Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Dec 20, 2020 at 10:40 AM
    #2221
    F33rNoFish
    F33rNoFish New Member
    Daniel
    Lots of good looking trucks!
    I’ll be putting a truck camper on mine and don’t want to lift the suspension much to keep a good center of gravity. Probably an added leaf in the rear and a bump stop or potentially bags but kinda want to stay away from bags.
    I would rather go smaller wheel with wider tires so if I need to air down I still have a good traction patch. I’ll be doing baja offroad trips on it so traction is key in some places out there.
    I don’t think I’ll go 35’s. Maybe 33x12.50 on 17’s.
    Anyone running that stock?
  2. Dec 22, 2020 at 3:49 PM
    #2222
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Question for you guys. I've got my icon 17s on order, got my tires picked out, I think, but how is everybody dealing with the TPMS?
    Has anyone had a problem with switching the oem TPMS over to a set of 17" icons? How does the reprogram of the tire pressure setting work?
    If I just don't put the TPMS sensors on the new wheels will there be a constant error message? Or can a tech stream approach fix that?
    Thanks in advance. I don't see this topic covered elsewhere and I'm just trying to prepare for all the details.
  3. Dec 23, 2020 at 8:37 PM
    #2223
    OnePuddleUnder
    OnePuddleUnder New Member
    NC
    01 Silver Tundra AC
    Can someone explain why the OP lists 2003 as the first year described in some part of the posts but references all the way back to 2000 original model for other gen 1 specs?
  4. Dec 24, 2020 at 7:39 PM
    #2224
    DedDucks
    DedDucks New Member
    Brett
    Tatum, TX
    2021 Cement SR5 Crewmax TSS 4x4
    Truck looks good! Do you have a straight on shot? Trying to see what an 18x9 +18 looks like compared to fender edges. Seems like everyone runs flares with them in all pics I can find.
  5. Dec 26, 2020 at 6:37 AM
    #2225
    Nightshade85
    Nightshade85 New Member
    21 Tundra Limited Nightshade
    None
    I apologize in advance with the newbie post but this will be my first time replacing tires with something different than was originally on.
    I have a 21 Crewmax Limited Nightshade. The tires on it now are P275/55r20/111H tires. I want something with more tread and a little more aggressive but nothing crazy as I don’t think it goes with a limited very well. I don’t want it to noticeably stick out past the wheel well but I’m fine if it does slightly.
    I think I’m leaning towards Toyo 275 R18 A/T 3’s. Does anyone know if these would fit the look I’m looking for? I will be keeping the factory wheels and do not want to do a lift or leveling kit. Thanks for any help!
  6. Dec 26, 2020 at 6:50 AM
    #2226
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    I’ve been looking at tires a lot lately. The Toyo is super popular and would look great IMO. I’ve had Dynapro at2 for a while and they’ve been great. The only way a tire is gonna stick out is if you add offset. Even a MT tire won’t stick out past the fender on stock rims
  7. Dec 26, 2020 at 7:02 AM
    #2227
    Nightshade85
    None
    Good deal, thanks for the response man. So what I’ve posted will fit my stock wheels?
  8. Dec 26, 2020 at 7:09 AM
    #2228
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    Well you have 20” rims and said you want 275/18 which is missing a number and a different size rim, so no. You need same numbers that are in original tires.
  9. Dec 26, 2020 at 7:10 AM
    #2229
    Barrett50
    Barrett
    Wisco
    2015 DC silver
    *on
  10. Dec 26, 2020 at 7:11 AM
    #2230
    Nightshade85
    None
    Ahh my bad I don’t know why I put 18’s. I do have the stock 20’s, sorry about that.
  11. Dec 26, 2020 at 8:27 AM
    #2231
    Semperfi5th
    Semperfi5th New Member
    Bamuffler Pro comp 7 inch lift 37x12.50r18 4.88 nitro gears Amp research steps King shocks all around Icon uca Nfab bumper Rigid pods Method nv305 18x9 wheels Prinsu roof rack Baja designs 40 inch light bar Coachbuilder steering Coachbuilder rear lift shackles Boss front bumper shims
    20x10 cali rawkon -25
    37x12.50r20 nitto ridge grappler
    Loving this set up for now
  12. Dec 30, 2020 at 6:12 PM
    #2232
    mitch 4x4
    mitch 4x4 New Member
    2011 gray tundra base doublecab
    leveling kit
    I have a 2011 tundra base doublecab that came with the stock steel 18" wheels. I am wondering what the factory offset is and am thinking about buying 275/70/18 tires with xd778 wheels with a +35 offset. I want the wheels to be right flush with the fenders. I just put a 2" leveling kit in it. any help would be great as I am new to the forum.
  13. Dec 30, 2020 at 6:34 PM
    #2233
    saber174
    saber174 New Member
    2020 White Tundra Limited
    20x9 Black Rhino Traverse +25 offset
    General Grabber ATX 275x55
  14. Dec 30, 2020 at 6:43 PM
    #2234
    Bob_Wiley
    Bob_Wiley I feel good, I feel great, I feel wonderful...
    Eric
    AZ
    2016 Black SR5 Crewmax 5.7 FFV
    Welcome from AZ. Check out the first post in this thread as I believe it addresses your question about the offset on stock rims. Others can chime in about the correct offset to give a flush wheel profile.
  15. Dec 31, 2020 at 5:10 PM
    #2235
    Blue93
    Blue93 New Member
    2018 Tundra
    Looks great!
  16. Jan 10, 2021 at 3:33 PM
    #2236
    Patmac14
    Patmac14 Toyota Enthusiast
    Patrick
    14 Barcelona CM Limited
    Bilstein 5100s, 1” blocks, TC UCAs
    From 305s to 295s, 5100s in the front and a block in the rear
    I want to return to the original rear end suspension but add a 1.5 shackle. The ass sits to high the way it is
    for those who want to know, I trimmed a lot of plastic to stop rubbing and the previous owner did a cab mount chop WITH OUT WELDING A PLATE IN PLACE.
    Skey44, silverstreak16 and drobb like this.
  17. Jan 10, 2021 at 3:45 PM
    #2237
    Kanobi13
    Kanobi13 New Member
    What photo is current?
  18. Jan 10, 2021 at 3:49 PM
    #2238
    Patmac14
    Patrick
    haha oops I fixed it black wheels are current set up
  19. Jan 10, 2021 at 3:59 PM
    #2239
    Kanobi13
    Kanobi13 New Member
    Looks good!!
    Patmac14[QUOTED] likes this.
  20. Jan 10, 2021 at 4:01 PM
    #2240
    Patmac14
    Patrick
    thanks master Jedi! I gotta do some research tho... the rear block has to go, and I need a good 1.5” shackle kit. Might even go to 6112s Billy’s. I really want it to be perfectly level
  21. Jan 10, 2021 at 4:09 PM
    #2241
    Patmac14
    Patrick
    5100s top setting? 2” block, 295/70r18 wildpeaks, ray10 sleath custom series 18x9
  22. Jan 10, 2021 at 4:12 PM
    #2242
    tundra_uso
    tundra_uso New Member
    East Bay, CA
    2020 SR5 Crewmax 4x4
    Sport model looks great with the TSS wheels
    AZboiler[QUOTED] and Patmac14 like this.
  23. Jan 10, 2021 at 4:54 PM
    #2243
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Are those Carolina tags? Where you at? I am from North Carolina- miss it except the waves here are so damn good. Sucks being an addict.
    Patmac14 likes this.
  24. Jan 11, 2021 at 6:29 AM
    #2244
    Patmac14
    Patrick
    Elizabeth city!
  25. Jan 11, 2021 at 6:51 AM
    #2245
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Nice. I lived in Wilmington & Wrightsville back in the late 80s/early 90s- lived in KDH while stationed in Chesapeake. Miss the BBQ!
  26. Jan 11, 2021 at 6:53 AM
    #2246
    Patmac14
    Patrick
    ah man nice, we could get along!! i got tired of looking for the best bbq, so i got a big green egg and just treat myself all the time!
  27. Jan 11, 2021 at 7:06 AM
    #2247
    Windnsea26
    Windnsea26 New Member
    I hear ya man. I started with a Green Egg, movers dropped it so I ended up purchasing two Kamado Joes. Love these things!
  28. Jan 11, 2021 at 8:06 AM
    #2248
    Pillslinger
    Rollin
    SWMO
  29. Jan 11, 2021 at 8:39 AM
    #2249
    Rockin 2nd Gen
    Rockin 2nd Gen New Member
    Jay
    Ohio
    2010 Tundra
    5" lift 20x12 fuel with 35" nitto ridge graplers. Full led and secaine 9" android head unit.
    5" lift 20x12 fuel wheels 35x12.50" Nitto ridge grapplers.
    J&ATundra, King R 808, Yoyo and 3 others like this.
  30. Jan 11, 2021 at 8:44 AM
    #2250
    Kanobi13
    Kanobi13 New Member
    What you have to do to get no rubbing on the front?
