Oil Catch Can
Discussion in 'General Tundra Discussion' started by nk1794, Mar 15, 2018.
  1. Mar 15, 2018 at 10:19 PM
    #91
    15whtrd
    15whtrd Mr. Blonde
    I do. I really liked it on my Tbss. It was weirdly satisfying knowing you were keeping all that oil out of the intake system.
    My Tbss was high compression and would ping sometimes with the tune i had. I added the can and cooler thermostat trying to combat this.
    nk1794[QUOTED][OP] likes this.
  2. Mar 15, 2018 at 10:23 PM
    #92
    nk1794
    nk1794 [OP] Always torque to spec
    San Jose, CA
    Whats the worst thing that could happened beside potentially voiding the warranty? if it throws up some code we just undo everything and clear it. I dont think it will cause any serious damage.
    15whtrd[QUOTED] likes this.
  3. Mar 15, 2018 at 10:26 PM
    #93
    nk1794
    San Jose, CA
    We’ll just blame Connor for drawing bad diagram if it doesnt work.
    Thegr8punkin and 15whtrd like this.
  4. Mar 15, 2018 at 10:29 PM
    #94
    nk1794
    San Jose, CA
    Nothing ventured nothing gained. :)
    15whtrd likes this.
  5. Mar 15, 2018 at 10:34 PM
    #95
    15whtrd
    15whtrd Mr. Blonde
    I still like 2 separate can idea. Or leaving the crankcase alone and just doing the one off the vavle covers. The crankcase seems more for boosted setups with a lot of blow-by.
  6. Mar 15, 2018 at 10:37 PM
    #96
    nk1794
    San Jose, CA
    Im thinking just try the valve covers for now.
  7. Mar 15, 2018 at 10:40 PM
    #97
    nk1794
    San Jose, CA
    is there a build page for your 4Runner mod?
    15whtrd likes this.
  8. Mar 15, 2018 at 10:44 PM
    #98
    15whtrd
    15whtrd Mr. Blonde
    Addig
    I don’t see how it could void warranty. But that’s why I wouldn’t want to change the routings of the original design. Just intercept, catch, prevent excess oil from being burned off. Then recycle it instead of burn it off into the air.
  9. Mar 15, 2018 at 10:45 PM
    #99
    nk1794
    San Jose, CA
    True
  10. Mar 15, 2018 at 11:05 PM
    #100
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    How easy was the install? I've been meaning to buy that kit.
  11. Mar 16, 2018 at 1:05 AM
    #101
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
  12. Mar 16, 2018 at 1:06 AM
    #102
    LEKS
    Makaha
    Very easy. Instructions were great
    nk1794[OP] likes this.
  13. Mar 16, 2018 at 6:21 AM
    #103
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I am running the ADD W1 catch can on my 2016. Used the same one on my 2005 Tundra. Works great. Empty it every oil change. It's amazing the amount of vapor turned oil it collects.
    nk1794[OP] and 15whtrd like this.
  14. Mar 16, 2018 at 6:28 AM
    #104
    nk1794
    San Jose, CA
    Awesome! Do you have any pictures? It would be great to see how it’s hooked up.
  15. Mar 16, 2018 at 7:00 AM
    #105
    Tundradrenalin
    Virginia Beach, VA
    3/8" SAE R9 hose wrapped in thermotec heat shield. Spliced the PCV hose in the middle, attached new hose with two barb fittings. The PCV hose ends weren't quite 3/8" ID and were quite irregular, so I just cut it in the middle and the center was actually 3/8". Very odd.
    Flyinryank and nk1794[OP] like this.
  16. Mar 16, 2018 at 7:01 AM
    #106
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    works for me.
    It’s more of my project page, but you found it
  17. Mar 16, 2018 at 7:10 AM
    #107
    nk1794
    San Jose, CA
    very nice! Which hose did you intercept?
    15whtrd likes this.
  18. Mar 16, 2018 at 7:11 AM
    #108
    nk1794
    San Jose, CA
    that looks like a fun project but a lot of :spending::D
    Thegr8punkin[QUOTED] likes this.
  19. Mar 16, 2018 at 7:13 AM
    #109
    Tundradrenalin
    Virginia Beach, VA
    The PCV hose. It's the hard to see and grab hose running from the crankcase to the intake manifold. The entire hose isn't more than 8 inches long but is mildly rigid.
  20. Mar 16, 2018 at 7:16 AM
    #110
    15whtrd
    15whtrd Mr. Blonde
    Ok so not the hoses from the top of the valve covers that lead to the intake tube? You intercepted the one drom the crankcase to intake manifold.
  21. Mar 16, 2018 at 7:20 AM
    #111
    nk1794
    San Jose, CA
    So you intercepted this hose. Right?
  22. Mar 16, 2018 at 7:21 AM
    #112
    Tundradrenalin
    Virginia Beach, VA
    We may be talking about the same hose. There is only 1 PCV hose on these trucks. It's under the big 5.7 engine cover and wrapped in that greenish foam, which makes it hard to access.
    15whtrd[QUOTED] and nk1794[OP] like this.
  23. Mar 16, 2018 at 7:25 AM
    #113
    nk1794
    San Jose, CA
    Thank you. This is much easier than I expected.
  24. Mar 16, 2018 at 11:50 AM
    #114
    nk1794
    San Jose, CA
    15whtrd likes this.
  25. Mar 19, 2018 at 7:58 AM
    #115
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    I almost Guarantee it’s less then the price of a tundra ;) I MIGHT spend as much on the 4runner as I bought my tundra for. The last 4 runner (punkin, the one I rolled) I spent around 5 grand on it to have it where it was. This one might have that much in it
  26. Mar 19, 2018 at 8:38 AM
    #116
    nk1794
    San Jose, CA
    $5K is not bad. I thought it would be 3 times that. Its awesome that you have the skills and know-how to do that. That’s way beyond my capability.:bowdown:
  27. Mar 19, 2018 at 11:10 AM
    #117
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Sorry 15k on any vehicle is to much unless it’s completely show room quality imo
  28. Mar 19, 2018 at 12:00 PM
    #118
    nk1794
    San Jose, CA
    I ordered a dual can system from Radium. Hopefully I’ll get them this week. Thank you everyone for your comments and suggestions. You guys are the best.
  29. Mar 19, 2018 at 1:50 PM
    #119
    15whtrd
    15whtrd Mr. Blonde
    Looking forward to see it!
  30. Jun 20, 2018 at 1:02 PM
    #120
    2010ISFU
    2010ISFU New Member
