Offset question.
Discussion in 'Wheels & Tires' started by Palmer812, May 8, 2019.
  1. May 8, 2019 at 6:59 PM
    Palmer812
    Palmer812 [OP] New Member
    Robert
    New guy here. Picking up a 2019 Crew Max in Cement Gray in a few weeks. Getting the sr5 package with 18” wheels. Want to go 20”. The TSS wheels are 20x9 with a 50 mm offset. Not many aftermarket options available in that offset. What is the lowest offset that will fit without the tires sticking out from the fenders at all? Thanks in advance.
  2. May 8, 2019 at 8:09 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    I have +20 with 285/55/20 and it clears with stock suspension.....that’s about the limit because it is really close.
  3. May 8, 2019 at 8:18 PM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    This is 285/55r20 BFG ko2's on 20x9 with +50 offset. They are flush with the edge of the fenders. They aren't tucked in or stick out.
  4. May 9, 2019 at 4:36 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    +50mm is about as low as you can go and not have them stick out at all. Mine are a +25mm on 275/70/18, and the sidewall of the tires stick out just a bit.
  5. May 9, 2019 at 4:41 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    here are 295/55/20 tires on a 20x9+50mm offset wheel. they stick out just a tad from the wheel well.
  6. May 9, 2019 at 4:42 AM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
