Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. May 5, 2020 at 3:37 AM
    #2011
    Getmeacoors
    Getmeacoors From the far Norcal
    California
    2019 sport 4x4 MGM
    Alot
    20x10 -20 be prepared to cut :sawzall:
    I've got 20x10 -18 and the amount of work I had to put in to not rub was insane. And multiple times I thought I won.. and it started all over.
    Good luck!
    Anyway heres my 20x10 -18
    Top pic 20 x 12.5 x 35
    Bottom 20x13.5x38
  2. May 5, 2020 at 7:04 AM
    #2012
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Why exactly do you think you'll have more options on your next tire with a 10 inch rim? Like mentioned above you're gonna end up with a lot more work trying to fix rubbing issues. If you look at my post above #2022 I got 35s on an 8.5 inch wheel and have zero rubbing issues on a 3 inch lift.
    Edit: Forgot to mention I went from 285/65s to the 35s my past swap.
  3. May 5, 2020 at 10:50 AM
    #2013
    Foggynogginz
    Foggynogginz New Member
    KC
    2018 Platinum 4x4 CM
    Still diggin it.
    sslamd, mvetrox, Half Assed and 2 others like this.
  4. May 6, 2020 at 8:09 PM
    #2014
    Clark624
    Clark624 New Member
    2020 TAN TRD
    So before I go and install my 3/2 ready lift in the my 2020 tundra. Just wondering if anyone has a similar set up. 3/2 lift with 18x9 rims with 20mm offset and LT285/75R18 duratracs. Ready lifts website recommended the tire size but mentions nothing about rim offset.
  5. May 6, 2020 at 8:15 PM
    #2015
    Clark624
    Clark624 New Member
    2020 TAN TRD
  6. May 6, 2020 at 10:41 PM
    #2016
    unclebeejo808
    unclebeejo808 New Member
    Oahu
    7CF72140-8F60-49CF-BB7F-33E1938DDFE3.jpg 18x9 +20 fuel shoks on 285/75/18 ridge grapplers. Bilstein 6112 on 2.5 setting.
  7. May 6, 2020 at 11:00 PM
    #2017
    Clark624
    Clark624 New Member
    2020 TAN TRD
    Any issues like rubbing ?
  8. May 6, 2020 at 11:54 PM
    #2018
    unclebeejo808
    Oahu
    I did a cmc before I put the tires on, it did rub the front plastic liner after. I chopped some off, all good now
  9. May 7, 2020 at 6:22 AM
    #2019
    Double Badass
    Double Badass For Thoughs about to Rock we SALUTE you
    James
    Arizona
    2019 Cement Tundra Crewmax
    6 inch pro comp coilover lift, 20 fuel wheels 35 nitto mud grapplers, colorbomb blackout, rigid industries lights, amp steps
    20x9 Fuel sledge wheels -18 offset
    35x12.50r20 Nitto mud grapplers
    7 inch coilover lift
    I totally removed inner fenders do to rubbing, but no big deal!!
  10. May 8, 2020 at 3:18 PM
    #2020
    degs
    degs New Member
    2020 MGM Crewmax
    5100/6112 (1.9") Cooper 275-70R18
  11. May 8, 2020 at 3:26 PM
    #2021
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Nice. There is something sexy about 35's on those wheels.
    superdenk likes this.
  12. May 8, 2020 at 4:41 PM
    #2022
    gabewhite
    gabewhite New Member
    2020 Tundra TRD Sport
    Stock...for now.
    Anyone running the Relation Race Wheels RR6-H? I have searched here, google, Facebook and more but cannot find any photos other than a couple on their website on a truck with fiberglass fenders. Thanks in advance!
    gabex35, equin and Double Badass like this.
  13. May 17, 2020 at 5:15 AM
    #2023
    StoneyWV
    StoneyWV New Member
    Calvin
    Rough Country Level,
    Rough Country 1.5 Level kit. Faulkin Rubitrek 275/70/18 on Tirerack Oasis 5 Lug 18X8 wheels with +45mm backspacing. Exactly the look I was wanting. Just a tad outside the fending well.72BAFB0D-30A8-4D63-B2A4-057AAD821519.jpgA1B5D754-F520-4B1B-B874-409E6BED344F.jpg 604DE9FF-9596-4F91-AD01-AAED822F681C.jpg
    degs likes this.
  14. May 17, 2020 at 9:22 AM
    #2024
    Clark624
    Clark624 New Member
    2020 TAN TRD
    A bit delayed but got it done. Just gotta do. A bit more trimming on the front plastics. 5AC4D3BA-B3E9-4AC9-B54E-F43853B63AC4.jpg
  15. May 19, 2020 at 6:29 PM
    #2025
    stangless40
    stangless40 New Member
    Alberta Canada
    17 Platinum
    lots
    First pic 285/65/18 TRD pro black wheels, second pic 35 x12.5 x18 on fuel vector wheels.
  16. May 20, 2020 at 2:04 AM
    #2026
    Psquancher
    Psquancher New Member
    Jeff
    Atlanta area
    2018 Tundra CM 4X4
    aFe intake and dual exhaust. ADD Stealth front bumper with Rigid light Bar and Smittybuilt winch, ADD Stealth rear bumpers and ADD Stealth steps. Bilstein 6112 @2.3” Bilstein 5160s with Toytech shackles at 1.5". Fuel Contra 20x10 -18 with Ridge Grappler 285/65 with custom BMC. Monster system with Infinity Kappa components JL HD750/1 and JL HD600/4 amps JL Stealthbox and Alpine avic8400NEX hu and full Kilmat sound dampening.
    So I ended up with 20X10 -18 and now it’s time to tackle the rubbing issue. Can you elaborate on what you learned and what my best course of action should be?
    Double Badass likes this.
  17. May 20, 2020 at 7:24 AM
    #2027
    Double Badass
    James
    Arizona
    I just removed the hole inside fender to fix the problem
  18. May 20, 2020 at 1:40 PM
    #2028
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Guess the first thing is what size tires are you running?
    But if 33+ you will need a bmc. And when you do it make sure its healthy. Like take the plastics out of the wheel well hammer down your pinch welds then do the Bmc. If you remove everything you can cut out another half inch than if you leave it all on. You will need bumper shims to push bumper forward and still might need to cut some front plastic.
    You can check out my build for pics and what not.. good luck
    https://www.tundras.com/threads/getmeacoors-2019-sport.48515/
    Edit* just saw you have add stealth bumper so the front should be good
    equin likes this.
  19. May 20, 2020 at 1:42 PM
    #2029
    Getmeacoors
    California
    2019 sport 4x4 MGM
    Alot
    Yes but he is only a 2-3 inch lift if I remember correctly. And he is 10 wide. We have 7 and 9 inch lifts lol
  20. May 21, 2020 at 2:38 PM
    #2030
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    Double Badass, drobb and Vr0ck like this.
  21. May 23, 2020 at 2:12 PM
    #2031
    daays
    daays New Member
    Method Grid 18x9 in Matte Black on stock Michelin LTX AT2 tires. Also swapped out the faux bead lock bolts to the black kit that Method sells.
    Skey44, silverstreak16 and equin like this.
  22. May 26, 2020 at 11:50 AM
    #2032
    YodaPower36
    YodaPower36 New Member
    Ryan
    Kennett Square, PA
    2017 Tundra SR5 Double Cab
    Exterior: 3.5 rc lift Fuel Vandal 20x9 1 mm offset on 35’s, Trd dual exhaust, Spyder Industry Steps, rekgen mud flaps, Trd pro grille, Diode Dynamic SS3 fogs, YotaLED grille lights, ApexOffroad bumper shims. Interior: Heated seats, RC seat covers, Full head unit and stereo replacement. KENWOOD 1057xr, Kicker amp/sub combo,
    I am basically going for the same sizes. What offset did you have on this?
  23. May 28, 2020 at 7:46 PM
    #2033
    typeone
    typeone about time I realized you could change this...
    Zach
    2016 MG Tundra CM
    ICON/Method/BFG
    Need a little in here. Anyone go from 35x12.5s to 325/65/18?
    was there much of a difference? I need new tires and I’m having trouble finding BFG ATs in 35.
  24. May 30, 2020 at 3:00 PM
    #2034
    jamestada
    jamestada New Member
    James
    2020 Tundra TRD Sport 4x4 Magnetic Grey
    Fox 2.0 Front/Rear 18" Fuel Beast wrapped in Nitto Terra Grappler G2
    Just threw these bad boys on!
    Fox 2.0 Coilover 2" lift up front. 1" Readylift block with Fox 2.0 in the rear. Probably going to go 1" more in the front or remove the rear block.
    Fuel Beast 18" x 9" +20et
    Nitto Terra Grappler G2 LT285/65R18
    No trimming needed, only had to remove the front splash trim held on by 2-10mm.
  25. May 30, 2020 at 3:52 PM
    #2035
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Truck looks awesome!
  26. Jun 5, 2020 at 12:51 PM
    #2036
    CamaroSsToTundra
    CamaroSsToTundra New Member
    Ohio
    2018 Tundra
    It was like in between 1 and 2 inches outside fenders and 0 offset
  27. Jun 5, 2020 at 8:16 PM
    #2037
    andrewmlb
    andrewmlb New Member
    2018 Black Tundra
    2018 Tundra, Rough Country Leveling kit 3" front 1" rear, XD811 20x9 wheels with +30 offset, Toyo Open Country A/T II 295/60/20 with .5" bumper shims. Took front small flap off but no rubbing or trimming.
    silverstreak16 likes this.
  28. Jun 18, 2020 at 6:33 AM
    #2038
    PROTaRD
    PROTaRD New Member
    Reston Virginia
    2005 Tundra AC
    none yet -just starting out
    The Setup
    WHEELS: SCS SR8 in Dark Bronze 18 x 9 and +25 offset
    TIRES: Cooper AT3 XLTs in 285/75/18
    Lift
    Front Bilstein 6112s set at the third setting up (1.9")
    Rear 5160 with Coachman 1" shackles.
    Alterations
    mudflaps removed
    stock skid trimmed
    GoldenGoon89, equin and Iowa12tundra like this.
  29. Jun 21, 2020 at 12:11 PM
    #2039
    Dylpickle
    Dylpickle New Member
    2015 Tundra
    325/65/18 BFG KO2
    Method 314 18x9 +18
    Toytec 2.5 coilover
    Deaver expansion pack
    JRock, Ltaco17, NH4x4Tundra and 6 others like this.
  30. Jun 22, 2020 at 7:12 AM
    #2040
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    B38C6D5B-9202-4839-8FA6-113E33E5318E.jpg E6565907-F090-409C-8EBC-E4769BD364C8.jpg 295/70r17 Mickey Thompson ATZ
    Method 701 17 x 8.5- 0 offset
    6112 / 5160
    ajaxv2000, red3, Prostar 190 and 5 others like this.
