Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. May 1, 2021 at 2:21 PM
    #2431
    DCGymRat303
    DCGymRat303 Psalms 91
    Highlands Ranch Colorado
    2017 Tundra
    Magnuson Supercharger and new floor mats
    That's my dream truck right there, perfect!
    But everyone knows if it was white it would be faster.
    Fastlane47[QUOTED] likes this.
  2. May 1, 2021 at 2:54 PM
    #2432
    crazybithead
    crazybithead New Member
    Paul
    2019 Tundra SR5 4x4 with TRD Sport Package
  3. May 1, 2021 at 4:36 PM
    #2433
    MoonRock2021
    MoonRock2021 New Member
    2021 TRD Pro Crewmax Lunar Rock 2021 4Runner Nightshade
    Finally installed Coachbuilder bumper shim, Method 317 wheels +18 with 295/70R18 Ridge Grapplers. Truck is stock height until Wednesday. Only very light graze is on mudflap in full turn while in reverse.
    In the closeup of inner wheel I noticed a shorter lugnut. Will be calling them Monday morning.
    Here is some pictures:
    178907033_190657259564972_43636680520759_01e1a56f8434ca48dae4a0016c9112f1a3b91e3e.jpg180329018_3851640951615758_5503762584014_a11ffbcb0f120a8cf45c3f5e5092cc29a724e034.jpg179095515_193325269284330_59662441562011_8d67e2ae7f3f5a7d72a53755e5016369f021d436.jpg180693719_464791044627816_28240547357993_ef49d14e27814c48ac511106153affaba022f360.jpg178873292_1186047661857523_1791670553487_ed994d7889049b17d805041b30b83298a7ceb815.jpg180224606_509253303771774_82538928245796_b35ac02512ff7f0bf58f613fd4c92ad36ea07f2f.jpg178438824_512494373081878_21473911327039_b2c5df903ff38a2072abd22f247709934f950392.jpg179742603_3884261005027568_1082249509355_31b35893ec439e5845471f715b01f2ab3d6e87df.jpg
  4. May 1, 2021 at 4:48 PM
    #2434
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Looks great! So whats going on on Wednesday??
    MoonRock2021[QUOTED] likes this.
  5. May 1, 2021 at 4:50 PM
    #2435
    MoonRock2021
    Thank you. I have the Coachbuilder Full TRD Pro kit being installed.
  6. May 1, 2021 at 4:52 PM
    #2436
    FISHN43
    FISHN43 New Member
    Ohio
    Nice! Post more pics after lift!
  7. May 3, 2021 at 1:11 PM
    #2437
    SrgJigPog
    SrgJigPog New Member
    '19 Tundra TRD Off-Road
    What size tires are you running? Just ordered the same set of wheels myself.
  8. May 4, 2021 at 8:59 PM
    #2438
    BrandonL812
    BrandonL812 New Member
    Brandon
    2017 Sequoia LTD
    Rx350 retrofitted, Morimoto Led fogs. interior and exterior leds swap. TRD drop in filter. Carbon filter delete. Led DRL panels. TRD Shift knob.
    Is everyone using factory lug nuts or aftermarket with your aftermarket wheel?
    My friend wanting to get some Fuel Lethal 20x9 +20 running 275-65/20 for his 2016 CM stock height, no plan for lift whatsoever. He daily his and no off-roading. He wants to know if he need aftermarket lug nuts.
    TIA
  9. May 4, 2021 at 9:07 PM
    #2439
    Retroboy1989
    Northern Utah
    2012 DC 4x4 5.7 SR5 TRD OR Barcelona
    Snug top 20" TRD Sport wheels 275/60R20 Tires Additional Trans Cooler
    I have never seen an aftermarket wheel that accepts Toyota shank style lugs. Most aftermarkets have conical lug seats.
    BrandonL812[QUOTED] likes this.
  10. May 4, 2021 at 10:36 PM
    #2440
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    every wheel is different. Need to check with Fuel to see if the stock lugs would work. I would personally just spend the extra $45 and get new lugs that will definitely work and probably be prettier looking.
  11. May 7, 2021 at 4:58 AM
    #2441
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Aftermarket
  12. May 7, 2021 at 5:29 AM
    #2442
    TheGreyTundra28
    TheGreyTundra28 New Member
    2018 Grey Tundra Sport
    Dirty Deeds 10 budget exhaust, Roof rack, 52" windshield, Truxedo Tonneau, and Line x Bedliner
    That color tho! :thumbsup:
  13. May 7, 2021 at 8:24 AM
    #2443
    greentrbo95gst
    greentrbo95gst New Member
    Huntington Beach
    For those running 17-in wheels where do you mount balance weights on the wheel? It seems like there's not enough space to mount them in the standard locations due to the caliper being so close to the wheel.
    This is on a 2020 Tundra trd pro. Tia
  14. May 7, 2021 at 9:21 AM
    #2444
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    If that’s the case then the shop would use stick weights on the inside of the rim and not the lip
  15. May 10, 2021 at 8:23 PM
    #2445
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    I couldn't figure out why nobody gave any love to 305/70 17. A little wider than the 285/75 and a bit taller than the 295/70. Lighter than the 315/70 and less of a lift to fit.
    So here we are. I had to find out.
    Ended up with about 2.25" up front, all mudflaps gone. No BMC, Stock UCAs, no diff drop, fender liner pulled forward, no bumper shim, no skid plate bend or trim. 1in shackle in the rear. Still about 1in rake, no sensor modifications and no issues so far.
    Tires: 33.8 Cooper Discoverer at3 xlt in 305/70 17.
    Wheels: 17"ICON Rebound in platinum. +25 offset.
    At full turn that wheel well is full but there is no rub.
    Tldr: 305/70 17 is another great option for tire size for our trucks.
    20210509_160942.jpg 20210508_141638.jpg 20210508_141623.jpg 20210508_141336.jpg
  16. May 11, 2021 at 9:15 AM
    #2446
    pretty
    pretty New Member
    @Pillslinger do you have either lift on the front or is that stock? I just ordered some 17 inch Icons. no tires yet as I am trying to decide what to do for suspension mods other than a coil spacer lift.
  17. May 11, 2021 at 11:59 AM
    #2447
    Pillslinger
    Rollin
    SWMO
    I used bilstein 5100 on the middle setting and added 2 coachbuilders shims on each side. By the book that should have been 2.57in total lift but in my case it came out to about 2.25in. I used a 1in shackle lift for the rear to maintain some rake.
    LB-Tundra6 likes this.
  18. May 11, 2021 at 12:00 PM
    #2448
    Northern1
    Northern1 New Member
    Travis
    2022 Red 1794
    I'm just about ready for some summer camper tugging. Thanks to all on this forum that have posted your trucks with details and pictures. I just turned 3,600 miles and have done the following:
    Bilstein 5100's all the way around, fronts on the middle clip with one shim on each side. I also added a 1" block in the rear.
    275-70-18 Cooper XLT's on 18x9 XD Heist wheels, +30mm offset. No rubs as of yet but I had already pulled the front air dam flaps off.
    I also added Toyota towing mirrors and exhaust tip. Put some Fire FLy led's on the interior and exterior and Tyger running boards.
    Last up is to do is get my airbags and Daystar bag cradles installed.
    Overall I'm pleased with the way that it turned out. I would say that going to E rated tires stiffened up the ride more than the Bilstein's did on the middle setting.
    D4x4TRD, Barrett50 and Pillslinger like this.
  19. May 11, 2021 at 12:08 PM
    #2449
    Pillslinger
    Rollin
    SWMO
    What pressure are you running in your tires? I'm also only a few days in but DT set my coopers to 40psi and I feel like it improved my ride over what the middle setting 5100 felt like in stock Michelins. The ride of 5100 seems to be one of the most subjective topics discussed on this forum. I think I would have to agree with another member who said "it rides more like a truck now and less like a luxury car"
  20. May 11, 2021 at 3:35 PM
    #2450
    Northern1
    Travis
    2022 Red 1794
    I’m running 40 psi as well. I’m ticked that I let DT talk me into using balancing beads, I’m heading back to have them spun balanced tomorrow. I know that E rated tires and Bilstein’s are a major discussion based on scouring the forum, I was just passing on my opinion on the tires vs. the shocks. I’m coming out of a 2019 F-250 so I’m not in search of a Cadillac ride. The tires definitely give a more planted feel over the stockers.
  21. May 11, 2021 at 5:53 PM
    #2451
    Pillslinger
    Rollin
    SWMO
    Ya I havnt heard much about the balancing beads, but what I have seen seems to be kinda meh at best.
  22. May 15, 2021 at 5:53 PM
    #2452
    MF702
    MF702 New Member
    2021 White TRD Sport
    Well. I got a pleasant surprise today. After plenty of forum research I went to Discount Tire to try on Ko2s in 275/65r20 on my ‘21 TRD Sport OEM rims and suspension. Of course, their computer said no. Even the 275/60r20s were a no.
    Several staff huddled around and looked at my truck. They all agreed that the 60s would fit and the 65s would rub. I told them to try on the 65s anyway because I was prepared to remove the front mud flaps and bend the plastic skid plates forward a little per “the forum”, hehe.
    20 minutes later several guys approached me grinning and said the 65s fit no problem. Weighted truck, full turns, no touch. Sold.
    Thanks to those that have gone before me. Good info sharing. Appreciate it.
    BC036E83-1683-43A9-B1B2-975934E26E82.jpg A5711807-21FD-4A1B-B4F3-1981C73ED6E8.jpg 22A71288-8A02-4DD3-B02A-CB0A476BA9EF.jpg 64E7912A-513E-47B8-A14E-C5B954DF277D.jpg C31F8B03-4859-46BA-84E3-A9F7FC1228AC.jpg
    TundraTed, okcowboy, D4x4TRD and 8 others like this.
  23. May 16, 2021 at 4:19 AM
    #2453
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Method 316's with the blackhawk extended wheel studs up front.
    J&ATundra and D4x4TRD like this.
  24. May 16, 2021 at 5:26 AM
    #2454
    TheBlackPearl
    TheBlackPearl Newish member
    La Gulf Coast
    2020 Black TSS Crewmax 4x4
    Stunning f’n picture
  25. May 17, 2021 at 11:27 AM
    #2455
    21SXmachine
    21SXmachine New Member
    Black 21 SX
    Whats the offset on the 2021 black SX 18’s that come w 255/70/18 highway tires ?
  26. May 17, 2021 at 7:36 PM
    #2456
    Vallejo206
    Vallejo206 New Member
    Rob
    Everett, WA
    02 SR5 V6 AWD
    Hey, I’m looking to put some 2018 4Runner wheels on my 2002 tundra.
    I’m getting a great deal on the wheels, from what I’ve read they should be easy to install and fit. Just wondering if I need to get different lug nuts or would my oem ones will fit. Thanks for any help you have have to offer
  27. May 18, 2021 at 3:15 AM
    #2457
    ATV25
    ATV25 Young at heart
    Terry
    Redding, CA
    2019 Platinum
    5100s, Icon Rebounds, Maxxis Razors
    What size lift do you have on that ? It looks awesome !
  28. May 18, 2021 at 7:47 PM
    #2458
    Franco4x4
    Franco4x4 New Member
    2019 tundra CM
    Beautiful truck. What's your setup?
  29. May 20, 2021 at 8:46 AM
    #2459
    Rippyro
    Rippyro New Member
    2014 Tundra 1794 - Sunset Mica Bronze
    Looks excellent. How much lift, backspacing, and any rubbing/trimming?
    also what steps are those? looking for some flat metal ones to replace the factory plastic ones. TIA
  30. May 20, 2021 at 8:52 AM
    #2460
    Rippyro
    Rippyro New Member
    I currently have 295/60R20 ridge grapplers on my stock 1794/platinum wheels with no lift. I'm looking to go with the 6112's and 5160s + 1" rear block to lift the truck a couple of inches, and I'm going to be buying new wheels as well. My tires have a ton of life left on them so I didn't plan on swapping them out until later down the line.
    Any suggestions on backspacing for a 20" wheel with 295/60 ridge grapplers on them with little to no rubbing (minimal trimming)? TIA
