Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Oct 2, 2021 at 6:29 AM
    #2611
    Beer Man
    Beer Man @cement.tundra
    2021 SR5 XP CrewMax Cement
    Looking for some advice. Will 285/75/18 clear with my setup? I tried to search but didn’t find much.
    Im running the 18” SCS Ray 10s with +25 offset. I’ve got the Eibach 2.5” coil over lift up front with stock rear suspension. I’ve already taken off all front & rear mudflaps.
    I was set on 285/70 but lack of options threw me off.
  2. Oct 5, 2021 at 7:38 AM
    #2612
    1794TX
    Steven
    N.TX
    '20 1794
    @okcowboy Not sure if you're still in the market for these wheels. A set in DFW, one of which has a 'hairline fracture', 'that I'm told can be repaired', which makes it a set of 3... 'NRH' is North Richland Hills, touching the northeast corner of Ft. Worth.
    20 Inch Toyota Tundra Sequoia Wheels - Read Below - auto wheels &... (craigslist.org)
    havagoodn
  3. Oct 5, 2021 at 8:15 PM
    #2613
    okcowboy
    okcowboy New Member
    No Mans Land (Tulsa, OK)
    2021 Tundra 4x4 1794 Edition Wind Chill Pearl
    I found a set of takes offs with tires and TPMS sensors for $500 just a couple of hours away but had to pass that day and then they were sold. :(
    I have my eye on another set of take offs (bare) that aren’t too far away. He’s asking $600, I’m just not sure about them. I’d really like to see a picture of a set on a white Tundra.
  4. Oct 11, 2021 at 11:43 AM
    #2614
    Hank
    Hank New Member
  5. Oct 11, 2021 at 12:10 PM
    #2615
    1794TX
    Steven
    N.TX
    '20 1794
    Height adjustable shocks will accomplish the task.
    Apologies if you don't need any of this: There are lots of opinions on here about whether shims are good enough - they're certainly cheaper. I would not trust my truck to them, but I'm sure saying that's asking for a war of words with folks who have and like them. 'Levelling' is just lifting the front end up to remove the 'rake' that the truck comes with from the factory; without lifting the rear. The rake is there to help the truck retain a good (safe) stance while towing, but if you don't tow much, or if you accommodate the squat that towing would cause otherwise (with air bags or springs), you may like the look, or like the additional room you'll have for bigger tires.
    There are lots of leveling kits / adjustable shocks; and this forum is full of great research. I did a lot of that and landed on Teraflex Falcons as my kit of choice, but they're pricier than the one's you've linked, and you'll have to wait longer to get them (possibly 8 months). Plenty of folks love their Bilstein, Icon, Fox, Old Man Emu, or other brands.
    Good luck. Will love to see pics when you get them installed.
    [edit]: Also, those 285/60/20's may fit w/o leveling. This string is the right place to find a solid answer on that.
    JuanTon21 likes this.
  6. Oct 12, 2021 at 2:29 PM
    #2616
    Urbandalefirefighter
    Urbandalefirefighter New Member
    Jackson Salter
    2011 Tundra Crewmax 4.6L 4x4
    2011 tundra crew max sr5
    stock suspension. Running 20x10 TIS wheels. BFG KO2 275/65r20. No trimming, no rubbing.
    DMV_Tundra, D4x4TRD, mvetrox and 4 others like this.
  7. Oct 12, 2021 at 10:57 PM
    #2617
    a_double
    a_double New Member
    Nice look! Where is the rub? Front bumper inner fender liner? Did you do a BMC?
    how do you like it so far?
  8. Oct 13, 2021 at 5:28 PM
    #2618
    2mchfun
    Still have these rims? How are they holding up? TIA
  9. Oct 13, 2021 at 7:07 PM
    #2619
    TexAirUh
    TexAirUh New Member
    NEPA
    2021 Cement Tundra Limited TRD O/R
    18x9 +25 Method 305's
    275/70/R18 Nitto Ridge Grappler
    Stock Suspension
    Only barely rub on full lock in reverse going over a bump - does not rub on full lock on flat land
  10. Oct 14, 2021 at 4:00 AM
    #2620
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
    @TexAirUh your pics didn’t load and what part of nepa are you in?
  11. Oct 14, 2021 at 4:30 AM
    #2621
    TexAirUh
    TexAirUh New Member
    NEPA
    Weird - they are showing on my end. Let me try and fix it. Thanks for the heads up.
    I am in the Wilkes-Barre area.
    @Brettstation37 just re-uploaded - let men now if that works
  12. Oct 16, 2021 at 9:38 AM
    #2622
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Currency converter= Earned to wasted dollars
    FBAE1EEB-1FC1-4241-A981-CC7F34E2634F.jpg 35/12.5/r18 BFG - Evo wheels-18X8.5. - Power Brakes & Rotors - On Bilstein 6112/5160 top setting/w shims
    Minor plastic cutting.. No rub
    Tundra805, dpast88, J&ATundra and 9 others like this.
  13. Oct 18, 2021 at 6:47 PM
    #2623
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    BFG All terrains. 285/65r18. Stock suspension. No rubbing so far. Took the front bumper mudflap/air dams off just in case.
  14. Oct 19, 2021 at 5:45 AM
    #2624
    COTundra23
    COTundra23 New Member
    Looks great! I’ve been eyeing these wheels in 17”.
    Dogsled[QUOTED] likes this.
  15. Oct 19, 2021 at 6:08 AM
    #2625
    Dogsled
    Dogsled New Member
    White 2020 1794 4x4
    Thats what set out to get… I think the 17’s provides more air down and look better… But, when i went with the big brakes they wouldn’t fit on the smaller rim.
    COTundra23[QUOTED] likes this.
  16. Oct 19, 2021 at 6:49 AM
    #2626
    gabewhite
    gabewhite New Member
    2020 Tundra TRD Sport
    Stock...for now.
    2020 TRD Sport. Completely stock suspension.
    20x9 (+12) SCS Stealth 6 Matte Gunmetal
    295/55r20 Toyo AT2 Extreme
    Removed front mud flaps and pushed plastic forward. Only have minor rubbing in certain circumstances. A little plastic massaging and that will go away. FD12D055-30BA-4ED0-A1D4-9F36DABFC232.jpg
    J&ATundra, mvetrox and TexAirUh like this.
  17. Oct 21, 2021 at 7:48 AM
    #2627
    CT1990
    CT1990 New Member
    CO
    2019 Quicksand SR5 TRD Off-Road 4x4 Crewmax
    6" BAMuffler.
    Did you have to do any BMC or anything on the front end to make these fit? I've got 18 in. SCS SR8's w/ a +25offset and want to run the RT 35x12.5
  18. Nov 1, 2021 at 4:25 PM
    #2628
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    Brrraaahhhh! Solid Truck, What you running fo suspension?
  19. Nov 1, 2021 at 5:43 PM
    #2629
    BlueSpartan1597
    BlueSpartan1597 New Member
    ‘19 White Tundra Sr5 TSS
    Looking for input. 2019 Crewmax and I’m about to install a Readylift 3/2. I just installed my coach builder bumper shims and I may be the odd ball out but I like the stock wheels. Looking to put on 295/65/20’s or 295/60/20’s
    Ridge grapplers, Open Country AT/III’s, or BFG KO’s? Those seem to be the go to tires from what I’ve read for my needs. I removed the mud flaps but not sure what exactly will fit with no rubbing. Thoughts? Thanks in advance.
    mvetrox likes this.
  20. Nov 2, 2021 at 7:52 AM
    #2630
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    l
    looks great with the OR wheels. Did you also install wheel spacers?
    Jemz808[QUOTED] likes this.
  21. Nov 2, 2021 at 8:02 AM
    #2631
    BlueSpartan1597
    No but was considering. I like that stance. Any mods to prevent rubbing? Any issues with throwing debris with those spacers?
  22. Nov 3, 2021 at 7:54 AM
    #2632
    Tinidancer1
    Tinidancer1 New Member
    2023 Tundra Limited 4X4
    Wescott Preload Collar
  23. Nov 3, 2021 at 7:46 PM
    #2633
    Mjrpa
    Mjrpa New Member
    Looking to put Nitto Ridge Grapplers on my stock 20 trd sport wheels. Currently on the stock trd sport suspension. I don’t want to modify suspension. Can I run 33x12.50x20 without rubbing?
  24. Nov 4, 2021 at 4:27 AM
    #2634
    mvetrox
    mvetrox 2020 E-Pro BHS
    Tennessee
    2018 Limited
    Stock
    I’d like to know myself. I want to keep my 20” stock limited rims. Been agonizing over tire size the past few weeks in preparation for winter. Been eyeing Michelin defender 285/60 R20s and continental AT.
    I spend more time commuting and pulling a tt.
    Please post when you pull the trigger.
  25. Nov 4, 2021 at 4:51 AM
    #2635
    Mjrpa
    Mjrpa New Member
    I’ve read in a couple of threads that you can go as big as 295/55/20 and even 60 profile without rubbing (mudflaps have to come off) When the measurement system changes to the 33/12.5/20 is where I’m confused and the tires I want are on that measurement scale so trying to see if that works too
  26. Nov 4, 2021 at 6:27 AM
    #2636
    BlueSpartan1597
  27. Nov 4, 2021 at 6:48 AM
    #2637
    Mjrpa
    Mjrpa New Member
    Amazing! I should’ve used google lol, thank you!
    mvetrox likes this.
  28. Nov 5, 2021 at 4:22 AM
    #2638
    mvetrox
    Tennessee
    2018 Limited
    Stock
    I use that site, thanks. that what makes it harder.
    I can see the size but it’s not installed. I had a 2006 XSP with 275/60 20s and they only rubbed in reverse at full lock. Hoping I can go a touch taller on my 2018. And fill the well a little more.
  29. Nov 5, 2021 at 5:22 AM
    #2639
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Check this out. * lol beat me to it!
  30. Nov 5, 2021 at 5:37 AM
    #2640
    BlueSpartan1597
    I pulled the trigger on some Nitto Recons 295/60/20’s. My truck is a 2wd using stock wheels and lift so that shouldn’t create any rubbing. If I was 4wd I woulda gone with the 295/65/20 which is 2 inches taller but would have to trim the front liner. Will post when they get installed. So many options makes it difficult.
    D4x4TRD, kleiker0303 and mvetrox like this.
