Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Mar 21, 2022 at 4:08 AM
    #2731
    mvetrox
    mvetrox 2020 E-Pro BHS
    Tennessee
    2018 Limited
    Stock
    nice truck. I’d like to keep my stock 20’s also. What size and lift are you running?
  2. Mar 21, 2022 at 10:25 AM
    #2732
    Kmoose35
    Kmoose35 New Member
    Ken
    2017 Limited Crewmax
    Thanks, I installed a Rough County 3/1 leveling lift and utilized the stock limited wheels (60mm Offset) as well as 1 inch spacers. The tires I used were Nitto Ridge Grapplers 35/11.5/20r. I did a ton of research and found only 2 people that reported this same combination. I did remove the front mudguards prior to tire installation but was able to reinstall them after running a self drilling screw and washer thru the guard into the body mount. The only required plastic removal was the short plastic flap in front of the front wheel. Also the Limited stock wheels have relief areas on the back that allow the installation of 1” spacers without the need to modifying the studs. The only other mod needed was to shim the front bumper out 1/2” which was easy and cheap.
    In the end there was plenty of clearance on the UCA, BM and sway bar with Zero rubbing. I even ditch tested the set up driving diagonally in forward and reverse with no rub. All this said I feel the ending wheel offset was where the magic combo is and the limited wheels seem to be slightly different offset wise than other stock Tundra wheels so take note.
    I was all set to trade in and get a 2022 Limited but the lift and tires has me in love with my 17 again!EF73CB19-D701-423C-AA65-79934D93E5D1.jpg C1734014-812A-495D-81B4-4B35BDA75474.jpg 76203C2F-6D8D-4C80-9345-9B7EA8832495.jpg BDBA429A-BBE6-495B-9396-53DFF347E426.jpg 21AA6C16-49E2-438A-8802-AFC81E8E908B.jpg1AC9BF09-BA1A-430F-8FDE-6316F348098F.jpg
  3. Mar 29, 2022 at 5:14 PM
    #2733
    dvs_one_76
    dvs_one_76 New Member
    Ken
    2017 Platinum
    Readylift 3/2, with 20x9 Fuel Techs and 285/65/20 BFG KO2. (Top is the before and bottom is the after)
  4. Mar 31, 2022 at 5:46 AM
    #2734
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    Awesome truck man. Are these Fuel Techs the +20 or +1 offset variety? How's the fitment/rubbing on the front? I have a 3/1 Readylift with 295/60r20 with 0 offset wheels. Thinking about going with 285/65r20's next time.
  5. Apr 1, 2022 at 7:27 AM
    #2735
    dvs_one_76
    Ken
    2017 Platinum
    They are the +20. There was the slightest rub if he truck was sitting wonky and the wheel was full lock out on reverse, and that was with the bumper shims installed. So heated and massage the inner bumper panel a little bit so I didn't have to worry about it.
    GT87[QUOTED] likes this.
  6. Apr 1, 2022 at 9:01 AM
    #2736
    GT87
    GT87 New Member
    Greg
    Western NY
    Cool bro. I heated and pushed the inner plastic forward and still rubs a bit in reverse. My front bumper shims came in the mail yesterday so hopefully that does the trick.
    dvs_one_76[QUOTED] likes this.
  7. Apr 2, 2022 at 3:55 PM
    #2737
    HARPER306
    HARPER306 New Member
    SK, Canada
    2020 Voodoo TRD Sport CM
    Front 5100's at middle setting
    275/70/18 discoverer at3 xlts on method 305's
    Will go a bit bigger in tires next set
    Henry1jg, wharto4x4, D4x4TRD and 10 others like this.
  8. Apr 4, 2022 at 2:27 AM
    #2738
    mvetrox
    Tennessee
    2018 Limited
    Stock
    Did you have to add a block or longer shackles to the rear?
    front: any bumper shims? I want to do as little as possible and fill my wheel wells.
  9. Apr 4, 2022 at 5:38 AM
    #2739
    HARPER306
    SK, Canada
    Nope, didn't touch the back and no bumper shims. Wheels went on first and didn't rub, fronts were just for a bit more clearance/level
  10. Apr 6, 2022 at 1:01 PM
    #2740
    joeevans1176
    joeevans1176 New Member
    Joe
    2017 TRD SR5
    Nothing yet
    Looks awesome! Great idea with the spacing! So did you do 1” spacers on the front AND back, or did you do additional spacing up front? I’m looking at 295/70r18 Baja Boss act’s on stock aluminum wheels. Thanks!
  11. Apr 12, 2022 at 9:29 PM
    #2741
    BruteForceBeWithYou
    BruteForceBeWithYou New Member
    Stephen
    2019 Cement Grey DC
    Just had 5.29 gears installed, turns these new 35" tires like they were stock size. Loving the setup. Tundra finally looks right.
  12. Apr 18, 2022 at 3:56 PM
    #2742
    wjam773
    wjam773 New Member
    2007 Blue Tundra SR5 Double Cab
    3.5" Rough Country Lift 18" Method 305 NV (+25) Duratrac 285/75/r18
    First I want to thank everyone on this thread for all of the help, information, and advice. It made my build so much smoother!
    1st pic is before and 2nd pic is after. I ended up going with:
    Duratrac 285/75/r18 (34.8")
    No rubbing with extra room to add some chains if I need to.
    I did the body mount chop myself, moved the front fender liner forward by redrilling new holes, and re-formed the skid plate.
    The Juice, D4x4TRD, Kwe1982 and 7 others like this.
  13. Apr 19, 2022 at 4:54 PM
    #2743
    TheBeast The Beach
    looks mean
    wjam773[QUOTED] likes this.
  14. Apr 19, 2022 at 8:30 PM
    #2744
    Semperfi5th
    Semperfi5th New Member
    Bamuffler Pro comp 7 inch lift 37x12.50r18 4.88 nitro gears Amp research steps King shocks all around Icon uca Nfab bumper Rigid pods Method nv305 18x9 wheels Prinsu roof rack Baja designs 40 inch light bar Coachbuilder steering Coachbuilder rear lift shackles Boss front bumper shims
    37x12.50r17
    Geolanders✌
    406Michael, D4x4TRD, equin and 5 others like this.
  15. Apr 19, 2022 at 11:20 PM
    #2745
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    12.50x35" BF Goodrich KO2s
    3.5" Ironman 4x4 Foamcell Pro lift
    17" Race Relation Wheel RR7-H, 0 offset
    BMC Mod by Off Road Warehouse
    D4x4TRD, equin, WVI and 2 others like this.
  16. Apr 20, 2022 at 1:54 AM
    #2746
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    What front bumper is that ?
  17. Apr 20, 2022 at 8:54 AM
    #2747
    Semperfi5th
    Nfab mrds bumper with boss bumper shims
    ATV25[QUOTED] likes this.
  18. Apr 20, 2022 at 10:40 AM
    #2748
    TheBeast The Beach
    very nice ! my next set of wheels. thanks for the gen 2 pictures with the RR7s :)
    How is the clearance with the 0 offset ? how about balancing/weights with the KO2s ?
    AstroDude[QUOTED] likes this.
  19. Apr 20, 2022 at 5:28 PM
    #2749
    ATV25
    Terry
    Redding, CA
    2019 Platinum
    THANKS ! Looks great
    Semperfi5th[QUOTED] likes this.
  20. Apr 23, 2022 at 10:40 AM
    #2750
    AstroDude
    Eddie
    thank you!
    Yeah I don't have any clearance issues. I went overkill with the BMC and flattened the pinch welds. I was going to put 37s on but I decided against it due to having to make even more mods just to fit them (removing front bumper/shaving it down)
    I'll take a picture of the BMC later but I have zero issues. Some people say the BMC might have not been needed...but I'd rather have it done and not need it...then to need it and not having it done.
    D4x4TRD and TheBeast[QUOTED] like this.
  21. Apr 23, 2022 at 8:20 PM
    #2751
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    (Old/Current) ToyTec Ultimate 3" lift (at out of box settings)
    (Old setup)
    Vision Creep 20"x9 +12mm (36.5lbs)
    Roadone Calvary MT 33x12.50R20 (70lbs) (TH 32.8")
    (Current setup) (DOT legal beadlock)
    Icon Rebound Pro 17"x8.5 +25mm (28lbs)
    Cooper Discovery STT Pro 285/70R17 (62lbs) (TH 33.03")
    D4x4TRD, equin and J&ATundra like this.
  22. Apr 25, 2022 at 8:50 PM
    #2752
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    Debating on changing my Method312's to Summit Offroad Dakars, anyone have any experience with these wheels? also any opinions on bronze or black?D8D0554F-6FA1-4254-8216-EC18F2CD91FF.jpgnewdakarbz2.jpg.jpg 6Ldakarblk2.jpg.jpg
    pvmike, NueveTundra and J&ATundra like this.
  23. Apr 27, 2022 at 7:53 PM
    #2753
    SunTundra413
    SunTundra413 New Member
    Ned
    Massachusetts
    2019 Black TRD Sport DC 4X4
    ARE Cap
    You should be fine.
    I just installed Continental Terrain Contact ATs 265/70 R18 on SCS Ray 10s which have a +25 offset. I'm stock height and no rubbing at all. I don't have a lot of miles on these tires yet, but so far I love them. Almost as quiet as the all seasons that came stock on the truck. I did take a 3 hour trip on the highway the other day and they were really smooth and quiet at highway speed too.
  24. Apr 27, 2022 at 10:08 PM
    #2754
    pvmike
    pvmike Home Depot flexing
    Los Angeles
    2014 Platinum Super White
    TRD Pro suspension, supercharger, 5.29 gears, Auburn LSD
    k3k0a808[QUOTED] and khooiii like this.
  25. Apr 28, 2022 at 8:06 AM
    #2755
    Splisken
    Splisken 2012 DC Tundra
    CO
    2012 Toyota Tundra DC
    ICON 3.0 Stage-1 Deltajoint w/RXT rear; 315/70R17 Falken Wildpeak AT; ICON 17x8.5 wheels; SmartCap (commercial); iKamper 2.0 Skycamp; Decked System; ARB Dual air; sPOD; upTop Overland Alpha roof rack w/BD rock lights
    Falken Wildpeak AT 315/70R17 on ICON 17x8.5 (25 offset)
    ICON Stage 1 3.0 lift w/RXT rear (add-a-leaf installed to account for the weight of the SmartCAP, Decked system, and RTT). It sits level and rides great lightly loaded beyond those items with a full tank, but an air bag assist is likely in my future to help handle the hitch mounted dirt bike and full loads.
    The tire shoulders are essentially flush to the outside of the wheel wells and only the sidewalls bow out beyond a small amount. It did require the body cab mount cuts and also a stock skid plate trim.
    D4x4TRD, 1SassyShan, equin and 2 others like this.
  26. Apr 28, 2022 at 8:17 PM
    #2756
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Do it. These wheels look bitchin!
  27. Apr 30, 2022 at 4:47 PM
    #2757
    k3k0a808
    k3k0a808 New Member
    2021 1794 WCP
    Nice, looks great! I ordered Black Dakar's the other day..should be here in a week or two
    khooiii[QUOTED] likes this.
  28. May 1, 2022 at 12:46 AM
    #2758
    Trd_Jason
    Trd_Jason New Member
    Mesa az
    2021 Tundra sr5
    Icon 3.0 stage 1 Icon billet ucas Icon rxt leaf pack set to option 1 Method 301 17x8.5 0 offset 315/70r17 bfg k02
    Just got mine done. Found a great deal on some rock warrior wheels. Cleaned them up, painted up the center caps and mounted up some 315/70r17 ko2. Truck looks so much better. What you guys think?
    Suspension specs are icon 3.0 stage 1. Front is set to how it comes from icon. Roughly 2.25 to 2.5 inches of lift and rear is about 1.25. Only rubbing is on the sway bar at full lock.
    Before
    After
    20220430_144350.jpg20220430_144310.jpg 20220418_131056.jpg 20220406_165710.jpg
    Viclava, Savmikey47, D4x4TRD and 11 others like this.
  29. May 2, 2022 at 1:54 PM
    #2759
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Wheels: ProComp 41 Series Phaser 18x9
    Tires: Toyo Open Country RT 37x12.50r18
    Front Suspension: Bilstein 5100 on top setting
    Rear Suspension: Bilstein 5100 w/ Total Chaos Fab 3/4” Shackles
    D4x4TRD, NueveTundra, equin and 4 others like this.
  30. May 2, 2022 at 1:55 PM
    #2760
    rdiddy5
    rdiddy5 New Member
    Ryan
    Arizona
    2018 Crewmax 1794 4x4
    Looks good!
    you got those OEM wheels up for sale? might be interested.
