Offset for 33” tires on 20x9’s ?
Discussion in 'Wheels & Tires' started by BigIrish82, Jun 29, 2020.
  1. Jun 29, 2020 at 9:04 PM
    BigIrish82
    BigIrish82 [OP] New Member
    Josh
    2018 Tundra
    I have a 2018 Tundra and I’m putting on a rough country 3.5” lift. Gonna run 33x12.50 Nitto Trail M/T’s on 20x9 wheels. What the correct offset to have them sticking out about 2”? Also, will I need to trim at all?
    Thanks!!
  2. Jun 29, 2020 at 9:30 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    You could probably contact the lift manufacturer, and they could tell you the backspacing range your lift would allow. For my BDS lift the max backspacing for 12.5" wheels was 5 1/2" which is stated right on lift website. Also, if you have a Discount tire near by they can help. They helped out me a lot. They have a computer program that gives you a visual representation of what specific backspacing will look like compared to a stock wheel backspacing.
    BigIrish82[OP] likes this.
  3. Jun 29, 2020 at 10:07 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Put in what you have now, and figure out your 2".. Welcome to the forum..
  4. Jun 30, 2020 at 5:07 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    probably around 0 offset or maybe a little negative. yes, you will need to trim.
    This is a 3.5" lift with 295/60/20 tires on a 20x9 +20mm offset wheel. The tires stick out about 1 inch.
  5. Jun 30, 2020 at 5:19 AM
    BigIrish82
    Josh
    2018 Tundra
    I’m okay with trimming some
    plastic. I like the look of your setup (at least what I can see of it lol). Thanks for the help!
  6. Jun 30, 2020 at 5:23 AM
    Netmonkey
    Georgetown, TX
    thanks, you can check out my build thread. it shows the clearance and what trimming i did to fit the tires:
    https://www.tundras.com/threads/netmonkeys-build-thread-2-0.63758/
    you will probably need to do the cab mount chop and push the bumper forward as well as modifying the bumper liner.
  7. Jun 30, 2020 at 8:06 AM
    BigIrish82
    Josh
    2018 Tundra
    Ok, so I’ve been rethinking 33’s. I don’t wanna do a CMC or move bumpers or anything like that. What is the largest tire I could put on 18x9 wheels with a 3.5” lift. Again, I don’t mind removing mud flaps and even a little bit of of plastic trimming. I still want a slight poke out of the fenders, but that’s optional at this point , not mandatory. Thanks for helping out here folks!
  8. Jun 30, 2020 at 8:58 AM
    Netmonkey
    Georgetown, TX
    well... if you keep the offset higher, then you will have less trimming to do. look at my setup. if you stay with a +18mm to +25mm offset, then you can easily fit 34's and i am so close to be able to fit 35's. i would just need to trim a little bit more of the fender liner or push the bumper out 1/2".
  9. Jun 30, 2020 at 11:14 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    My older wheel and tire combo was 20x9 +20 with 295/60 (33.94”) and if I remember correctly I had to remove the mud flaps and maybe heat treat (reshape) the forward liner but I cleared the cab mount. Wasn’t until I added 1”wheel spacers that I started to hit the mount. This was with a 3/1 leveling kit.
    Netmonkey likes this.
  10. Jun 30, 2020 at 11:18 AM
    BigIrish82
    Josh
    2018 Tundra
    So did your old set up have the tires poking out at all?
  11. Jun 30, 2020 at 12:27 PM
    r4z0r51o
    Dave
    Pictures sent!
  12. Jun 30, 2020 at 12:32 PM
    BigIrish82
    Josh
    2018 Tundra
    Thank you. Nice ride btw. Your old setup is exactly what I am looking for. Not worried about trimming plastic and removing mud flaps, just don’t wanna start cutting the cab mount. Just confirming, the old setup is with a 3/1 lift kit? I have a 3.5”, so I imagine that should be enough, right? Thanks again for the pics and advice!
  13. Jun 30, 2020 at 12:35 PM
    r4z0r51o
    Dave
    Your quite welcome. Cutting the cab mount isn’t really a big deal, it’s when you start having to modify the pinch weld behind the plastics. Good luck!
  14. Jun 30, 2020 at 4:26 PM
    jwatt
    jwatt I heart men
    Jack
    Oregon
    I went with 32's with my 7 " lift. With a 5.5 backspacing I only ended up having to remove front mud flaps. 35's would be major surgery.
