Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Aug 19, 2020 at 2:48 AM
    #2101
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
  2. Aug 19, 2020 at 5:18 PM
    #2102
    notoriouspig12
    notoriouspig12 New Member
    2014 crewmax
    2.4 level, 296/60/20 ridge grappler on 20×9 vision nemesis +18 offset.
    2.4 level with 295/60/20 on 20x9 +18 vision nemesis.
    21sr5 and TheBubbaDude like this.
  3. Aug 19, 2020 at 5:19 PM
    #2103
    notoriouspig12
    2014 crewmax
  4. Aug 19, 2020 at 6:10 PM
    #2104
  5. Aug 19, 2020 at 7:43 PM
    #2105
    tumaro
    tumaro New Member
    SW Sr5 Crewmax
    Love it..
    Any issues with rubbing at all? Any cutting?
  6. Aug 19, 2020 at 8:02 PM
    #2106
    dMO
    dMO New Member
    David
    2010 Black Tundra
    Toytec 3/1 leveling kit 18x9 VE37 35x12.50 Toyo RT
    Not the greatest picture at the moment... Vors VE37 0 offset 35x12.50r18
    Nice TE37s!!! Mine aren't the real ones but close enough, lol.
    hhenry_, equin and junior like this.
  7. Aug 19, 2020 at 8:42 PM
    #2107
    Jimp1325
    Jimp1325 New Member
    2020 SR5 W/TRD sport package
    2.5 level 20” Fuel Hostage Rims +1 offset 33” Ridge Grappler
    20” Fuel Hostage, 33” Nitto Ridge Grappler, 2.5 level840180B4-730F-445B-8352-9EE929B99C0A.jpg
  8. Aug 20, 2020 at 7:14 AM
    #2108
    zemstvo82
    zemstvo82 New Member
    Elkhart, IN
    2020 Tundra Platinum CM
    No issues with rubbing and didn't need to cut.
    tumaro[QUOTED] likes this.
  9. Aug 20, 2020 at 7:28 AM
    #2109
    tumaro
    tumaro New Member
    SW Sr5 Crewmax
    Any side views?
    Perfect set up. Can you feel the weight?
  10. Aug 20, 2020 at 7:37 AM
    #2110
    OpieTaylor
    OpieTaylor New Member
    Found a set of 4 of these wheels cheap. Thinking of getting them powercoated black for this truck.
    Any thoughts? I'd like to stick to 18" Toyota wheels.
  11. Aug 21, 2020 at 3:22 PM
    #2111
    Djone27
    Djone27 New Member
    2017 MGM Crewmax TSS 4x4
    HID Headlights, full LEDs, TRD front and rear sway bars, CB +2s, Eibach Stage 2s, SABM w/ pro intake tube
    I know this has probably been asked several times, but for the life of me I haven't been able to find a clean answer. I have a '17 4x4 with the TSS package 285/55R20 BFG KO2s. I believe these are a 20x9 +50 offset. I'm not interested in changing rims but do need to start picking out some new tires. These tires are 32.3"x11.7". I'm looking at switching to AT3 XLTs in 275/65R20. These are 34.2"x11.1". I believe these will fit based (off of what feels like hundreds) of pages here and on other sites. Using it appears these tires will actually be about .25" further away from my UCAs and about .9" closer to the fenders. I'm currently stock height but plan on leveling with 6112/5100 before too long. Can anyone confirm the fitment?
    P.S. I'll try to get a new member post setup this weekend with some pics.
  12. Aug 21, 2020 at 4:20 PM
    #2112
    Belated welcome from NY.
  13. Aug 23, 2020 at 10:43 AM
    #2113
    Dan_CO
    Dan_CO New Member
    2019 Tundra TRD
    Hello Everyone!
    I have a 2019 Tundra CrewMax Limited with stock tires and rims. I'm wanting to put the largest tire size WITHOUT a lift or level and I don't mind slight trimming. I'm reading that 295/70/R18 or 285/50/R18 are good picks.
    My question to you is:
    how can you get a tire company to put on these larger tires that will fit with minor trimming but their computers are saying the largest tire for my Tundra is the stock 275/65/R18? I don't have a garage set up or buddies who own shops to do it for me. Thanks in advance for your help!
    tumaro likes this.
  14. Aug 24, 2020 at 12:44 PM
    #2114
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    I did not have any issues with putting on bigger tires, but I bought my tires through a 4x4 shop, so they are used to upsizing without throwing up red flags.
    Have you actually inquired about this and were told that you could not, or are you just preparing for in case they do?
    tumaro likes this.
  15. Aug 25, 2020 at 1:47 PM
    #2115
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    My stock rim is 20"x8" with 60mm offset, if I get a set of rims that are 20"x9" with 0 offset and transfer the existing tires will the tires sink in or could I not use the existing tires due to new rims are wider? New to trucks and I want to change the rims but keep the tires until I wear them out.
  16. Aug 26, 2020 at 11:07 PM
    #2116
    docsmiles
    docsmiles New Member
    It depends upon what your goal is. Putting on larger tires on a stock rim wont change the look all that much in comparison to changing the offset of wheel with same larger tire. You could use a spacer but what is your goal or look you want?
  17. Aug 26, 2020 at 11:11 PM
    #2117
    docsmiles
    what's your feedback on your General grabber tires? smooth? noisy?
  18. Aug 27, 2020 at 3:02 PM
    #2118
    mcm0455
    mcm0455 New Member
    New wheels and tires today. AlphaCommand, 17x8.5, 35mm offset with Cooper Discover AT3 4s 255/75/17, TireRack.com, as soon as I get the 4th one, I'll take it out and report back to the ride difference from the OEM 20's.
    equin likes this.
  19. Aug 27, 2020 at 5:04 PM
    #2119
    shakabarstundra
    shakabarstundra New Member
    285/75/18 Toyo RT on 18” SCS Ray 10’s. Tires are huge and they talked me into going up from 275/70. 6112 Bilsteins stock rear.
    Had to chop the cab mounts and am going to have to get the CB shims, my bumper splash guards are off and it looks a little ugly to me.
    Rides great though nice and smooth. Tires are super quiet.
    A8A8D465-DAA2-49FC-8B8E-70D4852C381D.jpg 977B2FBF-A157-4154-BE9E-B81DEFC65380.jpg 9E001DB5-5E7B-4A33-A694-1B4A1FE50467.jpg
    21sr5, TRDblvd, JPB_VT and 13 others like this.
  20. Aug 30, 2020 at 9:52 AM
    #2120
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Pros just come with a 2” lift up front, no lift in the rear. The rubbing is most likely caused by your wheel offset. The more the wheel sticks out (less offset), the more likely it is to rub. Stock wheels come with about +50mm to +60mm offset and are more tucked in within the fenderwell. Many aftermarket wheels have an offset of between 0mm to +35mm offset, with the 0mm offset sticking out the most. But they also tend to rub more.
    Rather than remove the bumper, try to push in or remove the plastic bumper liner covering the fog lights. You can also move the bumper forward a bit using shims.
    By the way, what size tires do you have? And what kind of wheel is it and what is its offset if you know?
  21. Aug 31, 2020 at 9:21 AM
    #2121
    tumaro
    tumaro New Member
    SW Sr5 Crewmax
    Specs??
    sslamd likes this.
  22. Aug 31, 2020 at 9:35 AM
    #2122
    equin
    Ed
    DFW, TX
    The 18mm offset is likely what's causing the rubbing. I believe the Pro wheels have an offset of about 50-60mm, so they stick in more. The main problem with high offset wheels, like the stock ones, are that they may cause rubbing on the upper control arm or skid plate when running bigger, wider tires. It would've been great if Toyota had widened and enlarged the fenderwell area a bit to allow for aftermarket wheel/tire upgrades without the rubbing issues, but it is what it is.
  23. Sep 1, 2020 at 6:30 PM
    #2123
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    I’m getting new tires on Saturday, decided to get cooper at3 xlts. The truck is running 5100s on top setting with an add a leaf in the rear. Tire size options are
    285/75r18 (34.8x11.5)
    295/70r18 (34.3x12)
    275/70r18 (33.2x11.1)
    These would be going on stock trd off-road wheels. I’d like to stick with one of the 34s, I’ve had the 275/70r18 with Bilsteins on my last 3 tundras and would like to go bigger. I don’t mind trimming the skid plate (that has to be done with any of these sizes) and I already have all the mud flaps removed. The most off-roading this truck will see is beaches and semi rocky forest trails.
    Derf77 likes this.
  24. Sep 1, 2020 at 6:47 PM
    #2124
    shakabarstundra
    I just went with 285/75/18
    I initially wanted 275/70 based on pictures I saw here but got convinced to go up in size.
    They feel big but not ridiculous. I like that they’re still a little narrow.
  25. Sep 1, 2020 at 7:03 PM
    #2125
    19crewmaxTRD
    Seth
    what are the specs of your wheels?
    mid like to avoid a bmc if I can
  26. Sep 3, 2020 at 8:34 AM
    #2126
    Derf77
    Derf77 New Member
    South Chesterfield VA
    2020 Crewmax SB SR5 TRD Off Road
    TRD rear sway bar, Ready lift 3/1, 4 window auto up/ down.
    How is the ride with 51s at top setting?
  27. Sep 3, 2020 at 8:56 AM
    #2127
    19crewmaxTRD
    Seth
    It’s definitely stiff. I prefer it over the super soft factory ride. I’ve debated moving to the middle notch am adding a shim to soften it up a little
    Derf77[QUOTED] likes this.
  28. Sep 7, 2020 at 9:02 AM
    #2128
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    Maybe I’m overthinking this but here is my question. I want to add 6112’s at the 1.9 setting and a tire that will be good in snow. I have decided to go with Ridge Grapplers. I can’t afford to do the 6112’s and tires at the same time before winter unless some extra money falls into my lap.
    If I do the tires first I’ll have to go with 285/65/r18 so they will fit with the stock suspension and minimal if any trimming. Will the tire look too small after I add the 6112’s in the spring?
    Thanks in advance everybody!
  29. Sep 7, 2020 at 11:40 AM
    #2129
    Pacifico
    Pacifico New Member
    2019 Tundra SR5 4x4
    Brushed aluminum wrap, ProComp 6” lift, Flow Master Exhaust, Fuel Battle Axe 20x10 on 35x12.5 MT tires.
    Lift Kit
    6” ProComp, smooth ride
    Wheels
    Fuel Battle Axe 20x10, Offset: -18, Backspacing: 4.8
    Tires
    Mickey Thompson Baja Mtz, Size: 35"x12.5, minor trim of bumper and wheel well liner to clear
    hhenry_ likes this.
  30. Sep 8, 2020 at 6:20 AM
    #2130
    awdrules
    awdrules New Member
    2016 Tacoma TRD Offroad
    ome lift
    2014 - Present: 110.5mm
    These wheels say they are110? Will they fit a 2017 4x4?
