Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Jan 4, 2020 at 12:43 PM
    #1921
    InTheRough
    InTheRough New Member
    Kolt
    Gig Harbor, Washington
    2020 Platinum
    AR Headers DirtyDeeds Exhaust UpTop Racks Rock Warrior wheels
    I picked up the truck from the dealer yesterday. It's been so busy around here that I haven't had much time with the truck but I did get a couple pictures of the RW wheels. The beauty rings are still off because I plan on Plastidiping the the wheels and rings for now and powder coating them later.
    2011 Rock Warrior 17x8"
    Kelly Edge AT - LT285/70R17
    TRD lug locks
    Full:
    Front:
    Rear:
  2. Jan 4, 2020 at 4:10 PM
    #1922
    Rlh.airborne
    Rlh.airborne New Member
    2020 Mesquite Tundra TRD Limited
    Looks great, did you stay with stock suspension
  3. Jan 4, 2020 at 4:16 PM
    #1923
    InTheRough
    Kolt
    2020 Platinum
    Thanks! I like them too. Yes, this is a completely stock 2020 Platinum besides the OEM Rock Warrior wheels.
  4. Jan 5, 2020 at 3:44 PM
    #1924
    BoerboelTundra
    BoerboelTundra New Member
    2020 Tundra Super White SR5
    Where did you find cheap 17” rims? I’ve been looking everywhere
  5. Jan 5, 2020 at 3:51 PM
    #1925
    InTheRough
    Kolt
    2020 Platinum
    I'm not sure where he got his but I found my 17" Rock Warrior wheels with like new tires at a local wrecking yard during their black friday sale; paid $700 out the door for the set.
    silverstreak16, drobb and equin like this.
  6. Jan 5, 2020 at 4:14 PM
    #1926
    BoerboelTundra
    WOW nice find!!!
    InTheRough[QUOTED] likes this.
  7. Jan 5, 2020 at 4:25 PM
    #1927
    BoerboelTundra
    Any ideas what the cheapest new 17” rim that fits the tundra (3rdgen) suitable of moderate off road use?
  8. Jan 5, 2020 at 6:31 PM
    #1928
    InTheRough
    Kolt
    2020 Platinum
  9. Jan 5, 2020 at 6:34 PM
    #1929
    BoerboelTundra
  10. Jan 5, 2020 at 6:51 PM
    #1930
    InTheRough
    Kolt
    2020 Platinum
    Ok, just making sure you had seen that.
    I lucked out finding the wheels that I wanted. My personal preference would be to buy a used set of nice wheels than buy a cheap set of new wheels. I've had many issues with the finish on cheap wheels peeling or flaking as well as overall poor quality. Then again, I've got a set of expensive real beadlocks that I bought for my Tacoma before selling it; thinking it was going to be my 'forever truck'. I spent way too much on those and I'm not getting a reasonable return on selling them.
  11. Jan 12, 2020 at 2:52 AM
    #1931
    CTPlatinum
    CTPlatinum New Member
    2020 Tundra Platinum 4x4
    None Yet
    285/60r20 Ridge Grapplers measure 33.7/11.5, those should definitely fit on a +20 offset and a 2.5/2 inch lift. Guys are running 295/70r18 34.3/11.8 on the same setup.
    Bob_Wiley[QUOTED] likes this.
  12. Jan 13, 2020 at 10:38 AM
    #1932
    tundra4466
    tundra4466 New Member
    2020 1794 4x4
    Hey fellas, looking for some offset advice.
    I’m running 285/75/18 on stock trd off-road wheels with a 3/2 spacer lift on 2011 dc 4x4. Looking to replace rims while my tpms sensors are getting replaced. Looks like I’ll be going with 18x9 wheel Vs the factory 18x8 (I believe). Is +30 the right neighborhood without having to cut body mounts? Thanks
  13. Jan 15, 2020 at 2:11 PM
    #1933
    Blueswede
    Blueswede New Member
    2012 Tundra TRD
    Dirty Deeds exhaust
    So I have a 2012 stock Tundra with 18" tires. I'm looking at going to a 20" rim with new tires. Any concerns I should have about a correct fit? Thanks....
  14. Jan 15, 2020 at 2:12 PM
    #1934
    Blueswede
    2012 Tundra TRD
    Dirty Deeds exhaust
    Actually not a 20" rim but 20" tires.....duh.....
  15. Jan 19, 2020 at 5:49 PM
    #1935
    relentlessfax
    relentlessfax New Member
    Matthew
    2020 Tundra TRD Pro
    None
    So what about a 2020 tundra TRO Pro? it has a different suspension. What is the max size tire you can put on it?
  16. Jan 21, 2020 at 3:38 AM
    #1936
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    My journey ends with removing mud guards, front flap and bumper shims. I bought the the Tundra with steel wheels and 255.70.18. Ordered the and installed new set of wheels and tires a couple of days later. 275.65.18 paired with 18x9 +12.
    I was not planning on getting a leveling kit, but I did due to the rubbing. I then installed the leveling kit and paired it with 5100 bottom setting. That lifted the truck 2.5-3". It made my 275.65.18 looks small due to the contrasting color.
    After numerous research and reading through the post and calculating angles and what I can sacrifice even poor mileage, to get the look I am envisioning, on top of performance aspect and weight. I decided to go with Cooper Discoverer AT3 XLT 295.70.18. The overall diameter posted on Discount Tire website is 34.2, in actual measurement it was 33.75 before getting mounted. I will have some major rubbing in the front even after moving the bumper .5". A very slight rub in the driver side boody mount, but on the plus side, no BMC.
    I will be modifying the front bumper trim to eliminate the rubbing using a heat gun to add a contour in the areas that are being affected. As for the mud guards, I will have to cut off the area to expose the body mount.
    Cooper Discoverer AT3 XLT 295.70.18 59lbs 34.2/33.75"
    Vision Manx 2 18x9 +12 offset
    1/2" bumper shim. removed mudguards and bumper guard.
    Tuff Country 2" level kit paired with Bilstein 5100 bottom setting.
    275.65.18 vs 295.70.18
    Clearance with 275.65.18
    AT3 XLT 295.70.18
    Before shimming the bumper and removing mudgards
    I am happy how the truck sits, but I'll be shopping for a different set of wheels in the next few days. +25 offset or bite the bullet and get 285.70.18 Ridge Graplers.
    SRQRUSTY, JPB_VT, ajaxv2000 and 3 others like this.
  17. Jan 22, 2020 at 6:26 AM
    #1937
    pauldrade
    pauldrade Drade Tundra
    Paul
    2013 tundra double cab
    3" lift, 33” tires open country AT2, 18" Mayhem rims, flowmaster exhaust, K&N intake, smoke rear lights and 3rd brake light. Optima RED Top battery, LED Lights all around, Mesh black Grill, Alpine double dash Nav head unit. Suspension 5160s rear 5100s front.
    Anyone know if 33x12.50 AT2 fit with bilstein shock lift highest setting?? Do around 2.5” lift it’s a 2013 tundra
    Thanks guys
  18. Jan 22, 2020 at 7:21 AM
    #1938
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    What is the offset? That matters.
  19. Jan 22, 2020 at 7:39 AM
    #1939
    pauldrade
    Paul
    I have after market 18” rims. Everything else is stock besides the leveling kit I got now which gives me 3” lift. I want to improve the ride with the bilstein 5100s but they don’t give a full 3” lift
  20. Jan 22, 2020 at 8:57 AM
    #1940
    bigblue14
    Craig
    Right but your aftermarket rims potentially have a different offset than your factory rims. The larger the offset, the farther out your wheels protrude. It also leads to more plastic rubbing due the larger pivot arm.
  21. Jan 22, 2020 at 7:51 PM
    #1941
    SR520
    SR520 Lay it tight
    Robert
    Evergreen
    2020 SR5
    Leveled by Toytec: Boss Aluma 2.5 adj coilovers/ UCA
    Front +2" to levelIMG_20200121_092945.jpg IMG_20200121_093009.jpg IMG_20200121_093004.jpg
    Fuel Lethal 18x9 +20 offset
    Yokohama 285/65
  22. Jan 27, 2020 at 12:42 PM
    #1942
    wildbill2020
    wildbill2020 New Member
    2020 tundra sr5 crewmax
    5% tint all around, 35% tinted windshield with a 5% brow, removed stickers/decals
    Anyone ever put a -18 wheel on just a 1.5" level?
  23. Jan 29, 2020 at 8:08 AM
    #1943
    nick5121
    nick5121 New Member
    Nick
    2016 Tundra Limited
    16' Limited. 3.5" RC Lift. 18x9 Fuel Vectors with 295/70/18 Falken Wildpeak A/T3W. Planning to color match the chrome out & get the TRP Pro grill
  24. Jan 31, 2020 at 4:43 PM
    #1944
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    2018 Platinum. 2" level kit. 295/70/18 Toyo Open Country Xtreme AT2 on TRD wheels.IMG_20200131_130227.jpg
    Pillslinger and silverstreak16 like this.
  25. Feb 3, 2020 at 6:31 AM
    #1945
    liquid_g
    liquid_g New Member
    Grantham, New Hampshire
    2018 Tundra Platinum
    Hi all, just a quick question.. on the 20" rim on 3rd Gen Tundra with no lift, this says max tire size is 275/60/R20, one inch taller. Why not any wider? Stock size is 275/55/R20. Is clearance so tight that a 285/55/R20 wouldn't fit? That'd be only 10mm wider.
  26. Feb 3, 2020 at 12:42 PM
    #1946
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    I had 20's on my Tundra, 20x9 +50 offset, completely stock 2wd suspension and I ran 285/55 BFG ko2s. No rubbing anywhere at anytime.
  27. Feb 14, 2020 at 8:13 PM
    #1947
    Doc Green
    Doc Green New Member
    I have a 2011 Tundra SR5, with towing package. All stock. Want to get new wheels +18 offset. 275 65 r18 tires. Will this need modifications?
  28. Feb 15, 2020 at 3:02 PM
    #1948
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    The 285/55/20 comes stock on some TSS or Texas Edition trucks with 20x9 +50 OE wheels. If you have those wheels, you can go to a 275/65/20 and not rub. I put the 275/65/20 on an aftermarket 20x9 with +12 offset and had to remove the front mud flap and aero dam pieces. But other than that it was fine.
  29. Feb 15, 2020 at 3:16 PM
    #1949
    Scuba
    Scuba Sober member
    Austin, Tx.
    I recently ditched my aftermarket 20’s with 275/65/20 BFG and got some stock 18x8’s. Put on the 285/75/18 Nitto Ridge Grappler. Truck has Eibach sport leveling shocks set at 2” and 1.5” lift shackles in the back. I had previously removed the mud flaps and aero dam. I was expecting to need wheel spacers but there’s barely enough room between the tires and the UCA. Maybe 3/8”. There’s minor rubbing on the plastic liner in front of the tire but you can’t even hear it.
    Love the look of the truck. Very happy with the outcome and satisfied with the look. Having a 285 vs a 275 really does wonders for the look of the truck. The 285/75/18 is essentially a 35x11.5. The ridge grapplers are awesome tires. They ride well and are very quiet. I couldn’t be happier.
    I was going to go with the Cooper AT3 in the same size but, Nitto gives Discount Tire employees a 25% rebate when we purchase a set of tires. Cooper doesn’t. That made it a no brainer. :D
    rmiller139, 0600, TNTundra16 and 10 others like this.
  30. Feb 15, 2020 at 6:02 PM
    #1950
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Check my build thread below vvv
