Oil Capacity with the 5.7 V8
Discussion in '2.5 Gen Tundras (2014-2021)' started by erm626, Apr 18, 2015.
  1. Mar 31, 2023 at 10:41 AM
    #151
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    The manual can be wrong, the stick is actually sitting in your oil pan and the most accurate way you could possibly check it. Not sure how you can misread low and high on a dipstick, its been pretty common practice since maybe the 1920s. The issue is when you have manufacturers eliminating dipsticks even like how our transmissions don't have one definitely makes checking the level more difficult, but i still do the check procedure after draining it rather than just putting in what I took out, so that I know its correct.
    Seafury likes this.
  2. Mar 31, 2023 at 10:42 AM
    #152
    CTundraForMe
    CTundraForMe New Member
    huntsonora likes this.
  3. Mar 31, 2023 at 11:01 AM
    #153
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Here's how you check the oil on my 25 T, maybe we should go back to this method. :)
  4. Mar 31, 2023 at 11:33 AM
    #154
    Joe333x
    Joe333x Member
    Boston
    Im sure the service manual also tells you to check the dipstick when you're done but to each their own.
    Lol yeah i think model A was probably first to have a dipstick maybe.
    Seafury and TILLY[QUOTED] like this.
  5. Mar 31, 2023 at 11:47 AM
    #155
    TILLY
    Massachusetts
    Your right, the 28 Model A was the first Ford to have a dipstick.
    Seafury and Joe333x[QUOTED] like this.
  6. Mar 31, 2023 at 11:48 AM
    #156
    CTundraForMe
    I checked my electronic version of the owner's manual as well as the service manual.
    @Joe333x is correct. The service manual says check oil level. But it doesn't say anything else.
    The owner's manual says this.
    Note it says 3 (upper level) is excessive!
    The owner's manual also says this:
    So all these years I've been missing an apparent important step!
    However, the "high mark" on the dip stick is "excessive" according to the manual.
    Rocko9999 and Joe333x like this.
  7. Mar 31, 2023 at 11:50 AM
    #157
    BEYOND the high mark is excessive. Between the low and high is “normal”.
  8. Mar 31, 2023 at 11:52 AM
    #158
    Joe333x
    Joe333x Member
    Boston
    Interesting, never heard the top mark as being considered excessive, pretty much any shop even fills to the top mark. Were talking about a half a quart difference though so Im sure in the end its not going to make any difference between doing 8 or 8.5
    Seafury likes this.
  9. Mar 31, 2023 at 11:58 AM
    #159
    Joe333x
    Joe333x Member
    Boston
    Ahh that makes more sense.
    Seafury likes this.
  10. Mar 31, 2023 at 11:59 AM
    #160
    CTundraForMe
    To @KNABORES point, the diagram does indicate higher than the line is excessive.
  11. Apr 6, 2023 at 2:28 PM
    #161
    tiogajoe
    tiogajoe New Member
    Joe
    little marsh Pa.
    2020 DC TRD Limited
    Stock
    Just changed my oil and filter today. Was just about 8.5 quarts to the top mark. This was adding about 8 quarts and taking a ride. I then re checked the level. It took just about a half quart to top off.
    Joe333x likes this.
