Offset question
Discussion in 'Wheels & Tires' started by cfred70, Jul 13, 2018.
  1. Jul 13, 2018 at 7:41 AM
    cfred70
    cfred70 [OP] New Member
    Craig
    Ohio
    2018 Tundra SR5 Crewmax
    Extang Solid Fold 2.0, 20% Tint, Black Emblem Overlays
    Looking at some new wheels. My first question is does anyone know what the offset is of the trd stock wheel? Second question is the wheels I’m looking at are +12,will this be much difference than the stock trd or will these give me a little more stocking out than the stock wheels that I feel are tucked in quite a bit? Not looking to stick way out where I need to add fenders flares but at least a little more aggressive stance closer to flush with the outside or do I need to look at a negative offset?
  2. Jul 13, 2018 at 8:39 AM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    I run a +12 and it sticks out a little. I rub the body mount on 295/70r18 with 3” lift.
    zcarpenter92 likes this.
  3. Jul 13, 2018 at 9:31 AM
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    The offset of the stock 18" TRD wheels is +60. A +12 offset will push the wheel out almost 2". I am running 295's on a +25 offset wheel:108BF1FD-8C1C-4ACD-9AAF-D4FA8D85B0C5.jpg
    equin and joonbug like this.
  4. Jul 13, 2018 at 9:40 AM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I run 295/70R18’s on +12 offset as well, mine stick out a lil bit. I have no plans to run flares. If you decide you want more of a flush fit, you’ll probably want to look at a wheel with +25 offset. What size of tire are you looking at?
  5. Jul 13, 2018 at 9:59 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    If not new tires, just measure out 48mm from where you are now at full lock L and R to see if any rub; wheel straight ahead and see how much it sticks out if you like it.
  6. Jul 13, 2018 at 10:13 AM
    cfred70
    Craig
    Ohio
    For now I’ll just be running the stock tires (275/65/18). I don’t have a lift or level, will the +12 not work without a lift/level?
  7. Jul 13, 2018 at 10:52 AM
    Redbeard321
    Redbeard321 ballin' on a budget
    2016 Tundra SR5 Double Cab
    This is just my opinion. Unless you plan to add a lift and bigger tires +12 is not a good idea. It looks stupid when guys run the wrong offset and have stock tires with no lift.
    I have +25 rims and the tires are outside the fenders with a 275/60R20 tire.
  8. Jul 13, 2018 at 11:30 AM
    cfred70
    Craig
    Ohio
    Agree and thats what I'm trying to figure out. I hate the look of the tires tucked clear under, so would like to bring them out a little, but running stock tires for now with no lift, if I do lift it will just be a leveling with billsteins all around. Eventually a more aggressive tire, but probably stock size. Would just like the tires to not be tucked so far under, and I'm not sure what offset I need to look at to get that.
  9. Jul 13, 2018 at 11:43 AM
    cfred70
    Craig
    Ohio
  10. Jul 13, 2018 at 6:16 PM
    Redbeard321
    Sounds like you would be happy with something in the +25-35 range assuming its a 9 inch wide wheel. Mine are +25 on a 9 inch wide wheel and stock suspension.
    joonbug likes this.
  11. Jul 14, 2018 at 10:20 AM
    cfred70
    Craig
    Ohio
    Any idea what offset gets me flush or just a bit outside? I found a couple +18 wheels I like, but guessing those stick out a good ways? Found another that is +35 too. +35 probably a better bet??
  12. Jul 14, 2018 at 10:27 AM
    DaBoro54
    DaBoro54 Beach Fisher
    Leveling kit, 285/70R18 EXOs
    Thats +18 with leveling kit and 285/70r18
  13. Jul 14, 2018 at 10:35 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just the offset doesn’t determine how much your tires will stick out. Tire width also matters. A 295 tire with +18 will stick out almost half an inch further than a 275 tire with the same offset. Takes a little mathing but here’s a great thread to determine exactly how much your tires will poke out.
    https://www.tundras.com/threads/tire-fender-overhang-formula.11063/#post-189124
    zcarpenter92 and sr5shark like this.
