Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Jun 28, 2020 at 8:44 AM
    #2041
    hefemi
    hefemi kifaru overland - Qi Fuh Rou
    Kifaru
    > 1794 - Kifaru
    First Post!,
    Rig: Kifaru
    Rim: Fuel Blitz
    Tire: 305/50/20 Nitto Ridge Grapplers
    Lift: Leveled
    Rub: Not yet
    i like the look of the LP tires.
    HFM.
  2. Jun 28, 2020 at 9:19 AM
    #2042
    okie404
    okie404 New Member
    Looks good..
    hefemi[QUOTED] likes this.
  3. Jun 28, 2020 at 10:00 AM
    #2043
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Looks good. Any rubbing when turning?
    What setting are you running your 6112s at?
  4. Jun 28, 2020 at 6:52 PM
    #2044
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Thanks. Drivers side at 1.9 setting/ passenger side at 1.3. Moved the well liners forward by trimming ... easy. It rubs the flaps at full turn and that's it. Im leaving them on....I am super stoked with how it all worked out. Started out at 1.3 on the Bilstein and decided to adjust drivers side to counter the lean; I had to get 2 alignments..., wanted the zero offset and I think it looks pretty badass and just took a little plastic trimming with garden shears and couple hole drilled ( in the liner). I used the wheel well mod post on here for that. Keith Carty ( Dirty Deeds) is a friend and definitely steered me in the right direction. Would have loved to gotten Kings but...
  5. Jul 8, 2020 at 6:58 AM
    #2045
    Tundra14_Plat
    Tundra14_Plat New Member
    Bruce
    2014 Tundra CM Plat
    Stock suspension
    Original
    2014 Plat wheels 275/55/20
    New
    Icon Rebound 17 +25mm offset
    Nitto Ridge Grappler 285/70/17
  6. Jul 8, 2020 at 7:08 AM
    #2046
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Looks great.
  7. Jul 8, 2020 at 8:30 AM
    #2047
    G2G
    G2G New Member
    Chicago
    2018 White Platinum Tundra
    Looks great! About to do the same set up 2018 with stock suspension with the same rims and tires. No rubbing?
  8. Jul 8, 2020 at 8:57 AM
    #2048
    Tundra14_Plat
    Bruce
    2014 Tundra CM Plat
    Yes, there is slight rubbing at full lock which could be fix by removing mud flaps.
    G2G[QUOTED] likes this.
  9. Jul 8, 2020 at 9:08 AM
    #2049
    Tundra14_Plat
    Bruce
    2014 Tundra CM Plat
    I ordered my wheel & tires from custom offset which comes mounted and balanced. I had to get them re-balanced because this happened.
  10. Jul 8, 2020 at 9:56 AM
    #2050
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Figured I'd go ahead and post this up here since I forgot to before.
    6" ReadyLift (spacer kit, NOT coilover kit) w/ bilstein 5125 rears
    20x10 Hardrock Offroad Painkiller Exposed -19 offset
    325/60R20 (35.5/12.8R20) BFG KO2 10ply at 35 psi
    Did body mount chop, bumper spacer 1/2" kit, trimmed a little bit of fender liners, and removed mud flaps of course.
    Before with TSS package on 20x9 +50 offset wheels:
    After:
  11. Jul 8, 2020 at 10:07 AM
    #2051
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Damn.
    For those of us in the market for 17" wheel/tire combo is there something we should put in purchasing notes that could prevent this?
  12. Jul 8, 2020 at 11:00 AM
    #2052
    Tundra14_Plat
    Bruce
    2014 Tundra CM Plat
    Either it wasn't balance correctly from the facility or some bumps happen during shipping could have cause this. Just pay the local tire shop $60 to balance it prior to installation even if it was mounted and balanced at the facility you purchased it from.
    Vr0ck[QUOTED] likes this.
  13. Jul 9, 2020 at 6:03 AM
    #2053
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Is that where the weights got knocked off by the rotor?
    I had DT install mine with specific guidance on location of weights for the wheels- still had to return to have them rebalance. I was so happy to have new wheels and tires that it didn't irk me too much.
  14. Jul 9, 2020 at 7:22 AM
    #2054
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Got the truck cleaned up and on level ground. 2008 with 2” spacer, 275/70/18 Ridge Grapplers and 18x9 Method double standards, +25mm offset.
  15. Jul 9, 2020 at 7:30 AM
    #2055
    Tundra14_Plat
    Bruce
    2014 Tundra CM Plat
    Yes, that is where the wheel weights got knocked off by the brake calipers or the rotor dust covers. I'm guessing it was the brake calipers that knock it off because of how much closer it is sitting to the wheel.
    equin likes this.
  16. Jul 9, 2020 at 7:53 AM
    #2056
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Wonder if you opted for custom offset balance bead if this could have been avoided?
    Have any members purchase this add on and say its worth it?
  17. Jul 10, 2020 at 5:47 AM
    #2057
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    I would recommend noting to installer that 3rd Gen Tundras require balance weights on 17's to be placed clear of rotors - outside edge of wheel. I would then follow that up with a phone call or if possible a face-to-face discussion.
    In my case I damn told the voice on the phone where the weights needed to be however, there was a break down in comms between him and the dudes doing the install. They were extremely accommodating after the fact but it did cost me a 25 mile round trip and 2 hrs of my time. I should have verified in the parking lot but was more concerned with identifying the rub from the tires. All good now.
    equin and Vr0ck like this.
  18. Jul 11, 2020 at 8:23 AM
    #2058
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    Love the 0 offset. Don't love the chrome and headlights so much.
  19. Jul 13, 2020 at 3:24 PM
    #2059
    Yoyo
    Yoyo New Member
    VA
    2020 Tundra TRD SR5 CrewMax
    Fuel Assault Gloss Black, 20x9, +20 offset, Toyo Proxes ST, OEM Black Running Boards, Black Fender Flares, Pedal Commander.
    OK guys, wanted to share my set up. Nothing fancy as I wanted not to mess with the suspension but I love the look of the truck...
    Set up:
    - Stock Suspension (not even leveled)
    - Fuel Offroad Assault Gloss Black 20"x9 (+20 offset)
    - Toyo Proxes S/T 275/55R20 (Same OEM size)
    - AMI 6070KL AMI Race Style Billet Fuel Door 7'
    - Auto Ventshade "In-Channel" Ventvisors
    - Classic Black Running Boards
    Pictures:
  20. Jul 16, 2020 at 8:08 AM
    #2060
    joey2018
    joey2018 New Member
  21. Jul 16, 2020 at 8:10 AM
    #2061
    joey2018
    joey2018 New Member
    What method did you use to "Level" the truck? Looks perfect. Does it still fit in the garage?
  22. Jul 17, 2020 at 8:33 PM
    #2062
    Painterguy1978
    Painterguy1978 New Member
    2018 Tundra doublecab
    Any idea on break upgrade for 22 inch upgrade on off road tires
    texasrho83 and Fotnot like this.
  23. Jul 21, 2020 at 3:24 PM
    #2063
    JL98
    JL98 New Member
    2016 MGM Tundra DC TRD Off-Road
    TRD Pro Grille, 32'' LED Light Bar, 275/70/18 Duractracs, 18x8 RSSW Krawler wheels (+30 mm offset), Bilstein 5100 top setting (front), 1'' block rear, Plastidipped badges
    Rims: RSSW Krawler 18x8 (offset +30mm)
    Tires: 275/70/18 Goodyear Wrangler Duratracs
    Suspension: RoughCountry 1.75'' Levelling Kit
    Only removed the small flaps at the front, no rubbing at all. Debated the 285/65/18 vs 275/70/18 for the longest time but found a smoking good deal on these 275 Duratracs that I could not resist. Very happy with the look and ride so far!
    61566498550__CCD6B930-EC9E-4BD6-823F-06C8064B2A6C 2.jpg IMG_4847.jpg IMG_4848.jpg IMG_4837.jpg
    Blue93, Beesta, GoForthMGM and 6 others like this.
  24. Jul 21, 2020 at 5:41 PM
    #2064
    hefemi
    Kifaru
    > 1794 - Kifaru
    Hey Joey,
    I used these leveling kits https://www.amazon.com/gp/product/B06ZZHXKMW/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1 but you'll need to compress your coil spring and re-align the holes to make them fit, took me 4hrs to get one side and once I figured it out it took only 30mins for the other side.
    yes it does fit in the garage with about 3-5" clearance i think.
    HFM.
    marcelo73 likes this.
  25. Jul 23, 2020 at 5:10 PM
    #2065
    keep_it_simple
    keep_it_simple New Member
    Looking for feedback... I have a 2013 Tundra with 18x8 stock wheels. I'm buying a set of Falken Wildpeak A/T3Ws. Trying to decide between 275/70R18 or 285/75R18. Not worried about trimming plastic or body mount chop. I'm putting an ICON suspension on so I'll have clearance. I am concerned about how the added size (going from 11" x 33.4" 61 lb tire to a 11.2" x 34.8" 65.9 lb tire) will affect mileage, acceleration, handling, and general wear and tear. Will I need to re-gear? Thanks in advance!
  26. Jul 25, 2020 at 7:42 AM
    #2066
    2019-1794
    2019-1794 New Member
    2019 1794 Crew Max 4x4
    Wheels and Tires: BBS 18” Landcruiser Hertitage wheels and 285/75R18 Goodyear Duractrac
    Suspension: Fox TRD Pro
  27. Jul 25, 2020 at 10:11 AM
    #2067
    joey2018
    joey2018 New Member
    Lots of great info and cool setups here. Been searching for a few days. From what I learned there is no best set up. So I'm leaning toward the 3/2 level kit and 20x9 +18 offset. Like to do 20x10 same offset if possible with a 305 50 20 tire. Will this combo work? Any major down side to level kits vs coil overs besides price? I have a 2018 cewmax SR5
  28. Jul 25, 2020 at 2:49 PM
    #2068
    19TRDpro
    19TRDpro New Member
    S&B CAI
    8F53DF12-989F-4F12-A7E8-47914FBF95AD.jpg D8C1AAA8-1D25-4485-B0FD-A512FAE5685A.jpg D880CEC1-7E80-4BFA-AB9F-F3A9811C0407.jpg 954623D5-1DCC-4CCD-9B29-77B8E3555452_1_201_a.jpg 2019 TRD Pro
    295/75r18 Ridge Grapplers
    1.25" Spacers
    Westcott Designs 1.5 (3.5 total)/1 lift
    Front Mud Flaps removed, slight rub in reverse
  29. Jul 25, 2020 at 4:21 PM
    #2069
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Now that's a killer look!!! I really enjoy the looks of it
    2019-1794[QUOTED] likes this.
  30. Jul 25, 2020 at 4:26 PM
    #2070
    kwebre
    kwebre New Member
    2020 Blck Tundra
    4" pro comp suspension lift
    4”Procomp lift
    20x9 0 offset wheel
