Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Mar 31, 2021 at 12:18 PM
    #2371
    1794TX
    Steven
    N.TX
    '20 1794
    @Roman and anyone else who might know: Any idea the part number for these wheels? They're TSS Sequoia/Tundra OEM, and I probably need a set like a hole in the head, but you know how that goes...
    TK1979 likes this.
  2. Mar 31, 2021 at 12:28 PM
    #2372
    Jkenn6
    Jkenn6 New Member
    NJ
    23 Tundra
    IconAlloys Bandit 20x10 -24
    35x12.50R20 Nitto Trail Grapplers
  3. Mar 31, 2021 at 2:40 PM
    #2373
    Mjrpa
    Mjrpa New Member
    Nice wheel setup. Are you on the stock TRD suspension? I have the TRD sport (same suspension) and not trying to modify suspension since i have a lease. Might go with a similiar tire size (295/55R20) might be smaller.
    What did you do besides remove mud flaps to avoid rubbing?
    me...[QUOTED] likes this.
  4. Apr 1, 2021 at 6:15 AM
    #2374
    GT87
    GT87 New Member
    Greg
    Western NY
    White 2021 SR5 O/R CM
    295/60r20 Toyo ATIII, 20x9 XD 820, 3/1 ReadyLift Carven Exhaust
    Man this truck looks absolutely perfect. What's your suspension set up?
  5. Apr 1, 2021 at 12:16 PM
    #2375
    me...
    me... New Member
    I do have a 3/1 inch leveling kit, and had the littlest rub on the driver side front part of the inner wheel well all I did was use a heat gun and softened it up and slightly pushed it in. I didn't want to cut my shit up.
  6. Apr 1, 2021 at 12:21 PM
    #2376
    me...
    me... New Member
    No problems with the balance at all and I watched a bunch of reviews on them befor I pulled the trigger, and some guy had 50k and still probably had 10k more miles on them. He also said he wasn't easy on them. But he rotated them every 7k-10k. But the price I got them for were Luke $254.00 each also its a 12ply tire. To be honest I thought they would be extremely stiff. But I can't tell the difference from the nittos I had on befor. I know the earlier tires had problems staying round, but from what I understand they fixed the problem a year ago or something like that.
    mopar[QUOTED] likes this.
  7. Apr 1, 2021 at 6:00 PM
    #2377
    Username Kyle
    Username Kyle ...
    Kyle
    Chesapeake, VA
    2019 Tundra
    ReadyLift 2.4” Level Fuel Off-road Wheels Wrangler Duratrac Tires Predator Steps ARE Z Series Cap ARE Ascend Basket BedRug Bed Liner Debadged
    18” Fuel Off-road Vector Wheels
    275/70R18 Wrangler Duratrac Tires
    2.4” ReadyLIFT Leveling Kit
    *Removed front mud flaps and did some light trimming to front fender plastic near front bumper to get rid of rubbing at full turn in reverse.
  8. Apr 1, 2021 at 11:39 PM
    #2378
    Wilma
    Wilma New Member
    Will
    Boise, Idaho
    '14 White DC Limited
    Lift: - Toytec Boss 2.5 Aluma Series Coilover Kit @ 2.5inches - Toytec 2.0 Aluma Series IFP Rear Shocks - Toytec Progressive 3 Leaf Add A Leaf Pack - Diff Drop - N0 BMC, no rubbing w/ minor plastic trimming. Wheels: - Method 701, 18x9, +25 offset Tires: - Goodyear Duratrac 285/75/18 (34.5x11.5) Topper: - ARE CX Classic w/ windoors + Railing Recovery: - ARB Tred Pros - ARB SPEEDY SEAL REPAIR KIT SERIES 2 - VIAIR 300P Compressor
    Appreciate it. Just put them through 10 days in the backcountry and a 1,200 mile road trip. So far I like the ride. They’re tight on pavement and feel good on dirt, especially at speed. I don’t have much to compare but I’d say they are on the stiffer side. I prefer that for a rig that spends time on both pavement and dirt.
  9. Apr 4, 2021 at 5:32 AM
    #2379
    jscerbo13
    jscerbo13 New Member
    Hey everybody. Just ordered 6112 set at 2.5. Goofing to run airbags in rear to help with tow sag. I’m looking at the method mr703 wheels but can only find them in an offset of 35, is that going to poke out to far? Any pics or info? Also going to run ridge grapplers 285/75/17. Thanks in advance
    chuck416 likes this.
  10. Apr 4, 2021 at 5:52 AM
    #2380
    Username Kyle
    Username Kyle ...
    Kyle
    Chesapeake, VA
    2019 Tundra
    Depends on what you think too far will be. It’s going to noticeably stick out though.
  11. Apr 4, 2021 at 6:06 AM
    #2381
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Look at pics of +25 throughout this post and others. I say +25 cuz there’s lots and not may +35 but +35 will be just a tad less poke.
  12. Apr 4, 2021 at 8:44 AM
    #2382
    Wilma
    Wilma New Member
    Will
    Boise, Idaho
    These are Method 701 +25(+35 will be a tad less poke like Barret50 said). Tires are 285/75/18 which are the same 11.2in width as your 285/75/17’s. I would say +35 would be flush with your fender.
  13. Apr 5, 2021 at 4:07 PM
    #2383
    jscerbo13
    I’m looking to get method mr703 but can only find them offered in a 0 or +35 offset. 35 will suck the wheel to far in towards the truck am I correct? Will the 0 offset sit flush with fenders? I’m really looking for the tires to poke out a little bit so I should be looking for like a -12 offset. Is my thinking correct here? Offsets are confusing me
  14. Apr 5, 2021 at 4:17 PM
    #2384
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    The +35 will pull them in, a 0 offset will stick outside the fenders a little, it will not be flush.
    BravoDeltaRomeo likes this.
  15. Apr 5, 2021 at 4:21 PM
    #2385
    jscerbo13
    Ok great that’s what I was thinking. So a negative number will pull them out past the fenders correct? Will I have any issues running a 0 offset with 285/75/17 bilstein 6112 at 2.5?
  16. Apr 5, 2021 at 4:43 PM
    #2386
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    The stock offset is 60 mm (ET60). Take a metric ruler and measure how far the disk will stick out. The same tire will stick out further for the same 60 mm with offset 0 wheels.
  17. Apr 5, 2021 at 6:02 PM
    #2387
    Username Kyle
    Username Kyle ...
    Kyle
    Chesapeake, VA
    2019 Tundra
    The width of the wheel matters also. You’re going with a wider tire and a wider wheel. With 0 offset it means everything is centered up with the middle of the wheel which if I’m not mistaken means you’re going to be closer to the your fenders some. I’m no expert, but I’m assuming since the tires you want are about 1/2 inch wider than stock and the wheel is 1/2 inch wider than stock. You will probably be looking at some minor trimming and definitely removing the front mud flaps to avoid rubbing.
    A lift or leveling kit may help. 2.5” is solid. But it’s hard to say for sure if you’re going to avoid rubbing.
    For reference. My truck has a 2.4” leveling kit, 275/70R18 tires, and 18x9 wheels with a +20 offset.
    I had to remove front mud flaps and trim a little bit of plastic off of my front fenders to mitigate rubbing at hard turns in reverse.
  18. Apr 5, 2021 at 8:15 PM
    #2388
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    I have 295/70/17s with 6112s set at about 1.75". I trimmed and pushed the wheel well liner in-still rub on flaps but only in reverse and left them on. I think you'll be fine with 285s; if anything it will be light plastic trimming.
    Username Kyle likes this.
  19. Apr 6, 2021 at 1:30 AM
    #2389
    jscerbo13
    Nice. Thanks for the input everybody. I think I’ll pull the trigger on the wheels and tires today. Then the waiting game for everything to come in the mail.
    Wilma likes this.
  20. Apr 6, 2021 at 3:06 AM
    #2390
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    20x10 Havok Wheels -24 offset with 35" Cooper STT PRO and 6" ProComp. Probably go with KO2 when I need them, Coopers are pretty loud compared.
  21. Apr 7, 2021 at 11:07 AM
    #2391
    me...
    me... New Member
    Mine are +12 offset, so 0 would stick out further. But my tires are 12.5 inch wide so that also pushes them out a bit.
  22. Apr 7, 2021 at 3:02 PM
    #2392
    jscerbo13
    Nice. Looks good my man. I ordered wheels and tires today! Went with the 0 offset
  23. Apr 7, 2021 at 6:04 PM
    #2393
    Radlux
    Radlux New Member
    Socal
    Hello all I am thinking of purchasing 325 65 r18 falken wildpeak A/t3w on method 305s. Does anyone have this set up or at the very least wildpeaks? If so how do you like Falken Wildpeaks A/t3w?
  24. Apr 8, 2021 at 5:21 PM
    #2394
    Username Kyle
    Username Kyle ...
    Kyle
    Chesapeake, VA
    2019 Tundra
    @TRDFerguson
    @YotaBro
    @frichco228
    Radlux[QUOTED] and TRDFerguson like this.
  25. Apr 8, 2021 at 7:11 PM
    #2395
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I’ve been running AT3w in 295/70R18 for over a year and I’m very happy with them. They’ve been wearing well and are decently quiet for the tread IMO. Here they are with Raceline Gauge wheels, +18 mm offset:
    ABB5CF28-4CB6-4099-A20F-94B1E2057DE5.jpg 20FA37B0-C732-41FD-8D18-995374C1A693.jpg
  26. Apr 8, 2021 at 10:00 PM
    #2396
    Radlux
    Radlux New Member
    Socal
    That looks really nice. I just placed my order for method 305 nv in matte black and falken wildpeaks in 35s from cali-raised offroad. I am so excited after seeing your set up.
  27. Apr 11, 2021 at 1:21 PM
    #2397
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    I'm considering a set of method 316's
    Will a +18 offset with cause alot of paint chips with stock size tires?
    The roads in my area are covered by the tar and chip crap, lot's of loose gravel.
  28. Apr 11, 2021 at 5:05 PM
    #2398
    mopar
    mopar New Member
    ME
    '10 White Tundra
    Bilstein 5100's on highest setting on front, 2" blocks on rear, info center mod, NFab nerf bars, TPMS override
    Depends on width of tires. Anything wider then 275/285 and there's a chance you'll fling rocks on to body. I have +25 with 295 wide tires and they stick out about 1/2" beyond body and I can hear rocks bounce off body every once in a while. Fender flares will cure the problem.
    fixnfly[QUOTED] likes this.
  29. Apr 13, 2021 at 8:23 AM
    #2399
    TeamGoose
    TeamGoose Threat Level Midnight, Michael Scarn
    Temple, TX
    2020 Tundra TSS 4x4 Cement
    OEM LED Headlights, TRD Shifter, Interior LEDs, 6112(1.9) & 5160 reg. height
    Any rubbing.. looking at maybe getting those, but the Toyo AT3s in that size. I have 6112 @ 1.9 in the front. curious to see if 295 have some space between the tire and UCA and or if they rub bad.
  30. Apr 13, 2021 at 8:37 AM
    #2400
    WestexSBK
    WestexSBK New Member
    2019 SuperWhite CM TRD Sport 4x4
    No rubbing on anything metal I did remove the rear flap but I had the same offset wheels as you. I ran the stock suspension for about a month and then Installed 6112’s at 1.9”. I would definitely consider the 295/60’s if you want to fill the wells a little more. I think they would fit. Especially with a tire like the at3
