /7.9 with out as I just bought a 2021 tundra and its in owners manual
    SShooterZ likes this.
  26. Dec 30, 2020 at 6:33 AM
    jarela
    jarela New Member
    Just changed oil-filter yesterday, 2016 5.7, took 8.5 qrts.
    Ronin73 likes this.
  27. Dec 30, 2020 at 7:05 AM
    ItsNickROFL
    ItsNickROFL New Member
    Nick
    2020 SR5 Tundra CrewMax
    Intake, exhaust, interior
    My 2020 calls for 8.5 quarts of 0w-20
    Ronin73 likes this.
  28. Dec 30, 2020 at 7:30 AM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    I bought the Motiv kit from Amazon, the aluminum filter housing and Fumoto valve. Will do own oil and filter changes every 5k miles. Only did the first one so far, about 8.5 quarts filled truck to almost high line on dipstick.
    ItsNickROFL[QUOTED] likes this.
  29. Dec 30, 2020 at 12:38 PM
    ItsNickROFL
    Nick
    I wish I had the valve. I still might buy it. I bought their filter housing wrench and it’s a very very quality made tool. Does your oil pressure gauge sit dead middle after the truck is warmed up to operating temperature? I noticed it’s ever so slightly not in the middle and it drives me nuts. Dipstick says I’m perfectly fine and I know I am it took about 8.5.
  30. Dec 30, 2020 at 2:05 PM
    RickPlatinum2020
    Rick
    Eastern PA
    At highway speed, pressure gauge slightly over half, slightly under when idling. Hope that helps.
